Old 30th Jun 2022, 7:53 pm   #1
Davidwkd71
Default Eddystone s 840 c light question
Has any body wired a facia light so the dial lights up on a eddystone 840 c
Just thought it woukd be nice to have a dial light
I have some small 6v bulbs and fittings
Has any body done this before?.
Davidwkd71 is offline
Old 30th Jun 2022, 9:13 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Eddystone s 840 c light question
The Eddystone 840-series radios being 'hot chassis' designs, I'd not really advise trying to fit any kind of internal scale-illimination.
For night-time operation of my 840A bedside-radio I went with a WWII-era "Lamps, Operator No.6 ZA11521" as detailed herer:
https://www.vintage-radio.net/forum/...d.php?t=185294
run from a 12-volt wall-wart power supply, so I didn't have to do anything to "Steady Eddie" and retained the ungrounded status of the light.
G6Tanuki is offline
Old 1st Jul 2022, 8:44 am   #3
Davidwkd71
That looks a cool idea nice looking lamp thanks gt6tanuki.
Old 1st Jul 2022, 10:40 am   #4
broadgage
A lot of live chassis sets did have scale lamps, but retrofitting these to an existing set needs great care, and a full appreciation of the risks of mains voltage.
Small incandescent lamps wired in series with the valve heaters was a common approach.
The rated current of the lamps should be the same as the heater chain current.
Depending on the total voltage dropped by the lamps, the mains dropper may need adjusting.
An alternative approach is the use of mains voltage neon lamps, be certain to use high brightness types, which are still not that bright but might serve.
broadgage is offline
