30th Jun 2022, 6:01 pm | #1 |
An unusual BS546 plug
I bought the plug shown in the attached photos this morning. It's obviously a BS546 round-pin thing and doesn't appear to be anything special until I mention that the plug body is 3.25" in diameter, the cap is slightly larger at 3.75". Yes, it's the 30A one which I'd never actually seen before.
30th Jun 2022, 6:39 pm | #2 |
Re: An unusual BS546 plug
They used to be used a lot in theatres years ago, but that one looks brand new.
30th Jun 2022, 6:48 pm | #3 |
Lovely!
I remember my aunt's house [which 'went electric' in the very-early-1950s] had one of the 2-pin versions in the kitchen and another in the adjoining scullery/wash-house. Both fed from a single 30A fuse in a wooden-cased fusebox. The 'kitchen' one fed the new-fangled electric cooker; the washroom/scullery one supplied an electrically-heated 'copper' wash-boiler, which the housekeeper would fire-up twice a week to do the laundry. Earthing? back then nobody worried! There was also a BS546 2-pin 15A socket in the kitchen which powered the fridge, and - with some deft plug-swapping-action - a 3Kw 'Swan' electric kettle and what I would describe as a suicide-toaster.
30th Jun 2022, 7:22 pm | #4 |
The 2 pin plugs are BS73.
I grew up in a BS73 wired house. It only gained proper earthing when it was rewired for BS1363 in the mid 60s. |
30th Jun 2022, 7:41 pm | #5 |
I have seen one of the 30 amp sockets in a theatre, marked "210 volts DC" And presumably intended for a carbon arc spotlight.
30th Jun 2022, 7:54 pm | #6 |
Interesting that it has Wandsworth on it. I wonder if it was used by Wandsworth Council maybe in their office premises for something.
30th Jun 2022, 9:18 pm | #7 |
"Wandsworth" were one of the big manufacturers of electrical plugs/sockets in the 1940s/50s/60s. Nothing to do with the Council, it was just a company one of whose owners came from Wandsworth.
"Wandsworth Electrical Manufacturing Co. Ltd (WEMCO). Founded in 1904 in Birmingham by Edward Thomas Davies, Arthur Reynolds and Francis John Ritchie., manufacturers of switches, plugs and sockets. The name Wandsworth has been chosen as a founding member came from the Wandsworth area of London. The still existing, independent, Wandsworth Group is now based in Woking, Surrey."
30th Jun 2022, 9:53 pm | #8 |
I was aware that BS 546 included a 30A plug, but this is the first one I have seen a photo of. Perhaps they were needed for 3kW appliances on 110V mains?
Wandsworth also made the eponymous plugs and sockets, where the earth pin was slotted, and a transverse bar in the slot operated an internal switch in the socket when the plug was inserted. My Aunt's circa 1930-built council house on the Becontree estate in Essex had them until the house was rewired in the mid-1960's Last edited by emeritus; 30th Jun 2022 at 10:01 pm. Reason: Wandsworth plugs comment added |
30th Jun 2022, 10:22 pm | #9 |
The 30A ones were used to supply early versions of upmarket electric-range cookers [the kind that had two ovens, a plate-warming compartment, a grill and six rings on the hob]. My aunt's kitchen had one such, installed in the early-50s and still in-use until she went QRT in 2019.
1st Jul 2022, 4:52 am | #10 |
I think it is new. I did clean it a bit before the photo but it was only surface dirt. Both cord grip screws were there, there were no fragments of wire inside either. Generally used plugs either have missing cord grip screws (one is taken out to remove the cable, not put back) or bits of cut-off wire/cable left in the terminals.
I am told the 30A one fell out of use earlier than the others (which are still being made of course) as it was superceded by the 32A BS4343 (can't remember the CEN number) connector. |
1st Jul 2022, 8:27 am | #11 |
Though it appears to be old enough for the cord-grip screws to have gone rusty.
1st Jul 2022, 8:55 am | #12 |
No, that's just the lighting. The screws to hold the body on are plated steel, those for the cord grip are brass. I have no idea why, but as the 4 former are all identical, ditto the 2 latter, I assume they're original.
Attached is a photo of the 4 sizes of BS546 plug in the obvious order. It shows how large the 30A one is! |
1st Jul 2022, 10:17 am | #13 |
Thanks for the clarification (I hadn't thought of steel v brass) - and for the "identity parade" giving a scale to the 30A plug.
1st Jul 2022, 11:35 am | #14 |
Amazing. I've gathered many thousands of plugs but never seen evidence of the existence of 30A in real life, despite working in various branches of industry and theatre where one might have expected to find one.
1st Jul 2022, 11:51 am | #15 |
Oof Oud would probably be interested in those photos for his digital museum of plugs and sockets.
1st Jul 2022, 2:10 pm | #16 |
1st Jul 2022, 2:12 pm | #17 |
I'd never seen one, or even a photo of one, before. In fact some people had told me it never actually existed. And then, yesterday, I saw a large round-pin plug in a box of oddments at the local antique market. And then I saw the 'BS546' and '30A' in the moulding, so of course I bought it.
1st Jul 2022, 6:32 pm | #18 |
Whatever the application, the mind boggles on how big the flex would have to be to handle the max 30A design load. Must have been at least the equivalent of either 4mm or 6mm in today's money.
Rog |
1st Jul 2022, 6:44 pm | #19 |
I do wonder if they are still in use in another part of the world. For sure in South Africa round pin plugs of the old UK style are still the norm.
1st Jul 2022, 9:09 pm | #20 | |
I have only once seen one in a private house, used for a "fast recovery" immersion heater of 5kw or thereabouts. |
