Old 23rd Jun 2022, 9:45 am   #1
phil_fw
Default Tandberg series 15.
My series 15 performs OK but recently developed a glitch whereby the motor won't turn when selecting play. It is an intermittent problem which suggests it may be bad contacts. I opened the box and can see the function selector switch mechanism but I am wondering where the actual electrical switch is located. Would appreciate guidance before I dismantle more than I need to. Thanks
phil_fw is offline
Old 23rd Jun 2022, 12:34 pm   #2
ben
ben's Avatar
Default Re: Tandberg series 15.
The motor switch is located in the area under the pinch roller. Check/clean the aluminium tape end feeler arm and linkages, which also activate this switch - these get gummed up. Clean those first before trying to dismantle anything. This is a very delicate mech.
Regards,
Ben.
ben is offline
Old 23rd Jun 2022, 5:00 pm   #3
phil_fw
many thanks
phil_fw is offline
Old 6th Jul 2022, 10:33 am   #4
phil_fw
Hi all
I was adjusting my Tandberg - issues with spool torque.. and afterwards there was this "thing" on the table. Perhaps someone could identify it?
It has 18 80 stamped on the surface.
Looks important.
Thanks
Phil
phil_fw is offline
Old 6th Jul 2022, 10:37 am   #5
phil_fw
Hi all
My Tandberg is working well mechanically and plays OK - but - after about 30 minutes the audio quality starts to diminish and distort with the audio level going down as well.
It isn't the heads... I think this feels like a heating problem somewhere in the electronics. If I turn it off for a while the audio is fine again.
Does anybody have a suggestion as to where to look for the problem.
Thanks
Phil
phil_fw is offline
Old 6th Jul 2022, 10:47 am   #6
ben
ben's Avatar
Check the conditions of the amp module and the thermistor. Will look at my notes later and try to be a bit more specific!
Regards,
Ben.
ben is offline
Old 6th Jul 2022, 11:54 am   #7
phil_fw
It is made of Delrin and has those sloping surfaces that look like they are associated with operating clutch or brake mechanisms
phil_fw is offline
Old 7th Jul 2022, 6:16 pm   #8
DMcMahon
DMcMahon's Avatar
Nothing obvious similar seen in the service manual, unfortunately the manual does not have exploded views (s) showing all parts.
DMcMahon is offline
