Old 22nd Jun 2022, 7:35 am   #1
inecik38
Default Rusty clips
Hi, I want to repair a philips turtable, there are some clips and just now there are some rusts on them.I can not find a new one so
1-I can paint them
2-I can sanding
3-I can heat them after put in oil and it can be black colour.
What do you recommend.
Sorry, ı can not send a picture
inecik38 is offline
Old 22nd Jun 2022, 7:42 am   #2
inecik38
Default Re: Rusty clips
Thats are pictures
inecik38 is offline
Old 22nd Jun 2022, 8:03 am   #3
Cobaltblue
Cobaltblue's Avatar
Hi you can buy new clips I dont know if these are close enough:
https://www.ebay.co.uk/itm/384382145051
Just an example not a recomendation.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 22nd Jun 2022, 8:03 am   #4
Nickthedentist
Nickthedentist's Avatar
Hello,
These clips are plated, so "sanding" would be too aggressive. But you could try a coarse metal polish.
I have also had great success on this kind of thing with a product called Evapo-Rust. It's not cheap, but you can re-use it, so it goes a long way.
Nickthedentist is offline
Old 22nd Jun 2022, 9:18 am   #5
snowman_al
snowman_al's Avatar
You could try something the car enthusiasts do for pitted or lightly rusted chrome work.
Use aluminium cooking foil, squeeze it into a rough ball, dampen it with water and rub the chrome with it. It does work.
https://www.youtube.com/watch?v=e0FN...arolinaPrepper
You can use a chrome or brass polish after to preserve finish.
Never Leave Well Enough Alone...
snowman_al is offline
Old 22nd Jun 2022, 3:05 pm   #6
Uncle Bulgaria
Uncle Bulgaria's Avatar
I'd try polishing first.
1) Evapo-Rust is genuinely brilliant. There are so few products that live up to the results one hopes for, but this really is marvellous. Put the rusty object in, leave it overnight, rinse it off and it's shiny. Astonishing. The stuff is reusable until it stops working too, so is actually pretty economical. I've started using it last year probably twice a month and am still on the same tub I originally decanted.
2) You could do some DIY electroplating.
3) New clips might be available. Certainly other types are, even if they don't match the originals. Look for flight case suppliers like Penn Elcom, who have a lot of different 'over centre' catches.
Uncle Bulgaria is online now
Old 23rd Jun 2022, 9:59 am   #7
Heatercathodeshort
Heatercathodeshort's Avatar
These were very rusty. I removed them and gave them a heavy clean with a rotary electric wire brush. A spray coat of clear lacquer gives a good appearance. Just my way. John.
Heatercathodeshort is offline
Old 23rd Jun 2022, 3:38 pm   #8
Viscount
yes i use the wire brush method as well if you finish with a really fine one you can get some really good results
Viscount is online now
Old 25th Jun 2022, 7:03 am   #9
inecik38
Hi I cleaned with brush and pumice just now it is better.
inecik38 is offline
