10th Jun 2022, 9:03 am | #1 |
Magneto phone generates no ring voltage
I have a 300MT phone - that's an Australian number - Circuit attached, that produces no voltage. The gravity swith operates and the magneto switch looks to move when the hadle is turned. The handle moves freely even with the handet out of the cradle and I can't hear anything in the earphone when the handle is turned. Could the magneto be dead? How can I test it?
The magneto swith seems to be working - continuity and then open when I turn the handle. With an ohmmeter between the red wire in the pic and either the green or white wire, I hear a crackle in the earphone. TIA |
10th Jun 2022, 11:29 am | #2 |
Re: Magneto phone generates no ring voltage
Hi Peter, a crude test would be to connect wires to L1 & L2 then get a pal to gently turn the magneto handle whilst you hold the bared ends in both hands. If magneto works, this should result in you get tingling sensation denoted AC ring current.
The best method would be to connect another phone to L1 & L2. Rog |
10th Jun 2022, 11:39 am | #3 | |
Rog |
10th Jun 2022, 11:43 am | #4 |
Thanks Roger
I shall try your suggestion. No heart pacemaker or heart condition here. |
10th Jun 2022, 2:38 pm | #5 |
If you're reading O/C while the handle is turned, it sounds as though there may be a lack of continuity within the magneto coil. The continuity otherwise is through the ringer, though a DC continuity reading seems to indicate a very leaky ringing capacitor.
10th Jun 2022, 3:46 pm | #6 |
Put a wire between 10 and 11, keep the handset on hook and try the generator, The ringer should ring.
10th Jun 2022, 11:22 pm | #7 |
I suspect the 1.7uF cap is leaky
11th Jun 2022, 12:24 am | #8 |
When I was a boy and fascinated with magneto phones, friends tired of being the dummy load for testing ringing current, quickly found that a wire ended Neon lamp would flash brightly and with a series resistor would indicate relative efficiency.
11th Jun 2022, 3:13 am | #9 |
11th Jun 2022, 4:10 am | #10 |
Hmm As an aussie kid from da bush. When ringing one didnt lift the receiver at all!!.
If you wanted grandmah, who's number was three longs and two shorts on the party line, You merely swing the handle for about 2 seconds for the longs,paused for about two seconds, and then swung the handle for about half a second for the shorts. One of course had to pause between the longs and the shorts. A little bit like morse. THis ringing made EVERY PERSON on the party line lift the receiver!! . So your message to grandmah was known by the whole community on that party line. OOHHH Florrie didja hear ?? etc etc. It was VERY common to replace the Tally Ho between the carbon blocks after a storm. For our POHM jailers that transported us, a Tally Ho is a " fag paper " used as lightning arrester between the two carbon blocks. We had two BIG single cell Le Clanche cells as the electricity for the carbon ganule microphone, and the 2000 ohm ear piece. I have forgotten the size but if memory serves me they were F cells. About the size of a LARGE beer can. Just memories. Joe Last edited by joebog1; 11th Jun 2022 at 4:12 am. Reason: more info |
11th Jun 2022, 4:13 am | #11 |
we didnt have a phone as kids, but my Nanna did ( aka grandmah ) on a party line.
j.b. |
11th Jun 2022, 4:19 am | #12 |
Found a pic, these are made in USA, ours were made in Au.
Joe |
11th Jun 2022, 8:33 am | #13 |
I took the generator apart and noticed a wire had been cut. Also one small carbon brush was missing.
11th Jun 2022, 8:45 am | #14 |
It sounds as though the magneto has passed its best and is in line for replacement - likewise the ringing capacitor. The latter appears to have been a multiple capacitor, but the modern replacements can probably be mounted in the existing can after removal of its innards if you want to keep original looks. Do you have any indication of the capacitor values?
11th Jun 2022, 8:52 am | #15 |
Perils of buying online. Someone had been there in the past. Actually the whole phone has had a hard life. The dual capacitor was in very poor shape having leaked a lot of pitch. Values are 1.7 and 0.4 uF for that capacitor. Anyway, I've learnt something byt taking the generator apar.
11th Jun 2022, 9:28 am | #16 |
The brushes are probably easily remade by grinding down ( emery paper on a flat block ) very coomon Makita or similar electric drill brushes. Super cheap on those auction sites.
FIRST though, I would be running a megger test on the armature windings to ground. If they have blown out the insulation on the armature, I am afraid your lost. UNLESS you can find another phone. Joe |
11th Jun 2022, 9:41 am | #17 |
Thanks Joe
Brushes are quite small - 2.4mm diameter I've got a few derelict phones I can harvest for parts. Last edited by petervk2mlg; 11th Jun 2022 at 9:49 am. Reason: typo |
11th Jun 2022, 9:58 am | #18 |
Modern equivalents would be 1.8μF and 0.47μF respecively.
11th Jun 2022, 4:09 pm | #19 | |
Also liked the piccy's of the batteries... I often changed identical ones on burglar alarms in the mid 70"s. We used to call them flag cells & I recall they were made in Northern Ireland. They were 1.5V and to load test I was taught to put an ammeter (10A range) across the terminals - a reading of between 4 & 6 amps indicated a good battery. Rog |
11th Jun 2022, 5:04 pm | #20 |
Non of thos capacitor is needed to make it work well, so you may just strap them. If you forget to hang up the phone will give highh load on the line when somone else is cranking, that is imprtant on a partyline, but not else.
