9th Jun 2022, 10:25 am | #1 |
Question re item (Identified as Bellset 20)
Can someone tell me what the item pictured is and what function it might serve?
9th Jun 2022, 10:41 am | #2 |
Re: Question re item
Judging by the switch positions it's a mini exchange. The incoming main telephone line (exchange) can be directed to the primary (main) telephone or the secondary (extension ) phone. Also the primary phone can call the secondary as an internal call.
9th Jun 2022, 10:55 am | #3 |
What you have there is a Bellset 20.
Perhaps I should add that Duncan's description of its function is spot on.
Mending is better than Ending (cf Brave New World by Aldous Huxley) Last edited by Dave Moll; 9th Jun 2022 at 11:01 am. |
9th Jun 2022, 12:00 pm | #4 |
Many thanks gentlemen. I'm pretty much a novice with old phones. Could I use this with magneto phones?
9th Jun 2022, 3:35 pm | #5 |
It's designed for use with CB/auto rather than magneto. I'm not sure how happy it would be with magneto ringing current coming from the extension(s). The magneto included is to signal to the extension(s). What sort of magneto 'phones are you intending to use?
10th Jun 2022, 1:26 am | #6 |
Re: Question re item (Identified as Bellset 20)
Thanks Dave. I thought that the ringing current might be a concern. I have a few magneto phones, such as the 300MT and the 338MT. These are Australian numbers perhaps but must have been based on English models.
10th Jun 2022, 9:12 am | #7 |
Looking at your circuit diagram, those 'phones should be fine as long as you resist the temptation to turn the magneto handle. Lifting the handset on the extension should make a loop which activates the indicator on the BS20, so no need for a magneto signal. Best to avoid connecting to the telephone network though - presumably, Australia has similar rules to the UK about this.
I look forward to hearing how you get on.
10th Jun 2022, 11:04 am | #8 | |
There is a separate Australian PMG version of the 'Bell Set 20' for use on magneto systems -see picture In the UK, the Bellset 20 was used on CB(manual) systems and on automatic exchange lines. |
10th Jun 2022, 11:07 am | #9 | ||
11th Jun 2022, 9:03 am | #10 |
Thanks. Later, I found this for sale online.
11th Jun 2022, 9:05 am | #11 |
Pic
