Old 15th May 2022, 3:30 pm   #1
6SN7WGTB
Default Simple low power RF attenuator
I was after one of the above, and decided to make my own using SMD components and a toner transfer PCB.
It's 0.6dB down at 100Mhz, and 1dB down at 200MHz.
In terms of accuracy, I'm getting 1.96dB, 4.17dB, 8.07dB and 15.88dB on each step.
I've never built anything RF before so I'm sure it breaks all sorts of best practice, but seems good enough for Government work as they say.
ID:	257234   Click image for larger version
ID:	257235   Click image for larger version
6SN7WGTB is offline
Old 15th May 2022, 11:30 pm   #2
Wendymott
Wendymott's Avatar
Default Re: Simple low power RF attenuator
Looks ok to me. Its all a matter of..is it ok for the uses you are putting it to. If you are wanting Test House Lab results... maybe not.... If its for personal use, you know the limitations, and could adjust if need be. Fine effort .
Should get out more.
Regards
Wendy G8BZY
Wendymott is online now
Old 15th May 2022, 11:32 pm   #3
joebog1
Very nicely finished and presented too !!
Joe
joebog1 is offline
