Old 3rd Apr 2022, 4:32 pm   #1
Colourstar
Colourstar's Avatar
Default Basket Case Bush SRG71
I rescued this locally last year as it seemed destined for the dump, which seemed rather a shame. However having brought it home I wondered why I'd bothered, as it was in such appalling condition. In the same family from new, it had fallen on hard times, having spent many years relegated to an outhouse. The cabinet is scratched, stained, damaged and filthy. Picture 2 shows how bad the top is. Even the family dog had chewed one corner! On the plus side, the radio chassis and record deck should prove straightforward to revive.
Radiograms like this have little if any value even in good shape, so this will be a labour of love to say the least. This afternoon out of idle curiosity I attacked the top of the cabinet with wire wool and meths. (I'm aware that sandpaper is to be avoided as it can be so easy to sand through the veneer). Anyway after some elbow grease it became evident on a test patch that beneath the stained and scratched finish lay hidden beauty. A final wipe over with a spirit-soaked cloth brought forth all sorts of attractive colour and warmth. On this basis I'm inclined to proceed, as there's really nothing to lose! I don't know whether meths & wire wool is the correct approach. It's slow but seems to work. Would Nitromors be more effective or would that not be appropriate here?
Any advice welcome.
Steve
ID:	254570   Click image for larger version
ID:	254571   Click image for larger version
ID:	254572   Click image for larger version
Colourstar is offline
Old 3rd Apr 2022, 8:40 pm   #2
kirstyd
Default Re: Basket Case Bush SRG71
ID:	254593I used to have the stereo version of this radiogram SRG81 from 1959 and despite its small size it sounded really good once it had been serviced . I stripped the cabinet and then French polished it .I also removed the brass trim that was tarnished stripped it polished it and then gave it a fresh coat of cellulose. You can also clean the speaker covering with household cleaner [its not cloth so it wont shrink . Nice machine and well worth the effort. The photo is of the SRG 86 the top of the range model for that year
kirstyd is offline
Old 3rd Apr 2022, 8:42 pm   #3
kirstyd
just to add i did use nitro moors and it worked a treat
kirstyd is offline
Old 3rd Apr 2022, 9:52 pm   #4
Colourstar
Colourstar's Avatar
Thanks Kirsty. Yes these old Bush grams have a certain quality and are very well built. It would be nice to give this one a second chance. I was surprised to see that it wasn't stereo- the two speakers are wired in parallel and there's a mono cartridge fitted. I wrongly assumed that Bush RG prefix model numbers were mono and SRG stereo.
Anyway on with the Nitromors then...!
Steve
Old 4th Apr 2022, 12:03 pm   #5
Heatercathodeshort
Heatercathodeshort's Avatar
It is a mono gram with provision for stereo by adding a AU71 amplifier. I doubt if anyone did! J.
Heatercathodeshort is offline
Old 6th Apr 2022, 9:06 pm   #6
kirstyd
The SRG 81 looks the same but is stereo . you can tell at a glance by its ivory knobs and the extra pickup head usually mounted in a bracket next to the record player. I have the user manual for the 71 if you would like it send me your address and i will pop it in the post
kirstyd is offline
Old 6th Apr 2022, 10:07 pm   #7
joebog1
Am I being pedantic?, or does one lay on the floor to remove/replace a record??.
Joe
joebog1 is offline
Old 7th Apr 2022, 9:19 am   #8
PaulR
PaulR's Avatar
You may well already know this, but beware of any paint strippers that contain water or are removed by water if you use wire wool to remove the stripper. It leaves tiny fragments of steel which rust and leave brown spots.
Paul
PaulR is offline
Old 7th Apr 2022, 8:53 pm   #9
kirstyd
yes joe once the front flap is down you need to get on the floor to put records on
kirstyd is offline
