24th May 2022, 5:58 pm | #121 |
Re: Perth PET
Apologies.
Reversed them now. Pins 26,27,28,30 & 32 at c. 5.4v Pins 29,31 & 33 show c. 0.4v. Should they have zero voltage or is 0.4 ok? Colin. |
24th May 2022, 6:05 pm | #122 |
Re: Perth PET
0.4V is OK because they are not bolted to 0V, they are connected via resistors which allows them a little bit of, but not too much, freedom. As mentioned before the reason we use resistors is in case the CPU somehow gets into data-output mode in which case it would not be a good idea for the data lines to be hard-connected to 0V and 5V.
Assuming all of those voltages are 'static' (steady), can you now power up and look to see if there is a steady squarewave on CPU pin 9 (A0) and if there is, look for these frequencies on the CPU address pins as originally found by you at the same stage in your earlier thread. Expect only random characters on the screen during this phase as the code which normally clears the screen and prints the initial greeting is not being executed. Code:
Address line Pin Frequency A0 9 250Khz A1 10 125Khz A2 11 62.5Khz A3 12 31.25Khz A4 13 15.63Khz A5 14 7.813Khz A6 15 3.096Khz A7 16 1.953Khz A8 17 976.6Hz A9 18 488.3Hz A10 19 244.3Hz A11 20 122.1Hz A12 22 61.05Hz A13 23 30.53Hz A14 24 15.26Hz A15 25 7.632Hz |
24th May 2022, 6:35 pm | #123 |
Re: Perth PET
All frequencies are as above.
Colin. |
24th May 2022, 6:49 pm | #124 |
Re: Perth PET
That's reassuring, as it suggests that the CPU is OK and executing at least one intruction correctly.
Now look for the same frequencies on the buffered BA0 to BA15 address lines, all of those lines should have good strong, clean 0v-5V waveforms on them. Code:
Sig IC Pin BA0 UC3 18 BA1 UC3 3 BA2 UC3 16 BA3 UC3 5 BA4 UC3 14 BA5 UC3 7 BA6 UC3 12 BA7 UC3 9 BA8 UB3 18 BA9 UB3 3 BA10 UB3 16 BA11 UB3 5 BA12 UB3 14 BA13 UB3 7 BA14 UB3 12 BA15 UB3 9 |
24th May 2022, 6:56 pm | #125 |
Re: Perth PET
All matched as above with square waves. I had to reduce the time/div to pick up the smaller frequencies but they're all there.
Colin. |
24th May 2022, 7:06 pm | #126 |
Re: Perth PET
OK, now you need to dual-wield and look at pairs of PROM chip select pins.
with both traces enabled, look at the following pairs of IC pins at the same time UD9 pin 20 and UD8 pin 20 UD8 pin 20 and UD7 pin 20 UD7 pin 20 and UD6 pin 20 The signals you see there should be mostly high, momentarily low, and in each case the two momentary-low chip select signals should be slightly staggered / offset, you should never see both low at the same time. |
24th May 2022, 8:25 pm | #127 | |
Re: Perth PET
Working exactly as you described.
Colin. Quote:
24th May 2022, 9:11 pm | #128 |
Re: Perth PET
Good, that means the address decoder is at least nominally working.
Let's do a quick check on the read / write signal which emerges from the CPU, passes through several gates and (if none of the earlier gates are faulty) should be available on UA3 pin 8, also look at the read enable signal for the system data bus buffers on UE9 and UE10 pin 19 (signal on those last two should look identical) |
24th May 2022, 9:24 pm | #129 | |
Re: Perth PET
UE9 and UE10/19 check out nicely together.
UA3 pin 8 goes straight to 5.4V and stays there however. Colin. Quote:
24th May 2022, 9:32 pm | #130 |
Re: Perth PET
Work back through the following points on the R/W signal chain until you find activity, and report back.
UA3 pin 9 UA3 pin 12 UA3 pin 13 UA10 pin 4 UA10 pin 3 6502 pin 34 |
24th May 2022, 9:47 pm | #131 |
Re: Perth PET
No square waves anywhere. |Voltages as below:
UA3 pin 9 - 0v UA3 pin 12 - 0v UA3 pin 13 - 5.3v UA10 pin 4 - 5.3v UA10 pin 3 - 4.4v 6502 pin 34 - 4.24v I powered off and checked continuity from pin 34 for the 6502 to the pin 34 pad on the motherboard and that's good so I don't think it's the NOP device getting in the way of pin 34's connection. Colin. |
24th May 2022, 10:00 pm | #132 |
Re: Perth PET
We may be chasing down a red herring here as the R/W line is probably in the 'high' state at all times unless the CPU attempts to write to something, at which point it will go momentarily low. At the moment we are forcing the CPU to do read-only operations.
Have a look at the general state of the unbuffered motherboard data lines DA0-DA7 but this time on CPU pads 33-26 on the motherboard, not on the CPU. Each one will probably be a mess of activity, what you are looking for is one which looks substantially different to the others in terms of the shape or the height of the signals. Last edited by SiriusHardware; 24th May 2022 at 10:11 pm. |
24th May 2022, 10:14 pm | #133 |
Re: Perth PET
Not easy to get in there with the NOP device, but I saw square waves on every pad.
Colin. |
24th May 2022, 10:19 pm | #134 |
Re: Perth PET
Now try looking at the buffered data lines on the 'other side' of UE9 / UE10, specifically,
Pins 18, 16, 14, 12 of UE9 and Pins 18, 16, 14, 12 of UE10 Anything out of the ordinary? |
24th May 2022, 10:50 pm | #135 |
Re: Perth PET
No - good square waves that are the same on each pin and compare the same across the ICs (for example UE9 and UE10 pin 18).
Colin. |
24th May 2022, 11:07 pm | #136 |
Re: Perth PET
Okay, will have to have a think about where to go next. (As usual, everyone else please pitch in with ideas).
The unbuffered and buffered address bus look normal as does the address decoder which selects the PROMs which in turn present their data directly to the CPU (not via buffers). The Test EPROMs (Slothie's, Daver2's) carefully avoid using external RAM until they are sure that zero page RAM at least is working and if it isn't they report that by writing to the video RAM. But even that basic environment apparently is not working, so at the moment we have to say that either the CPU is unable to read and execute code from PROM, or code is running but is unable to report results because it can not pass anything through the buffers to the video RAM. The video system itself is running OK, happily rendering the random startup content of the video RAM onto the screen. |
25th May 2022, 10:47 am | #137 |
Re: Perth PET
Couple of quick photos to show where we are without the NOP test socket installed.
Photo 1 is a consistent screen whether I have the 6502 fitted with original ROMS, the 6502 fitted with DaveR2 test ROM as well, or the 6502 fitted with Slothie test ROM fitted. Photo 2 is with the Tynemouth board fitted, a different (new to me) 6502 and ROM and RAM provided off the Tynemouth board (Basic 4 and motherboard ROM/RAM bypassed). You can just see on photo 2 that the normal screen is partially there in the top left hand corner, along with a flashing cursor but that the keyboard does not work at all. Colin. |
25th May 2022, 5:17 pm | #138 |
Re: Perth PET
Since the Tynemouth board is eliminating the PET's own RAM and ROM from the equation we seem to have come back to looking for an intermittent problem somewhere in the vicinity of the video, PIA/VIA or CPU logic circuitry. I know that the PET is generating characters and some are being held in video RAM but the two video RAMs (previously replaced!) are now socketed so it might be worth checking them by substitution if Colin has any spares. The same applies to the VIA and PIAs particularly the keyboard PIA (UC7). I don’t think any of the three have been replaced before. There are quite a few socketed logic chips dotted around the circuit now and some of them could again be checked by substitution if Colin has any in his spares collection. Of course a poor connection somewhere is still a strong possibility but I’m sure Colin will keep his eyes open and meter in hand. I know I’m fumbling around in the dark but my excuse is that intermittent faults are often really difficult to track down. Hopefully Sirius will come up with some more logical/methodical ideas on how to proceed as well. Alan
25th May 2022, 5:45 pm | #139 |
Re: Perth PET
I was just wondering if the high voltages, up to 5.49v, reported by Colin in earlier posts were indicating a supply voltage issue or just a limit of the accuracy of his dmm.
5.5v would be the maximum recommended supply voltage for TTL and possibly some of the other ICs in the PET. If there are two separate 5v supplies a large offset between them could cause some issues where two groups of ICs are at different supply voltage. I don’t remember if the PET has this type of supply. |
25th May 2022, 6:48 pm | #140 | |
Re: Perth PET
The voltage readings came from the scope. I could re-read with the meter; I suppose it's impossible to know which is likely to be more accurate?
Colin. Quote:
