Old 10th Dec 2021, 1:33 pm   #1
retroaudio
Default Domino Convertor
Hi I have had one of these since they came out but stopped using it when the external plug in transformer got broken. I was going to use it again but I wasn't sure what the values of the transformer should be. Can anyone enlighten me.
Alex
retroaudio is offline
Old 10th Dec 2021, 1:56 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Domino Convertor
I would recommend a 12V 1A regulated supply. A linear rather than a switch-mode is
preferable.
Restoration73 is offline
Old 10th Dec 2021, 2:08 pm   #3
Freya
Freya's Avatar
Agreed, linear regulated is a must.
Stephen
Freya is offline
Old 10th Dec 2021, 7:16 pm   #4
radiomarktv
Once you’ve obtained a suitable PSU for it, if you find the domino fails to work it could be down to the tantalum capacitors failing. Mine failed and I’ve been informed other dominos have failed too in the same way.
Mark.
radiomarktv is offline
Old 10th Dec 2021, 10:22 pm   #5
murphyv310
murphyv310's Avatar
Best always to test with a bench supply first and bring up the supply up over a minute especially if the converter hasn't been used for some years. I made a soft start PSU for one which I had replaced caps in after a couple let go.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
