Old 7th Jun 2022, 7:17 pm   #1
vinrads
Default Pioneer TX 7500 tuner repair
This tuner came in from a friend ,it belonged to a good friend of his , who is suffering from terminal lung cancer ,so this one took priority , on plugging in I was greeted with the usual fm noise as if it was working ,I soon found out it wasn't , there was 12 volts on the tuning heart , so remover the module ,tied the tuning drum down so I didn't have to re string it , the rf amp transistor read ok , just to be sure applied a strong sig to the output of that stage ,still no sig , next step checked if the osc was running and tuning with the scope all ok , luckily the mixer transistor wasn't to bad to get at ,having removed it 2SC535 ,it was found to be oc all round , fitted a replacement now we have stations , you do need a 100 watt iron to remove the screening , It is now with the owner a small thing that made him happy for a while . Mick.
ID:	258584   Click image for larger version
vinrads is offline
Old 7th Jun 2022, 7:50 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Pioneer TX 7500 tuner repair
Nice story, well done.
paulsherwin is offline
Old 21st Jun 2022, 3:32 pm   #3
Uncle Bulgaria
Uncle Bulgaria's Avatar
A hundred watt iron looks like a minimum! I'm impressed by the logical, clear fault-finding leading to a good result.
Uncle Bulgaria is offline
