Old 6th May 2022, 4:18 pm   #1
6SN7WGTB
Default HeathKit GD-1U Dip Meter new dial
Acquired a very good GD-1U and although it was mint internally, have replaced the rectifier and smoothing caps, plus made the mains switch DP as curiously for a UK model (with a DPST switch) HK only seemed to wire it SP.
The dial sticker was tired and also a bit off in terms of calibration.
So, drew up a revised one and both calibrated it plus added the optional three 'Low Frequency' X,Y&Z coil ranges.
A fair old faff to design the artwork, but worth it I think. Printed on a label and cut it out using a scalpel blade on a pair of compasses.
It could do with being a mm or so smaller - might do that as I used easy peel stickers.
ID:	256713   Click image for larger version
6SN7WGTB is offline
Old 7th May 2022, 7:23 pm   #2
newlite4
newlite4's Avatar
Default Re: HeathKit GD-1U Dip Meter new dial
What a great idea! I am sure that many of us have these GD-1U meters and have encountered the same problem. Over time, dirt creeps in and makes the markings illegible. The other Heathkit version was better because the dial is more enclosed.
Neil
newlite4 is offline
