29th Apr 2022, 1:10 pm | #41 |
Re: Mains filtering
These are often delta caps: One X-cap L-N and two Y-caps L & N to E. Historically they were pass-through devices with inline chokes too, but those seem to have become less popular now. The frequency range of the offending emissions is probably narrower overall, being from SMPSUs rather than universal motors.
29th Apr 2022, 3:04 pm | #42 |
Re: Mains filtering
Would it be possible/practical to fit X and Y caps to my distribution unit, either to the two main incomers or the RCDs? Has anyone done/tried that?
29th Apr 2022, 3:17 pm | #43 | |
Re: Mains filtering
"But also remember that an HF ferrite choke will typically need 6-8 turns passing through the centre hole. Regardless of the type of core, one pass through the centre will never be effective at HF!" To see any significant difference I think you'll need to adopt the sort of filter that M0NWK and GM3SEK have described. Hugh |
29th Apr 2022, 3:41 pm | #44 |
Re: Mains filtering
I think any form of mains filter would have to be 'tuneable' as such. Maybe more luck than science but recently when working on a Bush MB60 powered from the bench isolating transformer I connected a 4700pf 300v AC ceramic capacitor inside another 13 amp plug. When plugged into the double 13amp socket on the transformer output the noise was cut by about 70% but the frequency range of the interference suppressed is no doubt narrow.
LED replacement 'fluorescent' tubes generate an unbelievable racket over their entire length! Be warned if you intend to fit them over your bench and work on AM radios. Pity, the light is first class with very little shadow, not a problem for me because I work mainly with TV. John. |
29th Apr 2022, 4:49 pm | #45 |
Re: Mains filtering
Those with noise incoming on their mains - be suspicious of any nearby solar power installations, there have been reports of these causing such problems and exporting noise on the mains with cheap Chinese inverters being blamed .
See if there is any reduction in interference when the sun goes down. Apart from this, large UPSs in nearby premises could be an issue also. |
29th Apr 2022, 6:05 pm | #46 | ||
Re: Mains filtering
I've still not (quite) given up hope that there's something that can be done - even if I have to spend quite a bit of money for a professional installation - to reduce the interference on those incoming cables.
30th Apr 2022, 8:15 am | #47 |
Re: Mains filtering
Hi Steve,
This one has really taxed my faded old brain but I had a few more thoughts overnight, so this will by my swansong:- 1. Firstly I wonder if your house had been wired in he old lead sheathed cable - similar to today's twin & earth would mitigate the problem. With this in mind, rewiring with MICC aka PYRO 9copper sheathed) or FP200 (aluminium / pvc sheathed) may provide effective screening to the phase & neutral components. Obviously very disruptive & mega expensive though ! 2. More realistically & on the presumption that you only listen to one station, could the radio chassis be relocated in an interference free area with the speaker & switch wires being extended to the room where you normally prefer to listen ? Along of course with the cabinet for aesthetic effect ? Rog |
30th Apr 2022, 9:26 am | #48 |
Re: Mains filtering
That is very interesting CK. There is a truly massive solar 'power station' around 4 miles away at Billingshurst West Sussex. I watched them bury the massive cables underground to run parallel with the main A29 adjacent to the site. May not be the problem but worth noting. John.
30th Apr 2022, 10:47 am | #49 |
Re: Mains filtering
Regarding Y caps - these essentially inject RFI on L and N into the ground wire. That is why hospital grade mains filters do not have Y caps fitted - one X caps between L and N.
Craig
Doomed for a certain term to walk the night |
30th Apr 2022, 10:50 am | #50 | |
Re: Mains filtering
I imagine a professional installation would be very wise, not least to make sure that there's adequate fault protection in place and that you don't risk upsetting your electricity supplier or invalidating your fire insurance. Personally I'd want anything like that put into its own screwed-shut steel box. Cheers, GJ
http://www.ampregen.com |
30th Apr 2022, 10:51 am | #51 |
Re: Mains filtering
Why? Cheers.
30th Apr 2022, 10:56 am | #52 | |
Re: Mains filtering
2) That's not something I'd do Roger! Obviously one can move things around and I can think of many things that I could do to 'improve' things, and I have done that in the past and now. My objective was, and is, to remove as far as it is possible, the RFI on my mains supply and house wiring. I accept it may not be feasible.
30th Apr 2022, 11:00 am | #53 |
Re: Mains filtering
Because when a patient is attached to a machine, connection between the person connected to ground and live/neutral is generally not a good thing.
From Shaffner's data on medical grade mains filters "The B types of the Schaffner IEC inlet filters are designed without Y-caps due to the above mentioned leakage-current requirements of MDs. All filter families are also available with an earth line choke" Craig
30th Apr 2022, 11:02 am | #54 |
Re: Mains filtering
Having said all that about filters, I have all the parts on hand for building the mains filter linked in the OP's post to feed my collection of Racal RA17 and accessories.
Craig
30th Apr 2022, 11:33 am | #55 |
Re: Mains filtering
Be interesting to know how you get on Craig.
1st May 2022, 8:34 am | #56 |
Re: Mains filtering
My RA17II is in late rebuild after five years plus in the attic (MHz and kHz tuning frozen). Then I recently acquired an ex GCHQ RA17W which needs a complete resistor and capacitor rebuild. Basically an RA17L with different IF bandwidths and a few other minor mods.
An RA37 LF convertor which is fully working An RA98 ISB unit, recently restored, but with an oil leak from the mains transformer. Replacement transformer on hand to replace it. An RA63 sideband adaptor A NOS RA121 - a sideband adaptor with a CRT screen to indicate tuning. Having said that, many resistors read high - 50% or so - which must have happened in storage. So weirdly for a NOS unit it needs laying on of hands. Once I have at least one receiver up and running, I'll get the mains filter built and do some tests - which I'll report here. Craig
1st May 2022, 1:28 pm | #57 |
Re: Mains filtering
Just a thought - but it looks like (from your pictures) you have an old-style
'smart' meter which I think transmits on the old 2/3G network. Could this be a source of your problems? |
1st May 2022, 3:03 pm | #58 |
Re: Mains filtering
Can someone answer this?
2nd May 2022, 10:37 am | #59 |
Re: Mains filtering
If the meter is suspect then there is some hope perhaps for your situation..
If it is on 3G then they will probably replace it with a new type of simpler unit operating on 4/5G soon, as they are closing the 3G network sometime in the next year or so. .. but are keeping 2G for simple, emergency situations.. but obviously don't know if that applies to your meter as 2G may not be enough to give them the data they require from your installation. The newer types of smart meter instals now have the transmitter separate from the meter. If you cannot find a solution elsewhere and it continues to drive you up the wall it might be something you want to talk to your meter supplier about as the early smart meters were only concerned with getting data out of you, and they may have had similar complaints to yours causing them to re-design the later meters. Last edited by cheerfulcharlie; 2nd May 2022 at 10:57 am. |
2nd May 2022, 10:54 am | #60 | |
Re: Mains filtering
