28th Apr 2022, 10:52 am | #21 | |
Re: Mains filtering
PE = Phase/Earth impedance. PFC = Prospective Fault Current. PN = Phase/Neutral impedance. PSC = Prospective Short Circuit Fault Current. Lawrence. |
28th Apr 2022, 11:11 am | #22 |
Re: Mains filtering
Hi again Steve, despite the "fools errand:, comment in post [9], I still feel that switching off the house supply to see if the issue resolves or improves is worthwhile because:-
a) If reception improves then it can be concluded that the interference is emanating from the phase and / or neutral wiring of the ring main. or b) If the reception does not improve then it can be concluded that the interference is emanating from the earth wiring (as also suggested in post [9]of the ring main) or maybe another source ? This test should only take a minute or two and either way this will give us more info on the probable cause as opposed to just making assumptions. Going off thread slightly & with your best interest in mind, I would be tempted to remove the ferrite clamps from the DNO's meter tail. I say this because they could be presumed as meter tampering to reduce bills (similar to the old magnet trick on the mechanical meters). Of course, this is clearly not the case but best not to leave yourself open to any presumption by the REC who may not fully understand the theory involved. Rog |
28th Apr 2022, 11:55 am | #23 |
Re: Mains filtering
Given my earthing system, why would I want to improve the ELI? will it improve the noise issue or act as an aid to anything that I can do to improve it?
28th Apr 2022, 12:02 pm | #24 | |
Re: Mains filtering
Regarding the ferrite rings on my mains supply, thanks for the advice but I'm going to leave them on. I'd be more than happy to fight my corner with anyone who is suggesting that they are being used as a meter tampering device. It may well be that they are doing 'nothing' in which case I will remove them, but for now at least I'm leaving them in place. Thanks again.
28th Apr 2022, 12:07 pm | #25 | ||
Re: Mains filtering
28th Apr 2022, 12:25 pm | #26 |
Re: Mains filtering
My supply comes via a pole transformer 11kv to 240V> just outside the bungalow. AM reception used to be of similar quality to FM but over the last years it has become almost impossible to listen to AM at all and I only have a few neighbours! The mains appears to be loaded with it. The earthing is I believe 'local'. The neutral appears to be connected to a thick earth wire.
I have experimented with various mains filters but they all do practically nothing. I think we have to give up AM broadcasting, there are other means of reception. The earth wire that branches off to the right in the meter cupboard vanishes under a concrete floor, presumably the bungalow earth or a return to one of the wires rising on the pole. Anyway it works OK. John. Last edited by Heatercathodeshort; 28th Apr 2022 at 12:32 pm. |
28th Apr 2022, 1:17 pm | #27 | |
Re: Mains filtering
The Earth wire going into the floor could be a bonding connection to water pipe or similar rather than an earth electrode. Useful to note that nothing you have tried seems to mitigate this mains borne interference on which is a very interesting topic. Rog |
28th Apr 2022, 1:49 pm | #28 | |
Re: Mains filtering
So I was able to isolate different parts of the house in order to locate the source of any interference. BTW, the vintage wireless under test and also the battery receiver used for this test are situated 'nearside' and not too far away from my desk that has my computer, printer, mains powered phone, mains powered USB hub etc on it. As stated, all of the aforementioned have ferrite clamps on their mains leads. This is what I found. Switching off the nearside sockets had the most drastic effect of reducing the interference. Switching off the far side sockets had a lesser effect. Strangely, switching off the upstairs lighting circuit (no lights on) also removed the higher frequency hash that was present and quite audible. I also lifted the battery receiver (Bush TR82) up to the vicinity of my long line AM aerial as it comes into the house and the noise very slightly increased.
28th Apr 2022, 2:09 pm | #29 | ||
Re: Mains filtering
I am assuming that you used the main isolator which switches the Phase & Neutral to each circuit in which case we can safely assume that the house wiring is re radiating the interference that must be coming in via the mains supply. That said, it would still be useful to switch all mains leccy off to your house in one go & retest. This would completely rule out any secondary interference from your "in house"' equipment. As John indicated his local mains supply is loaded with all sorts of interference so I reckon this is nigh on impossible to resolve apart from maybe's going off - grid ? Rog |
28th Apr 2022, 2:31 pm | #30 |
Re: Mains filtering
Roger, In the tests previously described I used the individual switches on the RCD units to isolate each circuit individually.
I just switched the 'main' incoming mains switch on the disty box to 'off' and it killed virtually all noise. I then took my trannie outside and moved it near to the house mains feed as it came up the outside of the house from underground. The increase in interference was massive. Anything I can do?! I already have those clip on ferrite clamps on the incoming cables - see previous photo - and that makes little if any difference.
28th Apr 2022, 3:39 pm | #31 | |
Re: Mains filtering
Switching off at the RCD only diss's the phase whilst the neutral remains connected). Switching off at the mains isolator diss's the phase & neutral which has clearly killed all interference. Sure you will agree that proves that your problem is not with the EARTH connection (as previously suggested) but solely with the incoming mains phase & neutral *on the proviso that your own home equipment is not adding. John has tried all sorts of filters already with no resolve so we may be on a hiding to nothing. Just for the hat though:- 1. The bolt on capacitors connected across the mains supply on washing machines were designed to reduce interference from the motor feeding back into the mains. You say dissing the lighting circuit led to a good improvement so in theory, it is possible that one of these connected across the lighting 5A mcb + neutral + earth within the consumer may give similar result in which case could then repeated on all other mcb circuits. EXTREME CAUTION - These would have to be fitted by a competent person and / or electrician. 2. I have seen large permanently running UPS units in computer server rooms that completely isolate's the raw mains but these would be a very expensive solution. Rog |
28th Apr 2022, 5:43 pm | #32 |
Re: Mains filtering
Thanks Roger. It's been an interesting exercise but I can't help but think that there is no cost effective solution to the digital hash problem that blights AM these days. I remember prior to digital TV I would equip my AM aerial leads with a croc clip and removing a shard of the outer plastic shrouding, clip them on to the coax of my TV download with truly excellent results. Not now! It's like feeding in a hurricane!
BTW, can you tell me a bit more about the bolt on caps, value etc? Thanks.
28th Apr 2022, 5:50 pm | #33 | |||
Re: Mains filtering
The PE (Phase to Earth impedance) was 58.5 Ohms and the mains supply voltage was 238 Volts which means the Prospective Fault Current would be 238/58.5 The PN (Phase to Neutral impedance) was 0.47 Ohms, that means the Prospective Short Current would be 238/0.47 The difference between the current displayed and that calculated is probably due to the tolerance specs of the tester. With all the appliances I could disconnect disconnected I plugged the tester in and those were the results I got. At the time I was after a maximum figure of 200 Ohms, which was mentioned in the regs at that time, a 1.2 metre rod wouldn't do it but a 2.4 metre rod brought it down to well below that figure as can been seen in the test display. https://martindale-electric.co.uk/pr...h-loop-tester/ Lawrence. |
28th Apr 2022, 6:01 pm | #34 |
Re: Mains filtering
Thanks Lawrence.
29th Apr 2022, 8:44 am | #35 |
Re: Mains filtering
In my personal opinion, unexplained Multiple-Letter Acronyms (MLAs) are discourteous at best - and a PiTA at worst 😉
Guy
"What a depressingly stupid machine." [Marvin: HHGTTG] |
29th Apr 2022, 9:03 am | #36 |
Re: Mains filtering
That would be fair comment but back in post #14 I linked to a Wikipage that explained all the MLA's and showed diagram of what they meant in practice.
I again suggested in post #20 this link was followed. https://en.wikipedia.org/wiki/Earthing_system The trouble is when there is good clear guidance so readily available do you spell it out bearing in mind how many of the members here know exactly what they mean already. If the page was deemed difficult to understand then that's when I feel explanations are in order. Google* is your friend. * Other search engines are available Cheers Mike T
29th Apr 2022, 9:20 am | #37 | |
Re: Mains filtering
RCBOs exist in both SP and DP versions. Obviously they sense the residual from both poles but switch only the line. MCBs are normally single pole in the UK, but there are SPSN types that sense the current only in the line but switch both poles. There are also DP MCBS. Last edited by Lucien Nunes; 29th Apr 2022 at 9:37 am. |
29th Apr 2022, 9:48 am | #38 | |
Re: Mains filtering
Rog |
29th Apr 2022, 9:55 am | #39 | ||
Re: Mains filtering
Rog |
29th Apr 2022, 12:51 pm | #40 | ||
Re: Mains filtering
