11th Apr 2022, 8:03 pm | #1 |
Malfunctioning B&D drill
I have an older Black & Decker hammer drill (1970s) that is not hammering anymore. Upon disassembly I found the "disc with cams" on the output shaft was spining freely on the shaft. I can't see how that would work? Am I missing something or am I right in that it was once press fitted to the shaft and now have come loose?
Picture A and B shows the position of said disc. On picture C I have lifted it off. Picture D shows the stationary counterpart that the disc is supposed to bounce against. |
11th Apr 2022, 8:22 pm | #2 |
Re: Malfunctioning B&D drill
Does this help? https://www.sparepartsworld.co.uk/browse/8562/4
Edit, https://www.sparepartsworld.co.uk/pr...D144R%2FTYPE_1 Im not sure which model but should think all very alike. John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 11th Apr 2022 at 8:37 pm. |
11th Apr 2022, 8:34 pm | #3 |
Sheared key with part remaining in shaft and part in the disc?
10th May 2022, 11:17 pm | #4 |
Thanks for your suggestions,
Unfortunately I could not find any remains of any broken key, even after taking it to work and checking it with microscope. Exploded view drawings shows disc and shaft as a solid part that is not supposed to be possibly to separate. I found a seller that sell this part but it not worth buying to an older, "standard quality" machine like this. I took this as an opportunity to buy a better drill. |
