18th Mar 2022, 9:46 am | #1 |
Table lamp rebuild - looking for suitable material.
Hi All,
We have re-discovered an old table lamp originally made by SWMBOs grandfather many years ago. It is a wooden sailboat design with lamp holder positioned such that the lamp itself was inside the large sail. These sails were made from a green, semi transparent plastic material. One surface had a sort of mottled texture to it, I think in an attempt to resemble the sheet material of a sail. It was quite thick, probably around 0.57mm and I would assume at some point a fairly flexible material. Try as I may, I cannot find any suitable replacement for this (Not helped by the fact I don't actually know what to search for). Unfortunately I do not have any of the original material as it went brittle and fell apart some years ago. If anyone could suggest something suitable to make replacement sails I would be most grateful. Heat from the lamp itself will not be so much of a factor as I intend to replace the lamp with an LED type when the thing is bought back into use. Thanks in advance. |
18th Mar 2022, 10:07 am | #2 |
Re: Table lamp rebuild - looking for suitable material.
Look in charity shops and car boots, something will surely crop up that would do the job.
18th Mar 2022, 10:14 am | #3 |
Kevin |
18th Mar 2022, 10:17 am | #4 |
Have a look in WHSmiths and similar places for document folders, holders and covers etc. They come in several different colours, textures and thicknesses. I found some material ideal for tuning scale diffusers.
18th Mar 2022, 10:42 am | #5 |
You can stiffen cotton fabric with dilute PVA
Peter |
18th Mar 2022, 11:02 am | #6 |
The original material is probably 'Parchment' It was a very common material in the manufacture of lamp shades. John.
18th Mar 2022, 11:21 am | #7 |
A "lampshade" collar used to stop dogs chewing stitches?
Stuart.
Half my stuff is junk - luckily, my wife doesn't know which half! |
