Old 18th May 2022, 9:50 am   #1
EdGizzard
Default Revox PR99 Keeps Blowing Fuse
Hi All,
My RevoxPR99 started giving me problems yesterday. It was suddenly jumping out of record mode. As the day wore on it started dropping out of record and also the counter display would go out. After turning on and off it could be put into record again and was fine for the rest of the day. Got the job done
Came in the morning to have a look at it and see if I could figure out what the issue. But now it will immediately blow a fuse when turned on. The fuse that blows is the empty fuse holder in the photo.
Any thoughts on what to test first would be greatly appreciated.
Many thanks
Ed
EdGizzard is offline
Old 18th May 2022, 12:26 pm   #2
Ted Kendall
Default Re: Revox PR99 Keeps Blowing Fuse
Could be the rectifier or smoothing on that circuit breaking down.
Ted Kendall is offline
Old 18th May 2022, 1:39 pm   #3
theredhouseinn
theredhouseinn's Avatar
That is the fuse for the 21v power supply to the electronics.
You have obviously got a short circuit on that line.
If you have an Avo meter check the resistance on the 21v line and fault find from there.
Suspect are the Fraco's and riva's caps. Ckeck the suppression cap across the mains input supply, it is behind the panel with the mains socket and fuse holder on it. If it has not been changed, it will blow eventually, and blow the mains fuse.
John.
theredhouseinn is offline
Old 18th May 2022, 5:23 pm   #4
Michael Maurice
Michael Maurice's Avatar
I have had the bridge rectifiers fail on these recorders. You have to remove the power transformer to get to it.
I suggest you also replaced the two 2200uF capacitors on the power board.
Whilst you are working on the machine, replace the Rifa capacitors, one on the capstan control board, the other across the mains (Located on the panel where the mains input socket and the fuse holder are located.
Forum Moderator
Michael Maurice is offline
Old 18th May 2022, 6:25 pm   #5
EdGizzard
Thanks Guys!! Fantastic advise.
Going to spend a day on it this week. I'll report back
Thanks again
Old 19th May 2022, 1:12 pm   #6
EdGizzard
Hi All,
I believe the problem is the rectifier connected to the fuse in question.
The test results below are taken with the rectifier still soldered to the PCB. MM in diode mode.
With + probe of MM on - of rectifier:
- to AC pin 1 - 001
- to AC pin 2 - 663
With - probe of MM on + of rectifier:
+ to AC 1 pin 1 - 663
+ to AC 2 pin 2 - 636
Same test on the other rectifier gives readings of around 650 throughout.
Markings on the original Rectifier are KBPC1-01 204. I was going to replace them with these. what do you think:
https://uk.rs-online.com/web/p/bridg...ifiers/7005478
For the two capacitors:
https://uk.rs-online.com/web/p/alumi...citors/1084992
Any thoughts on a good replacement for the RIFA cap? (0.47 uf150v 60Hz)
I tested the 3 caps behind the mains cable socket and they all appear ok.
Thanks so much guys.
Ed
Old 19th May 2022, 1:45 pm   #7
Restoration73
Restoration73's Avatar
In 2000, I bought an ex broadcast PR99MK3 for £500 - a bargain, I thought.
It worked fine the first time powered up, but the second time the fuse blew - yes it was
the bridge. I was able to replace it with the pcb in situ - I used a 200V version.
I would use a 105 degree type for the capacitor though rather than the 85 degree shown.
Restoration73 is online now
Old 19th May 2022, 3:03 pm   #8
EdGizzard
Dont think RS do a 200v version. Keen to use RS as i can get the parts by tomorrow. Have an account.
So was thinking of ordering these today:
and
https://uk.rs-online.com/web/p/alumi...citors/7111510
Do you think they will suffice?
Thanks guys
Old 20th May 2022, 7:49 pm   #9
Michael Maurice
I use these capacitors in the power supply. Far better than Jackson capacitors IMHO
Forum Moderator
Old 21st May 2022, 8:11 am   #10
DMcMahon
DMcMahon's Avatar
and
Thanks guys
Looking at the MK. II schematics, the bridge rectifier for the +21V supply (D2) appears to be identified as 35V/2A, so your RS item will be fine.
DMcMahon is online now
Old 27th May 2022, 3:30 pm   #11
EdGizzard
!!!!PR99 WORKING!!!!
Thanks so much everyone. Hardest part was getting the PCB out so I could change the components.
Ed
