Old 18th Oct 2021, 1:59 pm   #1
bionicmerlin
bionicmerlin's Avatar
Default Test panel
Picked this up on my travels. Can someone confirm what I’m thinking. It would be one of two things or both. Used behind a counter to test bulbs or appliances or used in a tv / radio workshop for plugging in customer repairs. As it has different size round pin sockets.
I think at one time it’s been modified with extra wood and the bottom and it has a hard board back . Not sure if the Bulgin plug socket has been added.
Even Rosie cant work it out.
I will restore it as some sockets are damaged. Not that I’m going to use it has neutral fuseing as well Andy
ID:	243665   Click image for larger version
ID:	243666   Click image for larger version
I bet that car doesn't have a suppressor.
bionicmerlin is offline
Old 18th Oct 2021, 2:18 pm   #2
Default Re: Test panel
"And for customers with a plug that doesn't fit we have live mains screw terminals" this leads me to think it isn't quite up to modern standards. Worth restoring even if it is a demonstration of how not to do it (these days).
Old 18th Oct 2021, 2:20 pm   #3
barrymagrec
Looks as if the Bulgin connector was the input.
My Dad made something similar, though not so well finished, when he repaired customer sets back in the fifties.
barrymagrec is offline
Old 18th Oct 2021, 9:03 pm   #4
duncanlowe
Doesn't look like the bulb testers we had at Woolies. Not enough bulb bases represented.
And more switches than connections? I could see it being to plug in customers devices, as some devices did connect via BC bulb bases. Could the plethora of switches be to reveres polarity / phase? Fuses in both legs also kind of push me towards it being DC era?
EDIT: that said, that's modernish plastic chocblock isn't it? And TBF the ply looks not that old. Some of the rebating has been done with a modern machine, I would say.
duncanlowe is offline
Old 20th Oct 2021, 8:50 am   #5
Brigham
I imagine anyone using a workbench would have made something like this.
Interesting that BS1363 isn't included. Makes me think that it's fairly recent, and for 'old' stuff. An enthusiast's board.
Brigham is offline
Old 20th Oct 2021, 8:44 pm   #6
bionicmerlin
Thanks for your thoughts everyone Andy
