Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Websites
Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest.
Old 16th Aug 2021, 4:55 pm   #1
M0FYA Andy
Default Virtual Valve Museum
Does anyone know what has happened to this website of CV-numbered valves? All I get is a warning of an 'unsafe site'.
https://www.valvecollector.uk
Andy
M0FYA Andy is offline
Old 16th Aug 2021, 5:08 pm   #2
GMB
GMB's Avatar
Default Re: Virtual Valve Museum
Works fine for me (assuming I am looking at the same thing).
You are probably being protected from accessing a web site that might be dangerously interesting, due to some issue with certificates (or lack of them).
When you see that stupid message try looking in the "advanced" bit for the details. It usually turns out that their certificate for HTTPS has just expired which I regard as a very minor security issue.
GMB is offline
Old 16th Aug 2021, 6:57 pm   #3
ThePillenwerfer
ThePillenwerfer's Avatar
If you're referring to what I've circled below it simply means the the site is using plain HTTP rather than the secure HTTPS protocol. Given that you'll only be viewing the site rather than entering any sensitive information into it I wouldn't (and don't) worry about it.
Name:	Screenshot at 2021-08-16 18-52-26.png
ThePillenwerfer is offline
Old 16th Aug 2021, 7:24 pm   #4
M0FYA Andy
It was still misbehaving when accessed via my favourites bar, using either IE or Firefox. Going via Google to find the address https://www.valvecollector.uk it worked fine, so I have deleted it as a favourite and replaced it and it now works as it should. Very odd!
Andy
Old 16th Aug 2021, 8:16 pm   #5
ms660
ms660's Avatar
Accessible here and showing secure site (padlock) seconds before I typed this message.
Lawrence.
ms660 is offline
Old 17th Aug 2021, 7:10 am   #6
JonSnell
JonSnell's Avatar
I get this when using FireFox as my browser, Safari gets upset and thinks I am an imbosile for trying to look at an "unsecure" site. This message can easily be placed in a list of trusted sites.
No idea about microsoft.
Name:	Screenshot 2021-08-17 at 07.06.36.png
Valve equipment repairs since 1968 https://jonsnell.co.uk
Last edited by Radio Wrangler; 17th Aug 2021 at 9:03 am. Reason: OS wars remark removed
JonSnell is offline
Old 17th Aug 2021, 8:48 am   #7
M0FYA Andy
I see that a couple of replies here mention the 'r-type' valve museum website; this is not the same valve museum as the one I was discussing.
Andy
Old 17th Aug 2021, 8:57 am   #8
Station X
Station X's Avatar
Perhaps you could supply a link to the valve museum you are discussing then.
Graham. Forum Moderator
Station X is offline
Old 17th Aug 2021, 9:46 am   #9
M0FYA Andy
Already done, see post #4.
Andy
Old 17th Aug 2021, 9:54 am   #10
Station X
Station X's Avatar
Edited into first post.
Old 17th Aug 2021, 10:30 am   #11
ms660
ms660's Avatar
Still ok here a few minutes ago.
Lawrence.
ms660 is offline
Old 17th Aug 2021, 10:39 am   #12
M0FYA Andy
As I said in post #4, it is also working OK for me now.
The problem was somehow associated with accessing it via my Favourites bar, but strangely using either IE or Firefox. Deleting it as a favourite and then re-entering the address cured the problem.
Andy
Old 17th Aug 2021, 11:00 am   #13
ms660
ms660's Avatar
That screen shot was taken using Windows 10/Edge, not used Firefox for years so can't comment on that.
Lawrence.
ms660 is offline
Old 17th Aug 2021, 11:54 am   #14
Jeremy M0RVB
Odd. The server is set up to redirect http to https on first contact so there should never be an issue. Apache sends a 301 redirect so the browser should immediately go to the https page, unless browsers are beginning to look into and whinge about redirections before redirecting...
Edit: a thought, I wonder if an old page has some http: references inside. I thought I had got all of them but I will have another look. That would / should cause a warning.
Jeremy M0RVB is offline
Old 17th Aug 2021, 8:55 pm   #15
whiskas
whiskas's Avatar
I use Brave most of the time and that site works just fine,...
...where on earth did that spring/screw go??
whiskas is offline
Old 25th Aug 2021, 9:36 am   #16
crackle
both links in #1 & #4 work for me.
Mike
crackle is offline
Old 2nd Sep 2021, 7:55 am   #17
JonSnell
JonSnell's Avatar
Firefox version 92.0 beta, has no issues. Safari Version 15.0 is also fine.
Firefox is downloading a newer version and has to restart so I will let you know in a few moments.
Firefox 92.0 full public version is also fine. Maybe the browser history needs clearing because it is looking for an out of date page.
JonSnell is offline
