4th Apr 2022, 9:29 pm | #41 |
Re: Bush Dual Standard Colour Restoration
My MK3 CTV25 had a knackered LOPT and i replaced it with a Decca Bradford LOPT which works well on both standards. I am using a tripler with an isolator capicitor on the input and have the PD500 connected up as normal. The beam limiter works well, being fed from the diode conection on the tripler.
Might be a more reliable way to go for you. Regards David |
15th Apr 2022, 3:59 pm | #42 |
If I had a Bradford LOPT that would certainly be a quicker way to do it, but I doubt it would be more reliable in the long run. The Mylar insulation I've used plus modern enamelled wire are both much more durable than anything that was in use in the 70s- especially as regards heat resilience. Plus of course . with a quadrupler, the LOPT is running 2kv lower than a Bradford with tripler Time will tell! Did you need to make any other circuit changes?
17th Apr 2022, 6:57 pm | #43 | |
18th Apr 2022, 2:13 pm | #44 |
Yes I was fascinated to see in a previous post (yours?) that the Bradford LOPT was designed for dual standard
18th Apr 2022, 3:57 pm | #45 |
If my memory is correct, the initial Decca Bradford chassis LOPT (the 10 series) was made by Mullard/Philips - possibly a variation of the AT2055 series. Later Bradford chassis LOPTs were made by the (then) Decca subsidiary Weyrad.
The AT2055 LOPT was, I think, also used in the ITT-KB CVC1 dual standard hand wired colour chassis. |
