15th Feb 2022, 9:52 pm | #1 |
Crack repair on Bush DAC90A cream cabinet
Hi. I have filled in a crack on a Bush DAC90A radio (cream cabinet). The Humbrol paint that I used was number 41 (gloss), but I still found it a bit lighter than the cabinet colour. What other Humbrol number paint would members suggest to tone it down to make it look the same as the cabinet (without total respray)?
Cheers Mike |
15th Feb 2022, 10:00 pm | #2 |
Re: Crack repair on Bush DAC90A cream cabinet
I find the only way is to mix paints to get the desired match.
Even then, it changes colour some after drying and ageing. I mix on an old CD case and hold it on the place you wish to paint, then leave it to dry and age for a good few days. Natural lighting is a must as I find many light sources tend to make things look quite different. It takes a bit of experimentation and a good memory of how many parts of one paint versus the other were mixed (or better good notes). Good luck |
16th Feb 2022, 11:08 am | #3 |
I found it extremely difficult to mix a pale grey using my large selection of Humbrol paints on clear plastic laid over the item to be painted. In the end, I just accepted what I achieved.
Rob
19th Feb 2022, 9:51 pm | #4 |
The problems I came up against when trying to touch up a crack in a cream DAC90A was that the cabinet is translucent and the colour is integral . Any paint applied sits on the top of the surface and stands out almost as bad as the crack.
The other problem is that (in my case) the crack had darkened due to the 'sooty' colour that covered the inside of the cabinet above the dropper. I tried to clean the soot and then tried to lighten it with neat bleach. This initially failed as the crack was so tight as not to absorb any cleaner or bleach. Finally I warmed the cracked area with a hair drier and then applied foam cleanser followed by bleach. This resulted in the crack becoming a lot less visible. I left it at that... Hope this helps. Rich
The rotation of the earth really makes my day... |
21st Feb 2022, 12:26 am | #5 | |
21st Feb 2022, 3:56 pm | #6 |
That is good news! I admit that the crack in my radio was very visible so you may have had more luck than me. Filling the crack with paint and then polishing with a cutting polish so only the crack is filled and there is no overpainting may be successful, the problem being that paint looks slightly different depending on the light. I have touched in repairs in the past that look fine inside then photograph them with a flash or take them into sunlight and they stand out terribly.
Hope you get it sorted. I would like to see a photo when you have concluded the repair if it turns out well. Rich
