16th May 2022, 11:53 am | #1 |
The James Knights Co. oscillator, 4.0 kc
Hello.
Last Saturday at the most pleasant open-air radio-electronics-only flea market held in Marzaglia (near Modena, Italy) I picked a circuit with a strange component. It is a tall metallic cylinder probably made in 1957 by The James Knights Co. Other labels say "avg temperature 57°C" and "thermostat 6.3V". I think it is an ovenised oscillator at 4.0 kc/kHz, but at the supposedly output pin I don't read a signal. The circuitry in the box is composed of a 7805 regulator and a transistor buffer on the output. If I power it up the tube heats up to <40 °C. I see a difference in current input in a cycle on-off of about 8 seconds per state. Four wires go to the socket: AC heater, GND, +5Vdc and a sort of 50 Hz drive signal. And one (silent) output. The oscillator may be broken, so I'll keep it as a novelty item or a hand warmer. But I wonder which application could have used an OC(X)O at 4.0 kHz. If I can get my eyes on a circuit diagram using a similar component I might find out if it has been (re)wired incorrectly. Thank you, Paolo PS: Marzaglia is held the 2nd Saturday of May and September. May is typically more crowded if you want to plan a trip (https://www.marzaglia.it/). |
16th May 2022, 2:14 pm | #2 |
Re: The James Knights Co. oscillator, 4.0 kc
Might that be an ovenised 4kHz resonator not a whole oscillator?
16th May 2022, 8:31 pm | #3 |
If it`s 1957 the7805 may not be an original component.....
16th May 2022, 9:34 pm | #4 |
Yes, the thing in the golden tube may well date from 1957 but the periperhal components in the green box look 1980s onwards and distinctly homebrew
17th May 2022, 2:12 pm | #5 |
Yes, it's indeed homebrew and it uses components that span some decades. By the way, I've never met a 7805 in that case (see pics).
I reversed the circuit around the transistor and it looks like an oscillator where the big tube is the resonator element, so Jon is right. Looking through the top hole with a strong light I see a small trimcap. Let's see if I can open the can without damages. Paolo |
17th May 2022, 2:35 pm | #6 |
Interesting.
The only thing I can think it might have been part of is some kind of Audio multiplex. One channel is at baseband, say 300Hz - 3.5kHz and the other channel is mixed up to 4.3 - 7.5kHz. Pye used to call theirs a 1+1. (PS I have had a 7805 in that package before) |
17th May 2022, 10:42 pm | #7 |
THe resonator could be any of a number of things.... A flexural-shear mode quartz bar, probably in an evacuated glass holder, maybe a quartz tuning fork in vacuo. or a metal tuning fork also in vacuo. Any of these would benefit from an ovened environment.
20th May 2022, 8:33 am | #8 |
I had to see the resonator and I found a surprise. A previous owner has replaced the original innards with a 10'000 kc/s XTAL oscillator, so he got an ovenised XO. Well, I might try crystal grinding to put it on 30m HAM band. I did measure once a 10 MHz output, but discarded it as noise and never appeared again in later tests, probably due to loose contacts inside the tube.
The curiosity remains on which device used a 4 kc OXO in 1957. Thanks for reading and contributing! |
