Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 4th Dec 2021, 9:22 am   #1
Electronpusher0
Default Search problems (No of characters?)
I am having a problem with the search function of the forum.
I wanted to find out how much AVO 8s are offered for on the forum so went advanced search for AVO 8 in items offered but got no results
I did a bit of experimenting and found that 3 letter words such as AVO or VCM return no results.
AVO 8 (with a space) also returns no results however AVO8 does
Is the search limited to words of 4 letters or above?
Peter
Electronpusher0 is offline
Old 4th Dec 2021, 10:36 am   #2
Default Re: Search problems (No of characters?)
The forum search facility requires a minimum of four characters in a word so "Pye" and "AVO" won't work.
The answer is to use the Google Custom Search box at the top centre of every forum page.
The first few results returned will be adverts, but after that you'll see forum specific stuff.
Station X is online now
Old 4th Dec 2021, 5:00 pm   #3
Paul Stenning
Administrator
Paul Stenning's Avatar
The forum search has always been limited to 4 characters, due to the database structure etc of the old forum software we use. As Graham says, the Google Custom Search gives better results in cases like this (which is why it was added some time ago).
Paul Stenning
Paul Stenning is online now
Old 12th Apr 2022, 3:06 pm   #4
Julesomega
Julesomega's Avatar
I've never had any joy using the onboard Search facility, and there's no point using the Google search for 'Modern equipment' as Google has yet to make 10 posts
Even though I limit the search to 4 characters (not words), e.g. "DAB" and play about with the advanced search specifying the modern equipment forum, even posts by Julesomega, nothing happens. Am I missing something?
- Julian
It's good here
Julesomega is offline
Old 12th Apr 2022, 3:44 pm   #5
Dave Moll
Dave Moll's Avatar
The other point to note with the embedded search facility is that multiple search words separated by spaces give results that contain ANY of the words. I'm not sure whether there's a way to show only results that contain ALL the search words.
For instance, a search for "Avometer eight" would return all posts containing "Avometer" AND all posts containing "eight", not just those containing "Avometer eight".
Dave Moll is offline
Old 12th Apr 2022, 7:22 pm   #6
Reelman
Reelman's Avatar
I’ve noticed this as well. Is there a way to search for threads containing ALL the search words? I’ve tried different punctuation to no avail.
Thanks,
Peter
Reelman is offline
Old 12th Apr 2022, 11:27 pm   #7
frsimen
Using the search string:
Avometer AND eight
Will only show results with both Avometer and eight.
"Avometer eight" will return results which have the exact match for Avometer eight.
Avometer OR eight will return results with either of the search words.
Paula
frsimen is offline
Old 13th Apr 2022, 12:12 am   #8
SiriusHardware
Another trick which works with the internal search engine and most other search engines is to put a specific phrase inside quotes, for example "Avometer 8 spares", will only return results containing the exact phrase in the quotes.
And if you really want to search for a word which is shorter than four letters, try entering
Avo OR Avo
The search engine isn't smart enough to realise both words are the same, so it will return all results containing Avo. (I've just tried it).
SiriusHardware is online now
Old 13th Apr 2022, 8:17 am   #9
Dave Moll
Dave Moll's Avatar
I thought I had previously tried the "and" trick (as well as the quoted string) without success, but I'll try again next time I do a search.
Old 13th Apr 2022, 8:34 am   #10
Dave Moll
Dave Moll's Avatar
For the purposes of another thread, I wanted to find a thread mentioning both Aurora and Hedghog standards converters, so I searched for Aurora AND Hedghog - which brought up results NOT containing both words.
Old 13th Apr 2022, 12:27 pm   #11
Julesomega
Julesomega's Avatar
I limit the search to 4 characters (not words) and always get 0 results, However, if I put more than 2 words I get 500 pages of results
- Julian
It's good here
Old 13th Apr 2022, 1:52 pm   #12
Paul Stenning
Administrator
The built-in forum search seems to be an OR search only, in that it will find threads containing any of the words you enter rather than all the words you enter. Keywords like AND don't have any effect.
If you want to search for more than one word go to Advanced Search and sort by relevancy, descending rather than by date. Posts containing all the words are more relevant so should appear first.
The limited documentation in the FAQ doesn't give any other options either, so that is probably just how it is and I doubt much can be done about it.
Today's database update should allow searching on three letter words such as Pye and AVO but won't help with anything else.
This is why we also have the Google search box. Google do website searching vastly better than any code here could, but it only covers sections that are visible when not logged in.
Paul Stenning
Old 13th Apr 2022, 2:34 pm   #13
Paul Stenning
Administrator
Searching for three character words seems to work now. It is quite slow though.
Paul Stenning
Old 13th Apr 2022, 4:43 pm   #14
frsimen
I should have said earlier that my comments were intended for use with the Google search. That does seem to give more than you would expect with a search of Aurora AND hedghog. The odd (but correct in this context) spelling of hedghog seems to be the cause.
Searching instead for:
aurora AND "hedghog" seems only to return what would be expected. However, it doesn't pick up the many threads with "hedgehog" also relating to the aurora product.
To pick up both hedghog and hedgehog, a search for:
aurora AND "hedghog" OR hedgehog
seems to work from the forum, but probably won't be much use as a general Google search!
frsimen is offline
Old 13th Apr 2022, 6:02 pm   #15
Aub
Aub's Avatar
As an aside to this and i think i've asked this question before, but can't remember the answer, why is it that, under advanced search ( not Google ) I can only see posts of mine going back to Jan 2016?
Thanks
Aub
Life's a long song, but the tune ends too soon for us all.
Aub is online now
Old 13th Apr 2022, 6:21 pm   #16
Cobaltblue
Cobaltblue's Avatar
Thanks
Aub
I think its a limit in how many results the search engine can show.
If you do a search only for threads started by you as opposed to all threads, the number of results is much lower and it does go all the way back to 2006.
Again if you do a search for all your posts but in the domestic Radio section it goes back to 2007
Hope that helps
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 13th Apr 2022, 7:06 pm   #17
Aub
Aub's Avatar
Mike, thanks very much for the explanation.
Aub
Aub is online now
Old 13th Apr 2022, 7:52 pm   #18
Paul Stenning
Administrator
As Mike says, there is a limit of 500 posts in the search results and they are sorted by whatever you choose (default is date descending) which would explain why you only see some results.
Paul Stenning
