27th Nov 2019, 3:43 pm | #1 |
What's this Baird?
Hi
My colleague's been offered this and was wondering if it was fully dual standard. I don't think so, but I'd be interested in knowing the model number - possibly a 620? |
27th Nov 2019, 3:46 pm | #2 |
Re: What's this Baird?
Is that a model number visible at the aerial input panel?
27th Nov 2019, 4:03 pm | #3 |
Could be, but we don't actually have the TV, just the photos.
27th Nov 2019, 4:17 pm | #4 |
I have only seen a couple of this type of Baird but It looks like an unconverted set.
I think the UHF tuner fits where the blanking plug is just above the VHF tuner. I can't see if the UHF aerial socket is fitted or blanked off from the picture. But as there is no visible UHF tuner knob I would think there is no tuner fitted. If it is a convertible set I wonder how it switched systems as there isn't a system switch visible either maybe a U position on the VHF tuner similar to some Thorn sets with solenoid switching? A nice set though and probably quite rare... Rich |
27th Nov 2019, 4:58 pm | #5 |
The system switch goes over when the VHF tuner is on the U position,no solenoids
involved,we had the Uhf tuner 23" version for some years. |
27th Nov 2019, 5:57 pm | #6 |
One of those was our family telly for many years.
It came as a purely 405 line set, and only later was fitted with the UHF tuner and a few other bits to enable 625 lines and BBC2. I was there at the time, it seemed to take about 20 mins to convert the set, and a bit longer to fit a second aerial and feeder. The VHF tuner was a turret job and had a 'U' position as already said, which flipped the system switch to 625. The UHF tuner was free rotating with a ball drive. The transparent knob had a slower moving scale underneath it. We were watching one of these sets when Emley moor mast fell and our UHF picture vanished. David
27th Nov 2019, 5:57 pm | #7 |
27th Nov 2019, 6:05 pm | #8 |
27th Nov 2019, 7:00 pm | #9 |
This series of sets was not bad performance-wise and is fairly easy to work on as well, i have the dual standard version. The UHF tuner drive setup however is the worst piece of stupid and over-complex design I have ever come across: it uses no less than two rubber friction washers, which either develop "flats" or just shrivel up, and an excessively complex string drive for the slow motion part. I think at least another make had a similarly awful design, possibly Pye. I can only assume it was a particularly "bad hair" day for the designer(s) or that they just bore the world a grudge!
Nice looking set Glyn, go for it!
Robert |
27th Nov 2019, 7:02 pm | #10 |
Yes, it is a Baird M646. I had one a few years ago and that didn't have the rotary valve UHF tuner unit fitted either.
It's an all valve set, circa 1963/4. CRT type AW59-91. However, in my set, a 660 series main chassis (transistorised IF stages) had been fitted into the set, retaining the original front control panel assembly. Very nice dark wood cabinet with folding doors and screw-in legs. Gave a cracking picture after a good 23" Mullard CRT fitted and many components replaced. Last edited by dazzlevision; 27th Nov 2019 at 7:08 pm. |
27th Nov 2019, 8:58 pm | #11 |
its complete with what look like original legs! they often got taken off or lost/ broken
28th Nov 2019, 10:33 pm | #12 |
Those legs are back in fashion! Just look at the TV ads for furniture. Screw-in tapered wooden legs on chairs, sofas, and sideboards but unlikely to be seen on Television sets ever again. What goes around, comes around...
