Old 27th Nov 2020, 11:05 am   #1
Mark Trotman
Default Panasonic NV-F70B owners manual needed
Hi
Has anyone still got the above manual as I need to tune the channels. I cannot find one anywhere for the b model or if someone knows the tuning procedure I would really appreciate that.
Thanks
Mark
Mark Trotman is offline
Old 27th Nov 2020, 11:17 am   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Panasonic nv-f70b owners manual needed
There might and I have not looked be one on the NatPan site.
HamishBoxer is offline
Old 27th Nov 2020, 11:25 am   #3
ben
ben's Avatar
You won't be able to tune the channels as there are no analogue TV signals being transmitted (and this unit has no digital tuner)- or have I misunderstood you?
Regards,
Ben.
ben is offline
Old 27th Nov 2020, 11:38 am   #4
Mark Trotman
I have a digital to analogue Goodmans Freeview box that gives a analog signal to tuner
Old 27th Nov 2020, 11:47 am   #5
Mark Trotman
Thank you all managed to find a 65b manual which is similar.
Old 27th Nov 2020, 11:52 am   #6
patrickgnl
The attached is from the F77B if it helps....
patrickgnl is offline
Old 27th Nov 2020, 12:30 pm   #7
Mark Trotman
Thank you ��
Old 27th Nov 2020, 1:03 pm   #8
John123
Unless it's just for experimentation purposes, the standard procedure would be to bypass the tuner and hook up the Freeview box direct to the (recorder's) A/V input. At least that way you can take advantage of Hi-Fi stereo recordings, and with a slightly improved picture..
Regards,
John
John123 is online now
Old 27th Nov 2020, 2:39 pm   #9
Mark Trotman
Thank you ��
Old 27th Nov 2020, 2:59 pm   #10
Mark Trotman
Default Re: Panasonic NV-F70B owners manual needed
I have tried various ways of connecting the vcr to my Sony oled Tv with little success. I have hdmi ports and a 3.5 mn video/sound av port. I bought a scart to hdmi box which was rubbish, 3.5 mm to 3 analog jacks into scart plug which was also unsuccessful. The Tv will accept analog tuner inputs and this is how the vcr is connected now. On back of vcr is rf, sound jacks and a bnc for video. Can I put a bnc to av plug adapter and try this through av input on tv?
Old 27th Nov 2020, 8:31 pm   #11
John123
Try testing the TV's A/V port with another device. You should be able to get it to work so long as the breakout cable is the correct one for the TV. Most likely you will have to manually change over to the A/V input via the TV's remote control.
Again, it should be relatively easy to hook up using a SCART to A/V break-out cable, or a SCART to RCA adaptor (on the Freeview box side), wired to the recorder's respective Video and Audio In sockets (select A/V input to receive). Same with the TV side.
Regards,
John
Old 27th Nov 2020, 10:26 pm   #12
Mark Trotman
Thanks, have looked up the TV manual and it shows a different 3.5mm pin arrangement!! Trust Sony
Thanks again
