19th Nov 2020, 2:15 pm | #1 |
3” screen 405 line portable Tv
Waiting on pictures as it is some distance from me but this TV has just surfaced.
3” screen 405 line portable unused still in it’s original packaging with all paperwork. An uncle has it but could not remember the make when I spoke to him yesterday, hopefully he will email pics today. |
19th Nov 2020, 2:30 pm | #2 |
Re: 3” screen 405 line portable Tv
The only one I've seen is 625 but vhf and uhf;
https://www.radiomuseum.org/r/standard_sr_tv3ac.html |
20th Nov 2020, 7:34 pm | #3 |
Hi.
I've never been aware of a commercially built three inch portable for 405 Lines. I'm just thinking it's a VHF/UHF set for only 625 lines, for use in UK and Eire.
20th Nov 2020, 8:44 pm | #4 |
After having been told it was a 405 line unit it turns out to be a 625 line Citizen ST955 pocket 2.2" LCD colour TV.
Never been used or had any batteries in it. |
20th Nov 2020, 9:46 pm | #5 |
20th Nov 2020, 9:53 pm | #6 |
I have a Sinclair leaflet from the second half of the 1960s advertising their first Microvision TV, which (IIRC) was for the VHF/405 standard. Of course, it may never have gone into commercial production.....
20th Nov 2020, 10:19 pm | #7 |
I have a rather similar Casio TV 3500 that covers UHF and VHF but unfortunately its VHF Channel 1 doesn't tune low enough for UK VHF Channel 1
Peter |
21st Nov 2020, 12:21 pm | #8 |
Hi Peter.
You could try BBC on channel 3 from Kirk o Shotts
21st Nov 2020, 12:26 pm | #9 |
Did anyone modify the Pilot TV37 for 405 lines?
Receiver has an electrostatic deflection CRT so no difficulties modifying the timebases for 405/50. https://www.radiomuseum.org/r/pilot_candid_tv_tv37.html DFWB. |
21st Nov 2020, 1:39 pm | #10 |
Wouldn't there be problems with it expecting the system parameters for 625 e.g. FM intercarrier sound, negative video modulation etc?
21st Nov 2020, 1:52 pm | #11 | |
Peter |
21st Nov 2020, 2:32 pm | #12 |
Here's the leaflet:
21st Nov 2020, 5:23 pm | #13 |
Hi.
The original sinclair microvision never was released. Here is an article with more information. http://rk.nvg.ntnu.no/sinclair/televisions/tv1a.htm
21st Nov 2020, 6:29 pm | #14 |
I had a TV1A, it is now residing at the Dulwich museum.
21st Nov 2020, 7:20 pm | #15 |
I had a Mon 1A, very useful at the time for just checking for the presence of baseband video. It meant that I could quickly check & identify video sources, without lugging around a large mains-powered video monitor.
With a magnifier, you could just about read printed text! I seem to recall that the battery consumption was quite high. Dave. |
23rd Nov 2020, 3:13 pm | #16 |
"... It functioned on VHF and UHF bands and was the first-ever multi-standard receiver, which meant that it could be used in nearly every foreign country as long as the country used one of the three major TV standards..."
More specifically; which standards? |
23rd Nov 2020, 6:36 pm | #17 |
Hi to all,
Hi Brigham, It worked on : - USA, M standard, 525, FM audio, 4.5 MHz - Europe, B/G standard, 625, FM audio, 5.5 MHz - UK, I standard, 625, FM audio, 6.0 MHz Best Regards jhalphen |
24th Nov 2020, 12:07 am | #18 | |
"VHF" System A "UHF" System I Both in System I, VHF Both unlatched System A, UHF Two nice undocumented features! The fact that the 9-90 dual standard set and not merely dual band is not obvious unless you actually RTFM.
-- Graham. G3ZVT Last edited by Graham G3ZVT; 24th Nov 2020 at 12:28 am. |
24th Nov 2020, 2:53 pm | #19 | |
At the time I had noticed the feature Rambo mentions. (Actually I think you'll find it works the other way round.) During one idle moment during a Trade Test Transmission I wondered if the complete 625-line UHF chain would handle a 405-line signal. So I pushed both buttons in on the Sony, which now was primed to display a 405-line picture on UHF, and went back to the Mixer Desk, where I selected 405-line Test Card D as a source. Then I 'punched it up' through the mixer. It all worked perfectly! 405 on Ch 33 UHF from CP (and all the other national transmitters). I only risked leaving it for a couple of seconds though, otherwise alarm calls would have started coming in. Possibly also 'calls' on my job! Steve
https://www.radiocraft.co.uk |
25th Nov 2020, 9:36 am | #20 |
About 30 years back I was using a TV9-90 for DX on vhf/625, where the -ve video
demodulator output is used. I had noticed some strong signals with inverted video. Using a simple spdt switch I was able to switch to the +ve video demodulator and view these signals which were in fact Canal+ from the transmitter in Corsica. |
