6th May 2020, 10:13 pm | #41 |
Re: Fixing a GEC BT 330 Television
I said to bridge F2 fuseholder because I assumed it was the blown fuse you mentioned back in post #1.
You MAY have to bridge the contacts of the mains switch ie S1 and S2 if they test open circuit. Don't bridge L and N or there'll be a big bang should you plug the set in.
6th May 2020, 10:26 pm | #42 |
Thats what i thought. it blow. dont worry I didn't do that. Yes ill bridge the fuse. Thanks lol
6th May 2020, 10:34 pm | #43 |
I do have lots of spare fused but they are the modern 3 amp the TV takes 1.2 amp I believe
6th May 2020, 11:06 pm | #44 |
will 3 amp do damage?
6th May 2020, 11:08 pm | #45 |
Hi!
Servicing articles for your chassis are here:– https://www.americanradiohistory.com...on-1972-01.pdf https://www.americanradiohistory.com...on-1972-02.pdf . . . altho' the articles are entitled "BT302 Series" all the circuit references, valve types, etc., are the same as your set! If you're not getting any of the valves lighting I would switch off the set, unplug it from the mains and begin by measuring across the plug pins for a continuity reading, which should be about 150–250 ohms with all the valves cold. No readings could be a blown fuse, a section of the "mains tapping unit" open circuit, or a valve with an open–circuit heater, and I should make you aware the receiver valves, which are Z329 or 30F5, have 7.3V 0.3A heaters and these valves did have a nasty tendency to be unreliable with regular heater failures, so do check all of these for continuity between pins 4 and 5. Fuse–blowing at switch–on may be the mains filter capacitor, or if you've removed this, a short across the h.t. line, very tricky to find unless you're experienced with TV faults! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 6th May 2020 at 11:24 pm. |
6th May 2020, 11:13 pm | #46 |
Thank you so much Ill print them out tomorrow.
7th May 2020, 3:42 pm | #47 | |
For testing purposes WITH NO MAINS POWER APPLIED you can fit any good fuse you like, or even bridge out the fuseholder. The same applies to the fuse in the mains plug.
7th May 2020, 7:36 pm | #48 |
Thanks again so you think i should fire up and see what happens ?
7th May 2020, 8:37 pm | #49 |
NO!. Do not apply power at present.
Let's take this in very small steps. Test F2 and the fuse in the mains plug and come back with the results.
7th May 2020, 8:49 pm | #50 |
Ok no problem im on it
7th May 2020, 9:07 pm | #51 |
F2 Im assuming you mean fuse 2 ?
7th May 2020, 9:13 pm | #52 |
There is no plug on set as I have removed it the fuse is good
7th May 2020, 9:26 pm | #53 |
7th May 2020, 9:26 pm | #54 |
Which fuse is good?
7th May 2020, 10:01 pm | #55 |
All fuses are good
7th May 2020, 10:08 pm | #56 |
Fit F2 and go back to post #35.
7th May 2020, 10:19 pm | #57 |
Hi when you get a chance to change more capacitors, you might want to replace the black Hunt ones as they will be pretty terrible by now.
8th May 2020, 10:49 am | #58 |
OK I will do that that.
8th May 2020, 11:31 am | #59 |
do you think I should change them all ?
8th May 2020, 11:41 am | #60 |
At some point.
Best to replace the ones likely to cause damage/burn ups then head for first light (some sort of raster displayed) and take it from there. No point in spending lot's of time effort money etc then switch on only to find an unrepairable/unobtainable part is duff such as a transformer or CRT. Lawrence. |
