Old 6th May 2020, 7:25 pm   #21
deepspacedaz
deepspacedaz's Avatar
Default Re: Fixing a GEC BT 330 Television
do you mean in condunity test, is circuit working ?
deepspacedaz is offline
Old 6th May 2020, 7:26 pm   #22
deepspacedaz
I have diagrams and scematics if that's what you mean
Old 6th May 2020, 7:36 pm   #23
deepspacedaz
I've removed the compacitor
Old 6th May 2020, 7:43 pm   #24
Station X
Station X's Avatar
Can you post the portion of the circuit diagram showing the heater chain please.
I've never repaired or restored a vintage TV in my life, but there's a certain commonality between their circuits.
In my opinion you're not going to be able to fix this TV simply by asking questions on here and responding to the answers. You need to do some reading on TV circuit theory.
Graham. Forum Moderator
Station X is online now
Old 6th May 2020, 7:45 pm   #25
dazzlevision
Originally Posted by deepspacedaz View Post
Did you want to see a pic of the capacitor
No need, it will be faulty!
dazzlevision is online now
Old 6th May 2020, 7:48 pm   #26
deepspacedaz
I dont know if the same message is sending it playing up. I ve removed the compaitor
Old 6th May 2020, 7:53 pm   #27
deepspacedaz
Here is the schematic. Also I am researching at the same time
Old 6th May 2020, 7:55 pm   #28
Station X
Station X's Avatar
That's the component layout. What we need is the circuit at a decent size.
Old 6th May 2020, 7:56 pm   #29
deepspacedaz
Sorry sent the wrong one.
here they are
ID:	205112   Click image for larger version
ID:	205113   Click image for larger version
Old 6th May 2020, 8:04 pm   #30
Chris55000
Hi!
I do have my doubts as to whether the OP ought to be attempting an old TV of the 405–line live–chassis type – there were many "quirks" and complex portions of circuitry in quite unambitious receivers of this age that caught many experienced engineers out – my recommendation is he puts a request in the appropriate thread for assistance!
Certainly myself or many other Members could give a step–by–step guide but I think it would be too complex for the OP to follow – he posted.a component–layout diagram when asked about the circuit, leaving me in some doubt as to whether he can recognize and understand a circuit diagram and pick out the appropriate parts of it.
Chris Williams
PS
What makes matters worse is that virtually all of the so called "TV Fault Finding/Troubleshooting" books online relate entirely to American 525 line only sets with their totally different mains voltage, scan and signal frequencies, etc., & and not one of these books are of help to the OP!
The best tip I can recommend is to get the set of four "TV Theory and Servicing" books by G.N. Patchett – these are free from the Internet Archive, and begin by reading through Volumes 2 and 4 as a starting point.
Chris55000 is offline
Old 6th May 2020, 8:14 pm   #31
deepspacedaz
Here we go. this may help
Old 6th May 2020, 9:19 pm   #32
Station X
Station X's Avatar
The diagrams are a bit unclear, but as far as I can see you've snipped out C155 which is wired across the mains. The set will work without it.
The heater chain runs:- mains - F2 - S2 - R79 - R78 - R76 - R75 - V12 - V13---------V8 - CRT - chassis - S1 - mains.
You need to check continuity round this chain using your meter on a resistance range. You will of course need to bridge F2's holder when you do this.
As a short cut you could check that you have continuity between the L and N pins of the mains plug and that the reading changes if you remove a valve
The trouble is that, even if the chain has continuity, any of the capacitors from the heater chain to chassis could be short-circuit. This will cause some valves to light, but not others and may apply excess voltage to those valves which do light up. You really need to change all these caps.
Old 6th May 2020, 9:30 pm   #33
deepspacedaz
Thanks Ill do that now
Old 6th May 2020, 9:52 pm   #34
deepspacedaz
Hello done the test. Nothing there just read 1
Old 6th May 2020, 9:54 pm   #35
Station X
Station X's Avatar
I assume that "1" on your meter denotes an open circuit? It's what you'd see with the leads not touching. With the leads touching you should see a low reading. If the heater chain is open circuit you'll have to test round the chain to see where the break is, I assume that any fuse in the mains plug was good, the mains switch was in the ON position and F2 bridged?
Old 6th May 2020, 9:59 pm   #36
deepspacedaz
yes. It was bridged and on. ill recheck. then do the full test
Old 6th May 2020, 10:02 pm   #37
Station X
Station X's Avatar
OK. we'll await results.
After a long period of disuse the contacts in the mains switch may not be making correctly. If that's the case temporarily bridge them.
Old 6th May 2020, 10:06 pm   #38
deepspacedaz
Oh no sorry, it wasn't bridged where is F2 Located, please ?
Old 6th May 2020, 10:08 pm   #39
Station X
Station X's Avatar
I've no idea. You'll have to look for it in the component layout drawings.
Old 6th May 2020, 10:09 pm   #40
deepspacedaz
Do you mean bridge NL ?
