Old 16th May 2020, 6:26 pm   #181
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Fixing a GEC BT 302 Television
V9 in place of V15. V15 is above the B729 [the taller one]
Heatercathodeshort is offline
Old 16th May 2020, 6:31 pm   #182
Heatercathodeshort
Do you get any sound at all from the speaker. Slight hum? Buzz? or is it completely silent as if the receiver was switched off?
Old 16th May 2020, 6:49 pm   #183
deepspacedaz
deepspacedaz's Avatar
I think i can hear a bit OF A BUZZ, The line is a bit wider vertically now
deepspacedaz is offline
Old 16th May 2020, 7:07 pm   #184
Heatercathodeshort
OK. Can you now get any disturbance of the line on the screen when you rotate the tuner through it's channels? You should also get clicks from the speaker.
Are you sure the tuner valves are in the correct sockets? You can slip the cans off and post a pic if possible.
Is the brightness on full?
Old 16th May 2020, 7:12 pm   #185
Heatercathodeshort
Does the height control have any effect on the height of the line?
Old 16th May 2020, 7:15 pm   #186
deepspacedaz
The brightness is on full I get disturbance when I go through channels
Old 16th May 2020, 7:17 pm   #187
deepspacedaz
Here are the tuner valves
Old 16th May 2020, 7:18 pm   #188
deepspacedaz
here are the tuner valves
Old 16th May 2020, 7:35 pm   #189
Heatercathodeshort
That is the IF board Daz. The tuner valves are mounted on the tuner itself. Leave them alone as the disturbance proves they are probably working.
Ok, just maybe a little progress.
We must get the frame timebase to work correctly. Is the brightness on full and does the height control or the frame form control just above it have any effect on the size of the line?
Old 16th May 2020, 7:37 pm   #190
deepspacedaz
Sorry i sent the wrong picture
Old 16th May 2020, 7:38 pm   #191
deepspacedaz
Yes it has effect on the line
Old 16th May 2020, 7:41 pm   #192
deepspacedaz
Heres the speaker
Old 16th May 2020, 7:49 pm   #193
Heatercathodeshort
Daz, What effect does it have? Does it increase the height, if so how much? Is the brightness control on full?
Old 16th May 2020, 7:57 pm   #194
deepspacedaz
Brightness is on full and really bright
Old 16th May 2020, 7:58 pm   #195
deepspacedaz
Does not increase height much
Old 16th May 2020, 8:00 pm   #196
Heatercathodeshort
The good thing is that we have at least got some EHT and a limited frame scan. The problem appears to be that it is very dim. A frame collapse should give a bright if not blinding line of light on the tube. Your very dim results show that the tube is almost certainly very low emission and any picture displayed would be very dim indeed requiring the room lights out to see anything at all.
The second problem is that you are going to have to spend a bit of money replacing all the black Hunts capacitors on the timebase panel at least to get even that far.The IF panel will also require a complete overhaul.
You will also need a 405 line signal source to be able to use the TV for any purpose.
It's time to decide how further you want to go with it and quite frankly I don't think it's going to be a viable proposition with the weak tube in mind.
At least we have reached this point without you having to spend what could be a large sum of money on components and equipment just to discover it's all in vain.
Have a think about it. Regards, John.
Old 16th May 2020, 8:10 pm   #197
deepspacedaz
its very bright on the screen just a line
Old 16th May 2020, 8:27 pm   #198
deepspacedaz
So what next mate ?
Old 16th May 2020, 8:32 pm   #199
Heatercathodeshort
Daz, I have asked you several times if the brightness is on full but no answer. It's all a matter of distance. Matlock is a long way from West Sussex.
You need 'hands on' experience to get this working. We have all tried to help but it is so difficult at a distance. Maybe someone nearer to you is willing to take on the challenge.
TV servicing could be described as an art. I have been repairing TV receivers [and just about everything else] since I was 11 years old, that was 1960! You never learn it all and I still come up with mind benders today. Regards, John.
Old 16th May 2020, 8:35 pm   #200
deepspacedaz
You must of missed my comment yes brightness is all the way up
