28th Nov 2021, 2:57 pm | #1 |
Radio New Zealand Short Wave
Hello all. I was somewhat surprised yesterday to pick up Radio New Zealand on my Mullard MAS281/15 (masquerading inside a Philips 170A bakelite cabinet). I received the transmission in the 41m band at 16:30 GMT using a 30ft long-wire. Reception was poor but partly intelligible. I looked up the station on the Web and found this link https://www.rnz.co.nz/international/listen confirming a transmission on Saturdays on 7390 kHz. A pleasant surprise since there aren't many decent AM shortwave stations left on air. Jerry
28th Nov 2021, 3:32 pm | #2 |
Re: Radio New Zealand Short Wave
I'm surprised you were getting reception from a transmitter in the Pacific using such modest equipment. When I first read your post I assumed you were hearing a relay located somewhere much closer, but your link suggests not. Well done!
28th Nov 2021, 5:04 pm | #3 |
If conditions are favourable at the time, it is surprising what can be heard. When I used to do a lot of SWL'ing I remember hearing Australia using nothing more than the built-in whip aerial. I think it was during an 'opening' when 10 metres was unusually active. All sorts of obscure amateurs as well coming in.
28th Nov 2021, 5:42 pm | #4 |
Many moons ago I got Radio Australia on an Icom 720 with about a foot of wire stuck in the aerial socket. Led to a few brownie points as the girlfriend at the time was Australian. And HCJB Ecuador on the same radio with a similar "aerial". I must give Radio New Zealand a go.
28th Nov 2021, 6:31 pm | #5 |
Hi Jerry,
Just been having a listen to the news on 7390kHz. Using an FT857 and a home made 90cm magloop in the shack. I have been a listener since the 1950s, but I must confess I haven't ever received RNZ before. I suppose it's because I didn't look for it. Kind regards Dave G0ELJ |
28th Nov 2021, 11:28 pm | #6 |
Yes, those were the days. I became more seriously interested as an SWL in the mid 1960s. I was given a CR100 (actually an ex-RN B28) communications receiver which opened up a whole new world, including amateurs on SSB. Trouble was I needed a crane to lift it. It ran faultlessly for years until one of the screen decouplers went s/c. Somehow I managed to wield my Henley Solon 25W iron into the depths of the coil box and replace it. The receiver went into retirement during my college days and after getting married it sat in the back of the garage for years until eventually I fired it up and it still worked. I sold it in a BVWS auction in Harpenden I think. Jerry
29th Nov 2021, 12:22 am | #7 |
There's still the occasional satisfyingly interesting catch to be found in between the innumerable China and Romania sledgehammers, it makes it worth twiddling around the bands even now.
29th Nov 2021, 9:05 am | #8 |
Hello Jerry,
Try 11725kHz in the morning too if the Mullard has the 25m band....Radio New Zealand has been a fine strong signal here in Bucks on most days this month peaking around 10AM but audible from before 8AM until after midday. It is a nice clear frequency. All good fun. Rupert |
29th Nov 2021, 11:01 am | #9 |
I have occasionally heard Radio New Zealand on my shortwave radios just using there built in telescopic rod aerial.
I will have to give 11725Khz a go when I am next off work.
Simon BVWS member |
4th Dec 2021, 1:16 pm | #10 |
Well, I'm absolutely amazed!
Never thought for one minute I would pick it up, but after reading this Thread, I thought it would be worth a try. Spun the Dial round on my Kenwood TS440 to 11.725 Mhz and there it was! Ok, very low in the Noise but remarkably stable over several Hours. I found fine tuning it in on SSB a great improvement because of the noise. Took a while to definately identify it as RNZ pacific though. My Antenna wasn't helping, as I only had a 28Mhz Vertical set up. Seems if you are picking this up, it really is coming from one location on the North Island of NZ. Their Transmitter is running 100Kw. Ian |
6th Dec 2021, 3:35 am | #11 |
They have recently had an upgrade to the antenna systems. Although the transmitter is only 100kW the antenna has a reasonably narrow pattern aimed at the south pacific islands or south east asia - the EIRP is around 5MW! Most programming come from our "National" programme on the MW and FM bands which is probably why there's not many station idents.
Here's all the tech gen.... https://www.rnz.co.nz/international/technical
Cheers - Martin ZL2MC |
6th Dec 2021, 12:37 pm | #12 |
And I expect antipodeal focussing probably helps a bit! Kind regards Dave |
6th Dec 2021, 12:48 pm | #13 |
Back in the '80s RNZI was a difficult catch with its 10kW ex-WW2 modified CW units.
I did send a report and they kindly sent me a copy of "The Listener" ABC was easier as it had more power and sites. Although now a very good signal, the audio sounds as if it is double-hop propagation. |
