18th Jan 2023, 6:07 pm | #1 |
Help ID this unmarked valve
This has been puzzling me for a while, what could it be?
Magnoval base, Philips/Mullard 'cross' at the top of the glass, 8Ω across pins 4 & 5 Doug Last edited by dougietamson; 18th Jan 2023 at 6:18 pm. Reason: sp |
18th Jan 2023, 6:28 pm | #2 |
Re: Help ID this unmarked valve
I wonder of it might be an EL93? I have one somewhere here that looks like an EL84, but shorter in stature. Cheers.
18th Jan 2023, 6:34 pm | #3 |
EL508 maybe .Mick.
18th Jan 2023, 6:38 pm | #4 |
Hello,
Possibly a PL508? https://www.radiomuseum.org/tubes/tube_pl508.html (Or an EL508) Yours, Richard |
18th Jan 2023, 6:44 pm | #5 |
At 8Ω cold (?) heater, more likely to be PL508 than EL508.
18th Jan 2023, 6:45 pm | #6 |
Yes, looks very similar to the attached photo.
The box of valves I was given that it came from had a few TV/video valves. Doug |
18th Jan 2023, 6:48 pm | #7 |
Measured cold on the minitester
18th Jan 2023, 7:14 pm | #8 |
19th Jan 2023, 2:40 pm | #9 |
Mullard PL508 heater measures 8.01Ω using a Keithley 2000 DMM
Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be! |
19th Jan 2023, 2:50 pm | #10 |
For a lot of valves I've found that the hot resistance of the heater will be between 5 to 8 times the cold resistance.
Lawrence. |
19th Jan 2023, 2:57 pm | #11 | |
It's also reassuring the low cost avr mini tester is doing a good job. From the project page: "Up to two resistors will be measured with a resolution down to 0.1 ohm. The measurement range is up to 50 Mohm (Megaohm). Resistors below 10 ohm will be measured with the ESR approach and a resolution of 0.01 ohm if a ATmega168/328 is used. Beware: resolution is not accuracy." Doug |
19th Jan 2023, 4:52 pm | #12 |
I've tested the valve on my DC-DC buck boost module, I set to 17.04v and the heater draws 300mA, spot on
Now to think of a use for it... |
19th Jan 2023, 5:14 pm | #13 |
Do you have a socket for it? Those B9D sockets are the first stumbling block.
19th Jan 2023, 5:42 pm | #14 | |
I checked the pins on some loctal valves and they are all 0.05". The valve holder attached pic is used to hold a magic eye, might be able to cobble together a bodge job. |
20th Jan 2023, 6:22 am | #15 |
What are the markings on the glass side wall (partly observed in photo 5 of 5 in post #1?
20th Jan 2023, 11:23 am | #16 | |
4 character plant/date = 'right angled triangle' Zero A 2 So the plant is Philips Heerlen Date is either 2nd week of Jan 1960 or 1970 I'll assume it's 1970 as the valve was designed for colour TVs. ? No typical 3 character type found. Doug |
20th Jan 2023, 11:28 am | #17 |
20th Jan 2023, 1:11 pm | #18 |
Something like a PL508 would work OK as a low-power single-ended audio-amp or even a low-power 1.8/3.5MHz RF power-amplifier in applications where a 5763 or 6BW6 may have originally been specified.
I reckon it would be good for 15 Watts on 80 Metres in Class-C. TV valves have quite some history in such applications; KW Electronics produced a top-band TX in the 'fifties that used a PL81 as the RF output valve, and the PL509/519 is popular amongst us Hams for use in HF linear-amplifiers, where their ability to handle impressive peak currents helps to prevent 'flat-topping' on modulation peaks.
20th Jan 2023, 1:22 pm | #19 |
I was wondering if an EAR 559 clone might be interesting. There is an interesting thread on DiyAudio at the moment on this topic ...
How would you drive an EL509 in enhanced triode mode. |
20th Jan 2023, 2:17 pm | #20 |
Here's the datasheet attached for the EL508, PL508 is on r-type.org.
http://www.r-type.org/pdfs/pl508.pdf I've bid 99p on a buddy for the single valve I have. The free box of valves also came with a NOS PZ30, I tested the heaters on 52v, all good. Looks like I'll be winding more transformers this year... |
