Reply
Old 3rd Nov 2022, 4:45 pm   #1
Outrun_uk
Default Fluke 79 DMM
Hi all,
The Fluke 79 from user Lighting arrived earlier today - many thanks!
This meter had an episode with a microwave oven magnetron so I wasn’t holding a great deal of hope for it but I do like a challenge…
As it turned out it only required 3 components to get it working - definitely a testament to the build quality and ruggedness of Fluke gear. Short circuit bridge rectifier, open circuit input resistor (note these need to be replaced with the correct fusible flameproof type) and the 1A input fuse.
Checked on a calibration machine and all well within specifications.
Cheers,
Kev
Outrun_uk is offline   Reply With Quote
Old 3rd Nov 2022, 8:54 pm   #2
barrymagrec
Default Re: Fluke 79 DMM
Good work - I hate to think how many faulty meters get junked for the lack of a little investigation.
barrymagrec is offline   Reply With Quote
Old 4th Nov 2022, 12:18 am   #3
Uncle Bulgaria
Uncle Bulgaria's Avatar
Great job - well done! Satisfying, too.
Uncle Bulgaria is offline   Reply With Quote
Old 4th Nov 2022, 9:50 am   #4
McMurdo
McMurdo's Avatar
Hopefully the person holding the probes is still with us.
I did a 79 a few years back that an electrician had used to try and measure the output from an insectocutor, same result.
Kevin
McMurdo is offline   Reply With Quote
Old 4th Nov 2022, 12:23 pm   #5
Peter.N.
My Fluke 11, my mainstay for 30 or 40 years has just packed up and the LCD screen is disintegrating so I'm looking for a secondhand one now. I found mine almost indestructible
its measured the resistance of the mains on a number of occasions and it just shouts at you and goes on working. Having been long retired I will not use it much but its indestructability still appeals to me.
Peter
Peter.N. is offline   Reply With Quote
Old 4th Nov 2022, 9:14 pm   #6
audiomm
iPeter
I have two Fluke 12's - one I use constantly,which had a display 'bleed' due to direct sunlight overcooking it. I sourced a new display on e-bay (made in China ) and they are exactly the same as the original. Just do a search on "Fluke 11/12 display" . Lots of options available. P/N is 855226 for the display.
Mike
audiomm is offline   Reply With Quote
Old 4th Nov 2022, 10:01 pm   #7
linescan87
linescan87's Avatar
I'm glad to see that this meter went to a good home, well done on getting it going. I have quite a few Flukes here and there always the first DMMs I reach for. Made to last.
All the best, John Joe
www.youtube.com/c/ojnojirishvintagetvandradio
linescan87 is online now   Reply With Quote
Old 5th Nov 2022, 11:20 am   #8
Peter.N.
Thanks for that but I have just bought a Fluke 25 for not to much money, I'm amazed that the displays are still available.
Peter
Old 5th Nov 2022, 3:22 pm   #9
lightning
So pleased you gave it a new lease of life.
That meter was my faithful companion for twenty years and probably 10,000 service calls.
May it last another 20 years ! The display was still good on it.
lightning is offline   Reply With Quote
Old 6th Nov 2022, 12:01 pm   #10
ex 2 Base
Well done Kev, good to hear that the meter has been revived. Ted
ex 2 Base is offline   Reply With Quote
Reply
