25th Apr 2019, 10:14 am | #781 |
Re: The Audiophoolery Thread.
25th Apr 2019, 10:39 am | #782 | |
Cheers, GJ
http://www.ampregen.com |
25th Apr 2019, 10:50 am | #783 | |
25th Apr 2019, 5:10 pm | #784 |
Someone describing himself as a hi-fi enthusiast does not guarantee that he is a hi-fi enthusiast. In a similar way, equipment described as hi-fi might not actually be hi-fi. The issue is whether accuracy of reproduction is sought, or a pleasant sound - which for some people may require certain lack of fidelity.
25th Apr 2019, 5:25 pm | #785 |
Or perhaps the issue is 'fidelity to the best that the recording engineer could do' (which is what the most accurate reproducers would give us) or 'fidelity to the acoustic experience we might have had if we'd gone to the performance or to the effect that the musicians wanted to create'. Quite a few enthusiasts would argue that the second kind of fidelity is more desirable than the first.
Given a) that acoustics are affected substantially by the listening room and b) that the experience happens inside our heads, and all our heads are different, I think it's entirely plausible that achieving the second kind of fidelity might require the use of equipment which isn't just 'a straight piece of wire with gain'. Once upon a time everyone understood and accepted this. Quad, Leak etc didn't build all those tone controls and filters into their pre-amps for no reason. They were there precisely to allow the listener to make the equipment as imperfect as was required to reproduce the original musical experience as well as possible. I suspect if we'd presented Peter Walker with a modern pre-amp (a unity gain box with a volume control and, if we're lucky, a reduction in source impedance) he'd have walked away laughing. Cheers, GJ
25th Apr 2019, 6:16 pm | #786 |
I try to work out whether the individual is using the equipment to listen to the music or is using the music to listen to the equipment.
25th Apr 2019, 6:33 pm | #787 |
I like it.
25th Apr 2019, 6:44 pm | #788 |
I have known people to whom, it seemed to me, the equipment was an end in itself, rather than a means to an end. Their attitude was/is best summed up by the punch line in Flanders & Swann's 'Song of Reproduction' -'I never did care for music much, it's the High Fidelity!'
25th Apr 2019, 7:17 pm | #789 | |
So, far from taking the minimalist view, the audiophool or even the knowledgeable audiophile should use equipment with tone controls, if not high quality graphic equalisers and employ equipment for setting up the same to match (or at least, provide some form of correction) to their listening room. A problematic, notchy, peaky frequency response in the listening room is much worse than the supposed extra 'distortion' that tone control circuitry may bring to the fold.
25th Apr 2019, 11:50 pm | #790 |
Hold on - I use a passive pre. And I am certainly not a minimalist anything. What do you need gain for? The output level of most sources actually needs to be attenuated and not amplified before it goes into a power amp.
The only time you need an active preamp is if you are going to have, and use tone controls, or absolutely need things like tape loops. Anyway, to be technically correct, an active preamp is actually a buffered passive pre (AKA volume control). Craig |
26th Apr 2019, 12:04 am | #791 |
You need an active preamp if you play LPs with a magnetic cartridge as you have to amplify the signal massively and also perform the RIAA equalisation, before any messing about with tone controls (best of luck with that).
26th Apr 2019, 3:23 am | #792 |
Re-reading a little of this very long thread reminds me of something I once heard about, which was that someone had spent a lot of time, money and effort trying to get the sound he wanted. A piece of music including a violin solo was involved, and the upshot was that the listener still didn't think the sound was 'right', at which point the musician involved walked into the room playing the piece on his violin!
26th Apr 2019, 8:18 am | #793 | |
The point I was trying to make is the output from most sources will be enough, without attenuation, to drive most power amps to full output or well into clipping. The best description of a pre-amp is a "control amplifier", and ought to borrow its architecture from a mixing desk, with a mixing bus, individual sensitivity matching for each input, and a master output control. The aim being to preserve overload margin throughout. It ought to make provision for tape recorder output and listen, and a headphone output. It should be capable of driving long lengths of coax or balanced cables. But its overall gain from input to output will be well below unity if it feeds a power amp. Or, for domestic non-professional applications you can just use a high quality pot-in-a-box (or equivalent, tapped transformer, tapped auto-transformer or optical) for short cable lengths. Now I don't have tone controls, but I can see the argument for having them. With sensitive use they can be used to correct for recording anomalies. For example anything by Phil Collins is mixed very hard sounding, because he is deaf as a post so directs the mixing engineer to compensate. Lots of close miked Deutsche Grammophon classical recordings sound unnatural (certainly as compared to a live orchestra) without tonal adjustment. I'm almost persuading myself I need an add-on tone control! Craig |
26th Apr 2019, 9:06 am | #794 |
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
If anyone thinks a studio recording is realistic should listen to any stereo recording done on a half decent microphone. The stereo imaging is astonishing in comparison. I think tone controls are desirable and any perceived distortion added is ac
academic considering what happens to the recording from source to media.
Dom Less snakes...more ladders! |
26th Apr 2019, 9:33 am | #795 | |
Do you know 'The Caution Horses' by the Cowboy Junkies ? They are folks who care about how their recordings are made and they made their first one (admittedly mostly because of financial constraints) using a single mic in their garage. It is an astonishing album, in my opinion of course. Their second was recorded in a church. But their third, Caution Horses, was (eventually) recorded in a studio - the story's here https://en.wikipedia.org/wiki/The_Caution_Horses. I think it sounds pretty good. Listen to this track from a proper source on a proper system and see what you think https://www.youtube.com/watch?v=rnmoOp8Jbdg. Cheers, GJ
26th Apr 2019, 10:30 am | #796 |
There is a 'right' sound, but as it exists only in the listener's head, words cannot describe it and it depends on all manner of external non-auditory influences (Most recent meal, what he's been drinking, last hifi magazine review read, colour of room....) so no two people ever agree on what is right.
My favourite classical recordings were the early Decca stereo ones that had been recorded in a very simple fashion, and my least favourite were the Deutsche Gramofon ones which seemed over-worked somehow I wasn't sure what it was about them, I'd just blamed von Karajan! I'm just amused that some people abhor tone controls and equalisers, but consider it quite proper to keep buying and selling equipment trying to get the same effect. It's a bit like saying "I want to go Eastwards today, so I must sell my car and keep buying new ones until I happen upon one already facing in that direction!" Of course, there are equalising networks inside crossovers (whether active, passive or digital) but what they don't know about doesn't vex them. I'm hoping none are reading this so I haven't given the game away. David
26th Apr 2019, 10:36 am | #797 | |
Alan PS For what it's worth I am also an advocate of tone controls (possibly switchable) although I think that the traditional baxandall arrangement has an unnecessary degree of attenuation. |
26th Apr 2019, 11:06 am | #798 | |
Alan |
26th Apr 2019, 12:18 pm | #799 | |
Are you sure it's a noun and not an adjective?
Regards, Richard, BVWS member |
26th Apr 2019, 12:19 pm | #800 | ||
As a counter-example, consider how most people (or, at least, most men) think of themselves as a better than average driver. It can't be true of all of them. |
