28th Feb 2021, 3:52 pm | #1 |
Rear exit 13A plugs
Were there any rear exit, as opposed to bottom exit, BS1363 plugs ever made? I ask because one of them would solve the "pulling on the Hoover (VAX really) lead breaking the socket" problem. It is our "lady that does" does frequently, at least (for the time being) I am "allowed" to replace the socket.
28th Feb 2021, 4:04 pm | #2 |
Re: Rear exit 13A plugs
A possible solution would be to fit the vacuum with a European plug and use an adaptor to convert that back to a UK plug.
I.e. use a CEE 7/7 plug and one of these type of adaptors https://travel-blue.com/product/euro...aptor-earthed/ |
28th Feb 2021, 4:24 pm | #3 |
The only one I have come across is a Clipsal waterproof plug. I got mine from Screwfix many years ago for my external socket. I believe they are still available but I don't think Screwfix sell them now. The Clipsal plug does fit a standard 13A socket, but the compression cord grip is not designed for thin cables.
28th Feb 2021, 4:25 pm | #4 |
Wow! She must be yanking on the cable pretty roughly to damage the socket.
I bet it happens when she's doing the stairs, and pulling the cable upwards from the hall socket and over the banister! Maybe you could tactfully suggest that she calms down her vacuuming technique a bit - or possibly present her with her very own trailing socket extension lead, so she can easily do the whole house from just the one socket. Just a suggestion...
Best Regards, Peter. Last edited by Lancs Lad; 28th Feb 2021 at 4:47 pm. |
28th Feb 2021, 4:41 pm | #5 |
If you search for 13 Amp straight plug you get several hits. (Example http://internationalconfig.com/icc6.asp?item=72150-SN )
Simplest (cheapest) would be to use one of those 'Easy Pull' or 'Super Grip' plugs with the handle. Then wrap the flex back round the handle so it pulls from the centre and not at 90 degrees?
28th Feb 2021, 4:54 pm | #6 | ||
Thanks all, "13 Amp straight plug" the right search clue, Google 'ain't that clever after all, the Super Grip option sounds perfect.
After posting I thought of adding a lawnmower type plug and socket in line, bright orange may be a bit of a hint too. Quote:
28th Feb 2021, 4:59 pm | #7 |
Haha!
I must be psychic What about the extension lead idea? Or maybe extending the vacuum cleaner cable with a Duraplug lawnmower connector as you suggest, so that she would have to use it to be able to plug the cleaner in? She reminds me of Hinge and Bracket's cleaner, Maud! She caused mayhem whenever she attempted to use their vacuum cleaner
Best Regards, Peter. Last edited by Lancs Lad; 28th Feb 2021 at 5:07 pm. |
28th Feb 2021, 5:02 pm | #8 |
But then if the resistance provided by the vacuum cleaner reaching the end of its tether isn't, maybe not.
Not a solution in the short term, but when it next comes to replacing the machine, maybe it would be worth considering going cordless.
28th Feb 2021, 5:19 pm | #9 |
In-line IEC C13/14 pair?
28th Feb 2021, 5:22 pm | #10 |
One bit I spotted:
UNITED KINGDOM, BRITISH 13 AMPERE-250 VOLT STRAIGHT PLUG, HARD DUTY "IMPACT RESISTANT" (UK1-13P), BS 1363A TYPE G, CLAMP TYPE MULTI-CONDUCTOR TERMINALS, STRAIN RELIEF (CORD GRIP) ACCEPTS 0.236-0.787" (6.0-20.0mm) O.D. CABLES, WIRING TERMINALS ACCEPT 14, 12, 10 AWG SIZE CONDUCTORS. BLACK. Notes: * Plug Designed for Industrial / Commercial applications. Not Hi/Fi Audio Equipment Rated. What was that last bit again? Not Hi/Fi Audio Equipment Rated. That's a first on me! David
28th Feb 2021, 5:29 pm | #11 |
Get a Henry, the longer cable should reduce the chance of stretching the cable, I can just about vaccuum the whole of my Gran's house with out moving the plug.
Or another option would be to fit a "kettle" style connector to the vacuum as I would expect that to pull out before the plug in the wall. I also wonder what is available in regards to mains plugs designed to separate easily as a safety feature. |
28th Feb 2021, 5:42 pm | #12 |
An IEC male/female mated-pair would seem a good option.
I used this with my late mother: in her 90s she didn't 'get' the idea that the kettle lifted-off the powered base, and would pick up the kettle-and-base to pour the boiling-water, only to discover for the umpteenth time that the flex from wall-socket-to-base was rather short and provided an abrupt end to her kettle-carrying. For safety, I fitted an inline IEC309 pair so this would separate-easily-when-tugged, so stopping her slopping boiling water over herself. |
28th Feb 2021, 6:10 pm | #13 | |
https://www.youtube.com/watch?v=rM_HyLXldfc Regards, Symon Last edited by Philips210; 28th Feb 2021 at 6:17 pm. |
28th Feb 2021, 6:27 pm | #14 |
Get a "brick" type 2 or 3 way 13A adapter and cable tie the vac's plug into a side or top outlet.
Leon. |
28th Feb 2021, 6:47 pm | #15 |
About fifteen years ago I had a Vax vacuum cleaner (£34.99 from Tesco) that had a 10 metre cable.
I could vacuum my whole 3 bed semi-detached house with the machine plugged in to the same socket in the downstairs lobby. Why aren't vacuum cleaner cables all a sensible length? I bought quite an expensive Bissell vacuum cleaner, and it's cable was only five metres long. What earthly good is that? I was forever unplugging and plugging in. It's such a good machine aswell, but the ridiculously short cable lets it down. How long were the cables on the 1970s Hoover Juniors and Seniors that I grew up with? They always seemed to be long enough to do the job. And most of them, I seem to remember, for some reason, had an Ashley plug on the end of them. At least, the ones in our family did! Don't know why! Did Ashley only ever make one style of plug? The big rectangular one!
Best Regards, Peter. Last edited by Lancs Lad; 28th Feb 2021 at 7:02 pm. |
28th Feb 2021, 6:49 pm | #16 | |
"The best dBs, come in 3s" - Woody Brown |
28th Feb 2021, 6:56 pm | #17 |
Use the top socket on a 2-way cube adapter?
Or splice in a section of coily cable so it's a gradual pull rather than a sudden tug. |
28th Feb 2021, 7:42 pm | #18 | |
Yes, I think this would be a frying-pan-into-fire situation, a small-but-jagged demolition ball flying around randomly! |
28th Feb 2021, 10:22 pm | #19 |
Re #10:
* Plug Designed for Industrial / Commercial applications. Not Hi/Fi Audio Equipment Rated. Perhaps due to the minimum cable diameter of 6mm? Audio/hifi cables are seldom this large, unless you are an audiophool. |
28th Feb 2021, 10:28 pm | #20 |
The machine is a VAX with long enough wire, chosen by her, who am I to argue? I like the IEC idea I have some in line plugs in stock.
