Old 13th Jan 2020, 7:31 pm   #321
john_newcombe
Default Re: Gemini 80-Bus System
Originally Posted by john_newcombe View Post
Have a look at post 270, there is a link to the images there.
I just realised that these are the GM849 (with the MFB mod) not 849a.
john_newcombe is offline
Old 13th Jan 2020, 7:34 pm   #322
john_newcombe
With the Galaxy MFB system re-assembled, albeit loosely, I was able to boot
Code:
CP/M (Bios 3.4) from the first 5.25 inch disk drive.
       Gemini Multiboard Computer System
     64K CP/M-80 vers 2.2     (Bios 3.4)
   A>
This did not give me an MFB system though as an attempt to run ANALYSE.COM reported the following.
Code:
   **** Not a Gemini MFB System ****
Accessing drive B: wasn't too successful either, the Winchester made some noises and the following was reported...
Code:
   A> B:
   Drive B T=0002 S=0000
   Xebec Error, code = 04
The Xebec Controller documentation suggests... Sector Not Found. The controller found the correct cylinder and head, but not the target sector.
So whilst not a fully functioning system, progress is steady.
Old 13th Jan 2020, 10:01 pm   #323
qazxsw123
The boot up sequence I get with 5.25 floppy drive is very similar
64K CP/M-80 vers 2.2 (Bios 3.5)
A>_
But due to any programs on the disk I cant progress further at the moment.
I' going to try the "simon" rom tomorrow to see I can work out the problem with the gotek .
qazxsw123 is offline
Old 14th Jan 2020, 10:45 am   #324
john_newcombe
Bios 3.5 is interesting... I don't have that, I would like to get that archived.
Is your issue simply that the Gotek is using GEMDDDS format and the BIOS is looking for GEMQDDS? The symptoms you describe remind me of when I was trying to use GEMQDDS disks with BIOS 1.4 (GEMDDDS only), they would boot and the directory could be read, however, programs would often not load. Of course you may be using the GEMQDDS images that I created some time back. I'm not sure if you are aware but those disk images were probably not quite right as earlier discussions in this thread have highlighted. These were removed from the library on GlassTTY.com a little while back in an attempt not to confuse things and introduce 'new' formats.
In terms of my own Galaxy, I am using Simon 4.1 for booting the floppy and will be trying to get a Gotek going today so that I can archive what I have so far. Obviously my aim is to get the hard drive working in the longer term to form a full MFB system. I will let you know how I get on later today.
Old 14th Jan 2020, 11:55 pm   #325
john_newcombe
Today wasn't too successful in terms getting the Gotek working or loading MBASIC for that matter and clearly I need to investigate all of these issues further.
Gotek
The Gotek boot image I have for CP/M with Bios 3.4 will not boot. In addition, I cannot get the machine to recognise anything other than the first floppy as A: and the Winchester as B: which prevents me from attaching the Gotek as B: or C: etc. Alas, the Winchester doesn't work at the moment either.
MBASIC
I can boot to a floppy and I have used READCAS.COM to try and load MBASIC from tape, whilst the system read the tape fine it failed to write to the disk. Several attempts were made but each failed in the same way.
FORMAT
As I only have one system disk for this machine I thought I would try and create another using FORMAT and SYSGEN from the existing disk. Format and verify worked fine but SYSGEN failed when copying the system from the working disk to the new disk.
Some successes though as SYSGEN did work when transferring the system from the system disk to an MFB Update Disk that wasn't originally bootable, it is now.
As I said, I will continue the investigation and keep the thread updated.
Old 15th Jan 2020, 8:54 am   #326
JohnBHanson
Sounds like you are trying to run an 829 bios on an 849 system. The bits in the drive select register are different - but bios 3.4 should be able to cope with both I think.
Simple fix will be to jumper the GOTEK as drive C: which cpm should treat as drive B: if I have got my sums right. Then check with configuration as post 322.
Alternative is to modify the select routine - it can even automatically determine if it is a GM829 or GM849 by looking at bit 7 of port e5 (Should be zero for GM849 1 for GM829). Thats tricky with multi.mac as several bits of code need to be modified.
You might need a later bios for the floppy
I am not sure why write to the disk does not work - it could be that the floppy disk controller needs calibration but don't mess with that for the moment.
JohnBHanson is offline
Old 15th Jan 2020, 10:09 am   #327
john_newcombe
Thanks John, I will be able to spend some more time this weekend to look at things again.
Old 15th Jan 2020, 5:36 pm   #328
qazxsw123
If you have a teac fd55 drive, check jumper MX is removed. with it in place the drive will read data without checking the drive select signal.
https://retrocmp.de/fdd/teac/TEAC_FD...r-settings.pdf
Old 16th Jan 2020, 6:22 pm   #329
john_newcombe
Hi have now managed to load MBASIC onto one of the backup disks I received with the machine. There were two issues. The first was my fault in not understanding that when loading a file, the file extension should be omited. e.g.
Code:
A> WRITCAS MBASIC.COM
and
Code:
A> READCAS MBASIC
A> REN MBASIC.COM=MBASIC
The second issue is that, despite having two system disk backups, which look similar in terms of files on the disk etc. The commands behave differently. For example on one FORMAT.COM complains that the bios is not MFB, the second formats the disk as 80 track double density (and verifies) however, this cannot read or written to. I am assuming that some kind of check for MFB is present and causes it to fail. The bios used to create the disks clearly used the SYSTEMFW.CFG file. If I try and create a bios using MFB.CFG, GENSYS complains that the system track is not large enough but SYSTEMFW.CFG works fine.
Anyway enough babble, I ran your program i.e.
Code:
10 FOR I=0 TO 255 STEP 8
20 OUT &HE5,I+7
30 P=INP(&HE5)
40 PRINT HEX$(I+7),HEX$(P)
50 NEXT I
The output was...
Code:
7 	7F
F	7F
17	7F
1F	5F
27	7F
2F	7F
37	7F
3F	1F
47	7F
4F	7F
57	7F
5F	5F
67	5F
6F	5F
77	5F
7F	1F
87	7F
8F	7F
97	7F
9F	5F
A7	7F
AF	7F
B7	7F
BF	1F
C7	3F
CF	3F
D7	3F
DF	1F
E7	1F
EF	1F
F7	1F
FF	1F
I hope this helps. Once you have this complete will it mean I will be able to emulate an MFB system with the Simon 4.1 ROM ? If so, that would be awesome.
Old 16th Jan 2020, 10:16 pm   #330
JohnBHanson
I have modified xbeaver to give the correct table.
Run with xbeaver gem925.cfg -o x to boot mfb (Boots directly from hd without ROMS)
xbeaver gem925.cfg -o rx to boot mfb from roms
My config file for the gem925 is
Code:
if B echo Option B - load boot sector at 0000 for booting
if E echo Option D - Include Debug console
if E echo Option E - External Video Card
if L echo Option L - Load CPM from file file
if M echo Option M - Include GM833 Ram Disk
if R echo Option R - Use boot rom (Simon)
if T echo Option T - Trace io cycles
if X echo Option X - Use MFB system (Work in progress)
#if X set B
if E cpuclock 1
if !E cpuclock 1
if T board 0x0 intbus 0x0 0xe0 xrw trace
if T board 0xe0 intbus 0xe0 8 trw trace
if T board 0xe8 intbus 0xe8 0x17 xrw trace
if T bus trace
board 0xfe gm813_mmu
if !E if X board 0xb0 gm832 Gemini_925_MFB green keyboard gemini
if !E if !X board 0xb0 gm832 Gemini_925 amber keyboard gemini
if E board 0xb1 extbus 0x0a1 0x03 rw /dev/z80xbus
if E output 0xb3 0
if D board 0xa0 gm832 SysTrace green
if D output 0xa1 0x1b 0x35
board 0xb8 serial_8250 bvrnet &
  ~/beaver/gm925/gm925/a%d &
  ~/beaver/gm925/gm925/b%d &
  /saturn/cpmapps/beaver/diska/user%d &
  ~/beaver/network
if X   board 0xe0 gm849m_scsi  ~/beaver/disks/gem925mfb.dsk
if !X  board 0xe0 gm829m_scsi   ~/beaver/disks/gem925.dsk
if M board 0xfb gm833 -maxtrack 0x3f
if X board 0xe0 gm849_floppy -geometry T80.2.10.0.512 &
  ~/beaver/disks/floppy.dsk
if !X board 0xe0 gm829_floppy -geometry TD35.2.10.0.512 &
  ~/beaver/gm512/GM512_ORIGINAL.DMP
if T bus io
if L binload cb00 ./beaver/network/cpm64w.bin
if L byte 0 c3 00 eb
if B if X binload 0000 ./beaver/network/gemhdbtm.bin
if B if !X binload 0000 ./beaver/network/gemhdbt.bin
if R binload 0f000 ./beaver/network/simon.rom
if R if X byte f031 6d 47
if R if !X byte f031 47 47
if R byte f310 76
Old 16th Jan 2020, 11:20 pm   #331
JohnBHanson
The mystery chip for IC14 looks to be an 74LS20 with pin 1 connected to +VCC. I cannot tell from the photo you sent me but is pin 1 bent under and connected to pin 14?
A few other pins look a bit strange from the photo...
From the photo the soldering down the lhs (eg pin1...pin5 or so) looks a bit odd - be nice to confirm that my assumption is correct.
PS- when you get the xbeaver emulator running with a gm849m_scsi card can you double check the scsi.bas program - should be the same as the emulator version now.
Latest emulator version boots MFB system directly - Simon can boot from the hard disk if there is not a floppy inserted which is hard to do on the emulator as it stands.
The analyse program almost works - just identifies as Single not Double Density as my emulator ignores the single/double density in the floppy disk selection. Also track read does not read any data.
However as MFB boots the data transfer utilities should work - however the floppy geometry in the config file will need to match.
Old 17th Jan 2020, 2:22 am   #332
john_newcombe
Thanks John, I will give it a go. I will also try and check the chip also.
Old 17th Jan 2020, 5:56 am   #333
JohnBHanson
The emulator is done on a table lookup for the two "undefined" bits the emulator should now match your board.
Truth table for the two outputs are as follows
Code:
Readback bit 0x20 gives the following
Bits:6  5  4  3   Out     RawIn  RawOut
Idx
 0   0  0  0  0    1        07     7f
 1   0  0  0  1    1        0f     7f
 2   0  0  1  0    1        17     7f
 3   0  0  1  1    0        1f     5f
 4   0  1  0  0    1        27     7f
 5   0  1  0  1    1        2f     7f
 6   0  1  1  0    1        37     7f
 7   0  1  1  1    0        3f     1f
 8   1  0  0  0    1        47     7f
 9   1  0  0  1    1        4f     7f
 a   1  0  1  0    1        57     7f
 b   1  0  1  1    0        5f     5f
 c   1  1  0  0    0        67     5f
 d   1  1  0  1    0        6f     5f
 e   1  1  1  0    0        77     5f
 f   1  1  1  1    0        7f     1f
and Readback bit 0x40
Bits:7  6  5  4  3   Out     RawIn  RawOut
Idx
 0   0  0  0  0  0    1        07     7f
 1   0  0  0  0  1    1        0f     7f
 2   0  0  0  1  0    1        17     7f
 3   0  0  0  1  1    1        1f     5f
 4   0  0  1  0  0    1        27     7f
 5   0  0  1  0  1    1        2f     7f
 6   0  0  1  1  0    1        37     7f
 7   0  0  1  1  1    0        3f     1f
 8   0  1  0  0  0    1        47     7f
 9   0  1  0  0  1    1        4f     7f
 a   0  1  0  1  0    1        57     7f
 b   0  1  0  1  1    1        5f     5f
 c   0  1  1  0  0    1        67     5f
 d   0  1  1  0  1    1        6f     5f
 e   0  1  1  1  0    1        77     5f
 f   0  1  1  1  1    0        7f     1f
10   1  0  0  0  0    1        87     7f
11   1  0  0  0  1    1        8f     7f
12   1  0  0  1  0    1        97     7f
13   1  0  0  1  1    1        9f     5f
14   1  0  1  0  0    1        a7     7f
15   1  0  1  0  1    1        af     7f
16   1  0  1  1  0    1        b7     7f
17   1  0  1  1  1    0        bf     1f
18   1  1  0  0  0    0        c7     3f
19   1  1  0  0  1    0        cf     3f
1a   1  1  0  1  0    0        d7     3f
1b   1  1  0  1  1    0        df     1f
1c   1  1  1  0  0    0        e7     1f
1d   1  1  1  0  1    0        ef     1f
1e   1  1  1  1  0    0        f7     1f
1f   1  1  1  1  1    0        ff     1f
Old 17th Jan 2020, 6:10 am   #334
JohnBHanson
This is the format program I have - the MFB version
Old 17th Jan 2020, 8:34 pm   #335
john_newcombe
Today I took the R/O tab of the only master disk I have and created a system.cfg that used A (QDDS), B: (DDDS) and C (Winchester). This was written to the system track and saved to a file also. The disk now boots and recognises the 40 track 5.25 drive. The Gotek when connected in place of this drive is also accessed, however, the files cannot be read form any of the DDDS images.
I have several physical disks, one is labelled 'Master disk' and the others seem to be MFB update disks. The dates vary from 1984-1986. Each of the disks has a format utility, however, only the one from 1984 will actually run. The others complain that the system is not using the MFB bios. The error text is correct as I am using the biosfw as biosmfb doesn't fit on a floppy. With 1984 version of the format program the disk gets formatted and verified at 80 tracks double density which I am assuming is QDDS. However, it cannot be read under bios 3.4.
As a result of both of the above, I could be forgiven for thinking that the disk/Gotek read issues are related.
To take things further, I think it's time to get a Simon ROM version of XBeaver MFB working so that I can have a play with some disk images.
Old 17th Jan 2020, 9:11 pm   #336
JohnBHanson
The two programs you need are gensys - to generate a standard or a mfb system
and config to configure an mfb system
eg gensys mfb.cfg
to generate an mfb system
gensys system.cfg generates a standard non mfb system
mfbfw.cfg gives a floppy boot for the mfb system
I started with the original image from you to create my two images
There are two system tracks 0 and 1 and can contain different systems
boot 0
or
boot 1
can be used from the command line to boot either the system from track 0 or track 1.
use nswp *.cfg
to browse the .cfg files. The short files are for use with config
Hope that helps.
Old 17th Jan 2020, 10:43 pm   #337
JohnBHanson
In post 330 change gm829m_scsi to either gm849_scsi or gm849m_scsi
Old 18th Jan 2020, 12:39 am   #338
john_newcombe
I have been using GENSYS with the floppy to create non-mfb system disks that is fine but prevents running MFB programs such as format.
I now have Xbeaver booting to an MFB system following your config, using the original gm925 disk image and running GENSYS to upgrade it to MFB. My real hardware does not have a working Winchester and the MFBFW.CFG file uses .biosfw which is a non-mfb bios.
i currently do not have any floppy disk images that will work with 3.4 the DDDS ones that worked with bios 1.4 do not seem to work with 3.4. If you have a floppy image that works for you under 3.4 MFB I would love to get a copy.
Old 18th Jan 2020, 3:16 am   #339
JohnBHanson
Tried and failed, then read the "Multi Format Bios Manual". Page 2 states
"A is fixed in type as the winchester...."
I tried to generate a .cfg file and then run gensys mfbflop.cfg and get
*** Error **** while configuring logical drive A
BIOS cold boot does not match your Drive A
Unable to proceed
So I think you need a winchester to work MFB
Old 18th Jan 2020, 3:46 am   #340
JohnBHanson
I have created a bios 3.4 (not mfb) boot disk with disk A and B as floppy (QDDS), C,D winchester
Included in the zip file is the gem925.cfg to make this work.
Boots under simon with command line
xbeaver gem925.cfg -o xr
Hope this helps you.
look at bootflop.cfg
(PS You will need to check you have the files in the correct places)
note the format used is T80.2.10.0.512 if you are going to copy this to a real floppy drive.
