Reply
Old 15th Oct 2020, 11:02 am   #2021
Herald1360
Herald1360's Avatar
Default Re: The Audiophoolery Thread.
Sounds like your leccy hacksaw ;
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 15th Oct 2020, 4:53 pm   #2022
Craig Sawyers
Craig Sawyers's Avatar
I suppose if you get fed up listening to these, you could of course smoke them
https://www.grado.co.uk/hemp-headphones.html
Craig
Craig Sawyers is online now   Reply With Quote
Old 15th Oct 2020, 5:13 pm   #2023
Radio Wrangler
Radio Wrangler's Avatar
Would they be extracting the michael with their choice of verb? Hand-rolled presumably.
"warm, and precise sound rolled into a Limited Edition Grado"
It's not April, I checked. So it must be money for old rope.
Radio Wrangler is online now   Reply With Quote
Old 15th Oct 2020, 6:13 pm   #2024
a Limited Edition
All my stuff is limited edition (at least the home made!) only one of each in existence, must be worth a fortune.
Old 24th Oct 2020, 10:17 am   #2025
Craig Sawyers
From
https://www.hegel.com/products/power/h20
"A practical benefit of the H20 FET-technology is a more rhythmic sound. It is simply better at re-creating a bass line. Another vital element is the removal of harmonic echoes in the higher frequencies, which result in a lot more detail and still a smoother and more natural sound."
Umm....
Notice also the incomplete spec (a common thing with consumer audio gear)
Distortion is quoted at a power level, but not at what frequency; or is it less than the figure at all audio frequencies? Who can say.
Intermodulation - what power level was it measured at?
Damping factor of 1000 (no frequency spec; it always falls with frequency as a result of the Zobel inductor). "Amongst the highest damping factor in the industry, and full control of the loudspeakers. All this to give you the most natural, rhythmic and dynamic sound on the market today.". Totally irrelevant spec. The damping factor is determined by the loudspeaker drive unit impedance.
It costs £4k for this, by the way. At least it looks good.
Craig
Old 24th Oct 2020, 10:30 am   #2026
Craig Sawyers
Ah - at least there is some technology behind it. Feedforward, but part analogue and part in a digital processing system.
https://www.hegel.com/technology/soundengine
Craig
Old 19th Nov 2020, 1:15 pm   #2027
DonaldStott
DonaldStott's Avatar
Just in time for Christmas, the perfect present for your audiophool friend or relative:-
https://rowlandearthing.co.uk/
"Many are unaware that the Earth’s surface is covered by a blanket of electrons, which may act as one of nature’s most powerful antioxidants and anti-inflammatories. Every time we come into contact with the Earth’s surface, we are able to absorb these electrons through our skin through a process called grounding, or Earthing."
I didn't have the nerve to click the Learn More > button or maybe I just have a positive disposition?!
BVWS Member
DonaldStott is offline   Reply With Quote
Old 19th Nov 2020, 1:26 pm   #2028
mark_in_manc
I was 21 years old when I first took a flight in an aeroplane, and one of the exciting things about it was that it struck me that this was the first time I had been out of contact with the ground, for more than the 1/2s or so I might manage by energetically leaping into the air (I was 21, remember). These days I don't even fly very often - I think I am considerably more grounded.
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is offline   Reply With Quote
Old 19th Nov 2020, 2:20 pm   #2029
Radio Wrangler
I suppose it's less messy than sleeping in a casket of specially imported earth from Transylvania... although modern advances in onesie technology could help here.
I thought that the really serious guys already had earth wires with croc clips to connect onto their tinfoil hats while they were sleeping.
Old 19th Nov 2020, 7:08 pm   #2030
DonaldStott
If you persist in wearing your tinfoil hat in bed at night as I do then there could be a real danger of creating a ground loop with your Rowland Earthing sheet with an annoying 50Hz hum!
BVWS Member
Old 19th Nov 2020, 9:42 pm   #2031
The Philpott
The Philpott's Avatar
Ah, Clinton Ober. Author of 'Earthing- The most important health discovery ever?'
Err. Penicillium? Dialysis? etc etc
He experienced enlightenment very suddenly one morning in 1993 (remind you of anyone?) I have to say the product prices are not as high as i was bracing myself for, though.
Dave
The Philpott is offline   Reply With Quote
Old 20th Nov 2020, 12:48 am   #2032
Craig Sawyers
What happens when there is a lightning strike nearby that induces a multi-kV spike on the building ground?
Craig
Old 23rd Dec 2020, 9:19 am   #2033
Craig Sawyers
https://www.absolutesounds.com/broch...testPrices.pdf
Craig
Old 23rd Dec 2020, 10:12 am   #2034
The Philpott
'POA'--(Translation: If you have to ask how much it is you probably can't afford it)
Old 23rd Dec 2020, 10:21 am   #2035
Ted Kendall
One born every minute...
Ted Kendall is online now   Reply With Quote
Old 23rd Dec 2020, 10:35 am   #2036
ajgriff
ajgriff's Avatar
I like these at £200 a time:
Optional Rounded 2.4 Kg Heavy Weight Anti-Magnetic & Shock Absorbing Mass Damper to Sit on Top of Equipment
One suspects that a couple of bags of sugar would be as effective.
Alan
ajgriff is offline   Reply With Quote
Old 23rd Dec 2020, 10:37 am   #2037
Craig Sawyers
Well, the third of a ton Air Force Zero turntable is POA. The one down from that, the Air Force One is £139k, and rumours are that the Air Force Zero is > quarter of a million. To which you have to add an arm and cartridge. Or two arms and cartridges.
Wonder what happens if you stump up for one of those and it sounds bad?
Craig
Old 23rd Dec 2020, 10:40 am   #2038
PaulR
PaulR's Avatar
Craig
How could it possibly sound bad at that price?
Paul
PaulR is online now   Reply With Quote
Old 23rd Dec 2020, 11:51 am   #2039
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
When I looked at the Absolut Sounds price list my first thought was that the number quoted was the part number. Then I thought that the price came from a random number generator which had been added to the salesman's birth date.
Malcolm G6ANZ is offline   Reply With Quote
Old 23rd Dec 2020, 12:24 pm   #2040
Radio Wrangler
But even if you stump up the best part of a million quid for a system, there'll be a new catalogue out next year full of stuff that's even more absolute and you'll have to start all over again.
It's just jewellery and art. The people who buy it derive their pleasure from looking at it and knowing it's mine, all mine... and the bragging rights as well. 99% of the joy must come from knowing almost no-one else can afford it.
You can always upstage these people "Well, I don't own any of that equipment, but I do own a brain capable of designing better.. and you can't buy one of those!" Always take the high ground, and hit 'em with superiority, full in their faces.
Reply
