14th Oct 2020, 7:56 am | #2001 |
Re: The Audiophoolery Thread.
Time for a resurrection of the Auxetophone!
http://www.douglas-self.com/MUSEUM/C...e/auxetoph.htm https://youtu.be/J7SV65DFNy8 Last edited by wd40addict; 14th Oct 2020 at 8:04 am. |
14th Oct 2020, 10:00 am | #2002 | |
Craig |
14th Oct 2020, 10:13 am | #2003 | |
Hey - it would make a really daft car horn! Taking that as a lead, a guy from Australia who was posting on a Jaguar forum I was admin for, described his younger self installing a locomotive horn under the bonnet of his old Holden. Apparently when he pressed the horn button it took so much current the car slowed down. Craig Craig |
14th Oct 2020, 10:17 am | #2004 |
Earth shaking bass then....and the ‘home’ version, the Buttkicker.
14th Oct 2020, 10:23 am | #2005 |
How long before someone brings out special audiophile-grade hydraulic pipes?
14th Oct 2020, 11:04 am | #2006 |
I’ve just found a giant gap in the market! Yay! £££& coming my way! With such ‘dirty’ and underpowered 240V AC colts coming in to your fine rhodium/platinum power lead, what’s needed is something more robust.
I will be boxing up and badging as ‘audiophile’ a fantastic new power- supply which — wait for it- runs from three-phase and provides clean and powerful power where it’s needed. A group of 100A-capable bridge rectifiers is followed by a bank 12,000 uF of EPCOS capacitors, providing a crystal clear and yet fully muscular energy to the amplifier. Why, you could even DJ at Glastonbury with this wonder. And this beauty will retail for only £999 monies.
Al |
14th Oct 2020, 2:53 pm | #2007 | |
And again theres the ones who say that certain conductor and dielectric/insulation interfaces and constructions deform under the applied music signal and this also alters the timing of different frequencies arrival at the speaker or amp input. It's a belief system and as long as you accept it as such I dont mind. I figure the poor souls can't win...................... Andy |
14th Oct 2020, 3:02 pm | #2008 | |
This also has probably already been done by someone, I ceased to be surprised a long time ago. A. |
14th Oct 2020, 3:36 pm | #2009 |
There was a Swedish chap de-canning electrolytic capacitors and fitting them in exotic wooden cases.
It looked like he had no knowledge of the relationship between keeping the H2O component in.... or maybe he did? It looks like the beginning of the exoticified capacitor.... those that didn't start life exotic enough. David
14th Oct 2020, 4:05 pm | #2010 |
I can remember those wooden capacitors.
He used wax that was strikingly like the stuff used on capacitors we change on sight. I never bothered to keep a link to what he did. |
14th Oct 2020, 4:17 pm | #2011 |
Ages ago, I read of 'the singing, dancing arc' in a book on radar R&D. A fun project to lighten the wartime grimness, it employed crude modulation of a HV arc! (What else?)
The lab gents played classical music through this contraption. 'Reproduction' was surprisingly clear, and quite powerful. I think this was at Metropolitan-Vickers. Could go down a storm at an eventual new normal hi-fi exhibition. No speaker cables to hinder fidelity... |
14th Oct 2020, 4:42 pm | #2012 | |
Ahah, that sounds perfect for a three-phase power supply! As for the capacitors, I'll remember to think of a value and then add an extra order of magnitude for maximum phoolery!
Al |
14th Oct 2020, 4:55 pm | #2013 |
I have a friend who used to work at the BBC's Daventry short wave transmitter station.
On a visit there in about 1988 I was shown the modulation transformer for one of the late '50s vintage Marconi transmitters there. This thing was roughly the size of a sub-station transformer and sat in the middle of an otherwise empty locked room. When I saw and heard it, the transformer was very clearly and very loudly producing the sound of the Housemartins song "Happy Hour". John |
14th Oct 2020, 5:25 pm | #2014 | |
If you ever get the chance to hear a pair then I strongly recommend that you take it. Cheers, GJ
http://www.ampregen.com |
14th Oct 2020, 6:11 pm | #2015 |
We had a 'Magnat' plasma tweeter in work for a while, which was used in scale-modelling for auditoria design (before numerical methods really took over, and instead of a spark source which was the other way to do it via impulse response and Fourier transform). It smelt funny
Scale modelling using ultrasonic signals is fun - if you want to try to scale the speed of sound (a bit) you can fill them with nitrogen. Well, I guess you can fill them with other gasses too, but sometimes not with a spark source
"The best dBs, come in 3s" - Woody Brown |
14th Oct 2020, 6:53 pm | #2016 | ||
https://www.lansche-audio.com/en/ |
14th Oct 2020, 9:58 pm | #2017 |
What about the "Ionofane" tweeter? I think they worked by modulating a plasma arc.
I remember a friend having a set. And I am sure you can do something similar by passing an Ac current through a bunsen Flame, I guess any hot gas will work once ionised. Neat trick if it could be contained and at normal room temps, a virtually massless driver? A. |
14th Oct 2020, 11:34 pm | #2018 |
There is a decent summary of the various versions of the ion plasma tweeter by numerous manufacturers worldwide.
Although the transient response and frequency range are extraordinary, alas so is the distortion, typically not much less than 1% http://www.roger-russell.com/ionovac/ionovac.htm Craig |
15th Oct 2020, 2:22 am | #2019 |
Good Lord! I thought 'twas no more than a lab curiosity! To borrow a tagline: 'I never knew there was so much in it!'
15th Oct 2020, 3:07 am | #2020 |
I'm used to plasma sound.
I have a function generator which can generate DC or sine or squarewaves of variable frequency and mark:space ratio, which modulates several kW of plasma. It's rather satisfying from a vintage radio point of view in that the plasma is generated from a thoriated tungsten electrode - water-cooled, no less. 210 Amps with the waa-waa pedal floored. It can go quite loud. It just doesn't sound good at all. A loud barking sound. squarewave much worse than sine. It's a bit bright. Not only do you need the ultimate in peril sensitive sunglasses, you can't leave any skin exposed to the UV. It's made a nice tubular steel hifi rack and a fancy aluminium swing-down bracket arrangement for the antenna mast on the house. The hefty mains cable would make an audiophile very happy indeed and you need something a bit better than an ordinary 13A plug if you wish to turn it up to 210 (199 more than spinal tap) I think I read that some plasma tweeters needed a supply of bottled gas. Argon isn't safe in an enclosed space without good ventilation. David
