10th Oct 2015, 10:50 am | #161 |
Re: 13A Plugs old and not so old
Sadly, it's that sort of complacency/negligence/laziness that meant that moulded-on mains plugs became mandatory on appliances. On balance, not a bad thing, as it's probably the innocent who most often suffered as a result. I'm still fuming slightly at the antique lamp that my sister recently showed me- "Oh, I didn't worry about plugging it in, 'cos it had been PAT tested". PAT tested by someone who was a criminal or an idiot or both, that is.
At least a moulded-on plug probably has either crimped or welded terminations that are unlikely to work loose, unlike the screws that frequently are found to be loose in fitted plugs. |
10th Oct 2015, 5:06 pm | #162 |
Since the Woolworth's brand 'Hercules' was mentioned previously, I'm reminded of rubber Hercules flush unswitched wall sockets with their trade mark fine vertical stripe moulding on the face plate. Or did I imagine it? Cheers, Pete.
10th Oct 2015, 6:01 pm | #163 |
A new estate that was built near me in the '40s had round pin 13 amp plugs with the live pin which unscrewed being the fuse, people complained bitterly about the cost of these fuses being used to only fitting a length of wire to the to the fuse in the fuse box previously. Does anyone have one of these plugs?
Peter |
10th Oct 2015, 6:14 pm | #164 |
Surely they must have been 15A plug tops? AFAIK there were never any round-pin 13A ones. I've never seen a fused 15A plug top though.
I've just found the wiki entry that says BS546 plug tops could be made to accept BS646 fuses - of a maximum rating identical to the rating of the connector.
Richard Index: recursive loop: see recursive loop Last edited by mole42uk; 10th Oct 2015 at 6:25 pm. Reason: Extra information |
10th Oct 2015, 8:13 pm | #165 |
They were made by Dorman Smith and were quite common on council estates. I think the BBC used them a lot too. I have a few plugs & sockets but no photos as yet (unless you can spot them among this lot in the third photo! Five of them on the right hand end of the third row down). However, here is a two way DS adapter with the pin-fuse. P.S. MK made fused round pin plugs of each rating; 2, 5 and 15 amp. I'll photograph them next time I've got the 'plug box' out. Don't know if any other companies made them as well. Cheers, Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..." Last edited by Tractorfan; 10th Oct 2015 at 8:22 pm. |
10th Oct 2015, 8:48 pm | #166 |
Did you mean right hand end?
11th Oct 2015, 8:40 am | #167 |
They were definitely 13A, that was the first time I had heard of them. The estate was built just after the war on what was woodland near where we lived, they dynamited the tree stumps out and it sounded as though the war was still going on.
We used to have a lot of customers on the estate so I was well familiar with the plugs but it wasn't long before the modern 13a plugs appeared, I first saw them on another new estate in the '50s. They were in the minority for a number of years though, Petts Wood where we lived had variety of plugs and they varied from the posh side of the railway and the cinema side where we lived. There were 2,5,10 and 15 amp round pin plugs on our side and only the 15a were three pin, the other side used Wylex and some other weird and wonderful things. We had various types of 'universal' plugs on our soldering irons but they didn't fit the BC sockets that were still widely used. Peter |
11th Oct 2015, 12:21 pm | #168 |
In my Misc Fuses box I have one of those Dorman Smith fuse pins. It's stamped 15 at the end, no other markings remain.
11th Oct 2015, 1:03 pm | #169 |
We had those plugs in the council house I lived in as a child. Fuse ratings other than 13A were available and they were coloured coded. The fuse had a nasty habit of snapping off in the wall socket leaving a length of fuse wire protruding which could shock the unwary.
By the 1970's the plugs were becoming increasingly expensive and it was a relief when the house was rewired with standard 13A sockets. This job wasn't as easy as it sounded as the sockets were mounted on round conduit boxes which had to be changed for square ones.
12th Oct 2015, 7:06 pm | #170 | |
As for PAT testing, I bought an apparently PAT tested lamp as well some years ago. It didn't work, the bulb just didn't light up. I moved it around and the cable with exposed live ends fell out the base, narrowly missing my arm. So I don't trust PAT test labels any more either. If it's second hand, I always open it up and look inside before I plug it in. |
12th Oct 2015, 7:38 pm | #171 |
I don't trust moulded 13A plugs because I can't open them up to check them, and from some comments on the web there are some very dubious ones around now. Anything I depend on, anything that is going to run unattended (when I am out, asleep, whatever) I cut off the moulded plug and fit a rewireable one.
I totally ignore PAT labels. Everything, old or new, gets opened up for inspection and then gets my version of the tests including a proper insulation test. Perhaps I have been lucky, perhaps it's bacause most of my old stuff is HP, Tektronix, etc, but I have found a lot more dodgy new stuff than second-hand stuff! |
12th Oct 2015, 8:40 pm | #172 |
Please keep on topic, PAT has been extensively covered in relevant threads.
12th Oct 2015, 8:48 pm | #173 | |
Source-traceable 1-metre 6A IEC-moulded-plug lead - £1.39 My chargeable-time to a customer - £45/hour +VAT. Why waste time messing around? |
12th Oct 2015, 11:08 pm | #174 |
Re #57, D&S's earliest patent (GB574125) covering their type of fused plug was applied for in 1943, before the 13A system had been finalised. Possibly the original concept would have been to provide fuses corresponding with the then-existing 2A, 5A and 15A circuits, and the 15A fuse is a relic of this?
12th Oct 2015, 11:44 pm | #175 | |
The CSA was marked on the cable as 0.5mm and when testing it that was the CSA of the bundle of strands. The earth resistance hardly lifted the pointer off the bottom stop. Fitting a fused plug onto one of these is just not good enough. |
13th Oct 2015, 9:54 am | #176 |
Just an aside- if 3*0.5mm is interpreted literally as written, the total CSA of three 0.5mm dia wires is about 0.5mm^2.
13th Oct 2015, 10:12 am | #177 |
I interpreted it as meaning that the flex contained three insulated wires each made up of a number of strands having a total CSA of 0.5mm^2, which is what was measured. This would be good for 3 amps. Lack of a fuse could be a problem though.
The sockets on these cables are designed so that they can't be used with an electric kettle.
13th Oct 2015, 1:59 pm | #178 |
The ones with a fused plug are rated at 6 amps.
The one I took to bits read just under 1 ohm per core. At 6 amps the cable would dissipate about 60 watts. The wires are too thin to reliably be terminated in a regular fused plug. I chopped it up and used the wires to fix rubber wiring in a radio. |
13th Oct 2015, 4:00 pm | #179 |
These cheap fuse-less 13A plugs have featured before, with much the same conclusion. People like us, with the knowledge we have, should really just scrap them on sight. As has been said, decent ones are available for peanuts.
13th Oct 2015, 6:51 pm | #180 |
As promised, here's a few pics of my DS plugs & sockets. Oddly, they don't seem to have any cable grip device, unless something is missing from them. I've also thrown in a Wylex type plug & socket for good measure. Apologies for the green tint. Cheers, Pete.
