Old 28th Jun 2015, 11:54 pm   #141
hannahs radios
Default Re: 13A Plugs old and not so old
I remember those Volex plugs. We had one on our freezer in the late seventies until it started to smoke one day. It was replaced and then given to me to play with.
I still have, and use, a VT branded adaptor. It's got 13 amp pins, a 13 amp socket on the front, and 2x5 amp 2 pin sockets top and bottom. Its those I use it for and yes, its fused at 5 amps.
hannahs radios is offline
Old 30th Jun 2015, 8:37 am   #142
Tractorfan
Tractorfan's Avatar
Smile Re: 13A Plugs old and not so old
I have a variant of the Clix plug with another 13amp socket on top, therefore they could have been stacked! I'm not sure (without another look at it) whether the fuse protects just the flex, or the socket as well.
The final two photos show a Clix two pin 15amp plug with the same type of cord grip.
Cheers, Pete.
Name:	Clix stackable.jpg
ID:	110147   Click image for larger version
Name:	Clix stacking plug (1).jpg
ID:	110148   Click image for larger version
Name:	Clix 15A plug.jpg
ID:	110149   Click image for larger version
Name:	Clix 15A plug (1).jpg
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 30th Jun 2015, 3:35 pm   #143
Leon Crampin
I have some of those Clix stacking 13A plugs still in use. Mine are white. The fuse protects both the load attached to the plug, and the socket which accepts a further plug. No chance of (n x 13)A loads...
I would only use these for low current applications, with no likelihood of cable strain.
Leon.
Leon Crampin is offline
Old 8th Oct 2015, 5:38 pm   #144
happytiger
No Longer a Member
Originally Posted by broadgage View Post
That is certainly one possible explanation, but I was told an alternative.
That the hole was to allow the user of an earthed appliance to verify, without dismantling, that the earth wire was still connected.
This could ell be the case. The earth connection has to be visible,in order to verify its integrity. When a 3core cable was fed though the case of an appliance,the earth was immediately brought back out to an external earth connection. The same with plugs, the earth was the outer shield.
This practice is not in use now, except for the Shuko plugs.
happytiger is offline
Old 8th Oct 2015, 9:43 pm   #145
Refugee
Refugee's Avatar
We have only come up with one batch of NOS plugs so far but I can manage a carton of five MK un-switched sockets in brown Bakelite. Yes they really are NIB.
They are a little bit shiny for the camera but still.
Also I thought it worth sticking up a Duraplug with RS branding and a NATO numbered BICC branded split live pin one in white Nylon.
Also with RS branding I have one of those ones with the emergency pull out handle on it for those chip fryers that used to catch fire and so on.
I am pretty sure the window above the earth pin was to allow an earth wire to be run the earth socket by the aerial connection on radios that used an external aerial.
ID:	114037   Click image for larger version
ID:	114038   Click image for larger version
ID:	114039   Click image for larger version
ID:	114040   Click image for larger version
Last edited by Refugee; 8th Oct 2015 at 9:51 pm. Reason: To add a bit about earth pins.
Refugee is offline
Old 8th Oct 2015, 11:13 pm   #146
McMurdo
McMurdo's Avatar
Those duraplugs seem to leach something out of the rubber that coats the fuse and clips with black and are a favourite for having a nick in the lid for the cable! Weren't they part of MK?
My AVO RF generator has one of those military BICC plug on it. They were also sold as 'legrand'. I like them alot
Kevin
McMurdo is offline
Old 8th Oct 2015, 11:32 pm   #147
broadgage
AFAIK, the better quality fuses and fuse clips are silver plated, Sulphur is used in the vulcanising of rubber, and minute amounts leach out or outgas and turn the silver plated parts black due to the formation of silver sulphide.
If a fuse is removed after many years of use in a rubber plug, then that part of the fuse that was in tight contact with the fuse clips remains silver coloured when the rest has gone black.
(eggs contain sulphur, and it may be observed that a silver or silver plated spoon used for eating eggs will require much more frequent polishing than a similar spoon used for other foods)
broadgage is offline
Old 8th Oct 2015, 11:33 pm   #148
Refugee
Refugee's Avatar
I can't quite remember but think it was the rubbery white Duraplugs that used to get black fuses.
That orange one has a more solid feel to the top. It might be some kind of hard Vinyl stuff.
Refugee is offline
Old 8th Oct 2015, 11:51 pm   #149
Alistair D
Alistair D's Avatar
I collect those legrand plugs. They were available in white, red, green, yellow, blue and black. I have a selection of all but the black one. I was outbid on that at £8.00 so still looking.
Al
Alistair D is offline
Old 9th Oct 2015, 2:47 pm   #150
Tractorfan
Tractorfan's Avatar
My parents bought a table lamp from British Home Stores back in the early 70s and they also bought a plug for Dad to fit. It's BHS's own brand, but I've only seen one other like it in blue. I've no idea who made these. Alas, both parents and the lamp are no more, but the plug survives!
Note the unusual wiring layout and early use of the 'ratchet' style cord grip.
Cheers, Pete.
ID:	114060   Click image for larger version
Name:	BHS plug (4).jpg
ID:	114061   Click image for larger version
Name:	BHS plug (2).jpg
Old 9th Oct 2015, 3:52 pm   #151
Nickthedentist
Nickthedentist's Avatar
Unusual indeed. I suspect the design was like that so that the wires could be the same length, a bit like the MK ones - or was it Ever Ready?
Nickthedentist is offline
Old 9th Oct 2015, 4:53 pm   #152
Refugee
Refugee's Avatar
The same length wiring plugs were Ever Ready.
While I had the plug box out we can have a look at a Micromark one.
I have also found found two Legrand split live ones in blue and white.
ID:	114070   Click image for larger version
ID:	114071   Click image for larger version
Refugee is offline
Old 9th Oct 2015, 7:32 pm   #153
McMurdo
McMurdo's Avatar
I've seen the every-ready ones badged as 'Marbo'; maybe the original manufacturer?
Kevin
McMurdo is offline
Old 9th Oct 2015, 8:06 pm   #154
G6Tanuki
G6Tanuki's Avatar
The original "MK Safetyplug" also boasted about the convenience of the equal-length-wires thing.
The orange RS-branded Duraplug - I used to have one of them on a length of similarly-orange 2-core cable back in the days of the Flymo electric lawnmower (which was also orange!). It was just the cover part of the plug that was orange - the bit the pins/fuse fitted into was the traditional black.
Another brand of rubber plug I remember was "Hercules" - Woolworths clone of Duraplug. They didn't handle prolonged high current (3Kw fan heater...) well, giving off a distinctive pong to highlight their distressed state.
G6Tanuki is offline
Old 9th Oct 2015, 8:37 pm   #155
dseymo1
Very true! I wonder why, as they seemed fairly decently made, and used similar gauge conductors as the Duraplug ones?
dseymo1 is offline
Old 10th Oct 2015, 2:04 am   #156
julie_m
I remember the BICC / Legrand ultra-slimline plugs, and had a bit of a collection of them at one point. I think the requirement for part-sleeved live and neutral pins -- making it possible to push a plug out of the socket safely from behind -- killed off the design.
As for equal-length wires, isn't that a bad idea? I thought the intention was to have the earth wire longer than the live and neutral wires so if the cable was pulled, the live wire would come out of its terminal (and stop the appliance from working) before the earth wire came out of its terminal (and stayed unnoticed until one day a fault developed in the appliance).
julie_m is offline
Old 10th Oct 2015, 4:35 am   #157
G8UWM-MildMartin
The Legrand version was definitely made with sleeved (with black plastic) pins fairly recently, well, actually, maybe 10 to 30 years ago... because there's one I bought at the time on something I made in 1987.
As regards equal cores, yes, they should have been cut to the correct lengths, but rarely were. You've also probably seen equipment from before the days of mandatory fitted plugs and noticed well over half are unacceptably badly done. The MK and Ever Ready/MB Marbo designs did help, but were very expensive and quite dear, respectively.
And the latter was prone to damage, leaving the top of the fuse exposed.
G8UWM-MildMartin is offline
Old 10th Oct 2015, 9:21 am   #158
Herald1360
Herald1360's Avatar
Equal cut length wires doesn't preclude the earth wire being slack when the others are taut. The layout of the plug can sort that issue out.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 10th Oct 2015, 9:58 am   #159
Nickthedentist
Exactly; look at the plug in post 39, and you'll see that the route to the earth terminal is straight, but those to the L & N terminals are more tortuous and longer. Well, that's what I like to think
Old 10th Oct 2015, 10:15 am   #160
Refugee
Refugee's Avatar
Take a look at what they do if the earth wire is too short
Refugee is offline
