18th Oct 2020, 1:59 pm | #1 |
Saved from the tip, but now scrap.
It was working the Pioneer PDZ56OT CD player having fitted a D to A converter , but after drilling a hole in the back panel, it didn't work ,the lens had popped out of it's mounting due to the vibration ,I could see with the glue marks which way it would fit ,so fitted it gave it a tiny spot of super glue , still not working ,so don't drill the case of your CD players. Mick.
It may be worth asking on the wanted . |
18th Oct 2020, 4:07 pm | #2 |
Re: Saved from the tip, but now scrap.
Er, is it a silly question, but why were you drilling a hole in the case?
Nick |
18th Oct 2020, 6:58 pm | #3 |
It's not a silly question Nick , I was fixing the D/A convertor to the rear of the unit ,what I find strange is the lens is perfectly level all round in theory it should have worked ,it's trying but not finding focus ,therefor not spinning the disk , Mick.
18th Oct 2020, 7:39 pm | #4 |
Has the glue vapour caused the lens to opacify?
18th Oct 2020, 8:48 pm | #5 |
Same thing happened to me about 18 months back. Pioneer too! Lens clouded up, even though I only used a tiny drop of glue. The mechanism was damaged anyway (it was a combo amp/2-cd changer someone had forced) so I wasn't too peeved. On the lookout for a scrap unit to cannibalize. Maybe you can pry off the lens and clean it? Or google the optical block number and see if there are affordable replacements.
Regards, Ben. |
18th Oct 2020, 8:49 pm | #6 |
Has some debris from the drilling got into the movement perhap's?
It's a very fine air gap for the focus motor which functions in the same way a loudspeaker voice coil. There is'nt much torque involved and just a speck can impede movement. Try carefully vacuuming or air blast the movement? Nick |
18th Oct 2020, 10:35 pm | #7 |
I am ok with the working of the laser ,focusing etc , the drilling was at the opposite end to the cd deck I am always very careful when drilling , using a rag to catch any turnings, Mick.
19th Oct 2020, 7:31 am | #8 | |
Peter |
19th Oct 2020, 7:36 am | #9 |
You shouldn't have used the hammer action drill
