Old 14th Oct 2020, 12:18 am   #1
Martin Bush
Martin Bush's Avatar
Default Lathe cut records
Hello all
I happened across this while looking up releases by one of my favourite artists, Ariel Pink.
The work this chap does is amazing and his sheer output, combined with his attention to detail is very pleasing.
I have no connection with the chap or the business, but I thought some on here would find his work interesting especially as he uses vintage technology and teaches people about it too.
https://www.michaeldixonvinylart.com/
Martin
Is it live, or is it... no, it's live actually...
Martin Bush is online now
Old 14th Oct 2020, 8:29 am   #2
John10b
Default Re: Lathe cut records
Very interesting thank you for the information.
John
John10b is offline
Old 15th Oct 2020, 10:08 am   #3
woodchips
Yes, interesting, makes you wonder if you could repeat what he does using a centre lathe with power cross feed?
Ummm?
woodchips is offline
Old 15th Oct 2020, 4:28 pm   #4
Martin Bush
I have one of his discs coming to me via Discogs. I only came across him when looking for interesting vinyl releases by Ariel Pink. The one that's on its way is supposedly cut on some sort of mirror-type material.
I don't know enough about lathes to answer your question Woodchips
I think what appeals to me is that he's doing something really interesting that can be played on normal record decks. He also does a range of CDs which play on both CD players and turntables (possible because CDs play from inside out and records outside in I presume).
Old 16th Oct 2020, 11:55 pm   #5
Martin Bush
Hi all
I now have one of the discs I mention above. This one is made on a piece of mirrored acrylic sourced from an off cuts bin. The sleeves is silk screened onto an interesting honeycomb type plastic which was also salvaged.
To me it's a thing of great interest and beauty. All the better for the fact that the disc was created using a 1940s piece of equipment.
Martin
Old 17th Oct 2020, 8:10 am   #6
saxmaniac
There's a chap called Norman Field in the Midlands who makes his own records on polycarbonate sheets, there's YouTube videos if you search his name
saxmaniac is offline
