1st Jun 2020, 1:48 am | #1561 | |
Re: The Audiophoolery Thread.
Forgive me but a string of emojis can say a thousand words in this case. Steve
1st Jun 2020, 7:41 am | #1562 |
There are plenty of consumers out to take a vendor for a ta-ta if they can. Excuses like 'They're insured for it' and 'It's nothing seen in their turnover' and 'they're fleecing us anyway' abound. While plenty of vendors think 'There's one born every minute' and "He won't be back, but there's plenty more where he came from'
It's all rather messy. Caveat emptor! Caveat vendor! It's beginning to feel good when you come across something which isn't a scam. This forum (those damned Romans!) is a calm, protected backwater on the internet. Whenever I look elsewhere all my scam-sensors start tingling if not screaming. But amidst all the nastiness, let's treasure the good guys. The nastier the rest gets, the more special they become. David
1st Jun 2020, 8:29 am | #1563 |
On the subject of general consumer awareness and caution, I believe that sincere (sine cera) originates from a similar time, place and circumstance as caveat emptor. Being a shyster is as old as the hills.
1st Jun 2020, 10:10 am | #1564 | |
1st Jun 2020, 3:10 pm | #1565 | |
It sold at Christie's in 1994 for £93,500 presumably because it still contained some of Parker's spit. |
1st Jun 2020, 3:21 pm | #1566 |
New, most expensive AudioQuest speaker cable, the Dragon Zero. £5900 for a 1 metre pair. If you need a more typical 2.5 metres it is £13,400.
Typical BS. They have (mysteriously) eliminated characteristic impedance. "By eliminating the Mythical Creatures speaker cable’s characteristic impedance, current compression and distortion of the signal (current) transient is significantly reduced" they say. Oh yes - everyone needs to banish characteristic impedance. Think of the benefit to 5G comms! It also features a "Dielectric-Bias System with Carbon-Level Radio-Frequency Trap (DBS) All insulation is also a dielectric whose electrical properties affect the integrity of the signal. When the insulation is unbiased, dielectric-involvement (absorption and non-linear release of energy back into the signal flow) causes different amounts of time delay (phase shift) for different frequencies and energy levels, which is a significant problem for very time-sensitive multi-octave audio. AudioQuest’s multi-patented DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes the nonlinear time delays, resulting in clearer sound emerging from a “blacker” background." No measurements to support those claims of course. Just words. And other nonsense. https://www.audioquest.com/cables/sp...es/dragon-zero In fairness they do a range of speaker cables at the £20 level too, that are real honest copper. Craig |
1st Jun 2020, 3:24 pm | #1567 | ||
1st Jun 2020, 3:41 pm | #1568 |
They even patented the Dielectric Bias System (attached). Basically a battery connected between two additional conducting features in the cable. I'm going to refrain from comment - but I really look forward to yours!
Craig |
1st Jun 2020, 3:47 pm | #1569 |
"Sincere" derives from the Latin "sincerus" which means clean, not from "sine cera".
1st Jun 2020, 4:08 pm | #1570 | |||
Last edited by barretter; 1st Jun 2020 at 4:12 pm. Reason: Misspelling of "something" |
1st Jun 2020, 4:26 pm | #1571 |
They took out an updated version - a "continuance" of the earlier one, attached.
Of course you could measure (or rather not) the effect of all this flummery using a null tester https://www.youtube.com/watch?v=ZyWt3kANA3Q But which manufacturer would want to be confused with reality? Craig |
1st Jun 2020, 5:28 pm | #1572 | |
1st Jun 2020, 5:39 pm | #1573 |
1st Jun 2020, 5:57 pm | #1574 |
Something I've always expected of the high-end business remains unfulfilled.
I have never seen an advert offering high-end equipment decontamination services - the restoration of high-end equipment which has been used with other equipment not appropriate to its stature. Passing wrong signals through it will surely undo many days of careful and skilled breaking-in, if it doesn't do irreversible damage. If cheap interconnects or cables have been used, there will be tiny amounts of inadequate material left behind on the connectors and binding posts. Obviously the connectors will have to be replaced by either factory originals or pundit approved tweaky ones. David
1st Jun 2020, 6:00 pm | #1575 | |
1st Jun 2020, 7:28 pm | #1576 | |
Edit - maybe he thinks there is a fault with the analyser as it isn't telling him the audiophool cables are any better than cooker wire. |
1st Jun 2020, 8:45 pm | #1577 | ||
1st Jun 2020, 8:52 pm | #1578 | |
A mischievous thought occurs to me that maybe a sceptical miscreant in their copywriting department came up with "Dielectric-Bias System with Carbon-Level Radio-Frequency Trap" - or Double BS for short....
1st Jun 2020, 8:53 pm | #1579 |
Several posts referring to an eBay sale deleted. Some posts referring to the same products but via different routes remain.
2nd Jun 2020, 12:07 am | #1580 | |
Of course now known for its toxicity. One of the things that people who restore Garrard decks (and charge good money to do so) is to strip off the cadmium and either zinc or chrome plate. Craig |
