29th Apr 2020, 3:06 pm | #1381 |
Re: The Audiophoolery Thread.
Don't make fun of it. Start selling wall sockets. And special circuit breakers for the fuse box.
Stuart The golden age is always yesterday - Asa Briggs |
29th Apr 2020, 3:14 pm | #1382 | |
https://en.wikipedia.org/wiki/Arthur_Paul_Pedrick
29th Apr 2020, 3:43 pm | #1383 |
HaHa - looks like a great character was Pedrick!
29th Apr 2020, 4:13 pm | #1384 |
It's really quite simple. A number of people just don't comprehend that a cable is conveying a signal E-L-E-C-T-R-I-C-A-L-L-Y and they treat the cables as if they were M-E-C-H-A-N-I-C-A-L in operation. Then they ponder what sorts of cables are needed to be able to convey both low frequency and high frequency vibrations.
It explains so much. USB cables can give flaccid bass, particularly if they have too much plasticiser in the PVC. Reviewers only have to look at an item to assess its heft and stiffness and from that their finely-tuned minds can determine what it must sound like. It saves the publications a fortune in test equipment, and because they know what they're going to hear, publication deadlines aren't threatened by overlong listening sessions. David
29th Apr 2020, 10:01 pm | #1385 | |
And then to think that these purchasers might be working with numbers in their day jobs makes it worse. 99.999999% indeed! Can anyone explain what might be meant or implied by a 'velocity of propagation of 88%'? |
29th Apr 2020, 10:27 pm | #1386 |
The velocity factor is 1/(c x root(LC)) . At RF. They have just changed that number <1 into a percentage by multiplying it by 100, for marketing reasons no doubt.
At low frequency, like audio frequencies such at mains 50Hz, it is entirely irreverent. Unless you have hundreds of km of cable... There is a half way decent reference that covers transmission lines audio frequency here http://audiosystemsgroup.com/TransLines-LowFreq.pdf Craig Last edited by Craig Sawyers; 29th Apr 2020 at 10:33 pm. |
29th Apr 2020, 10:27 pm | #1387 |
Prevents unwanted floor-cable coupling effects
Kevin |
29th Apr 2020, 10:31 pm | #1388 |
I'm still stuck wondering what 'Dual Mono-Filament' can be. If that is 2x1 then its just dual filaments surely.
Ian |
29th Apr 2020, 10:33 pm | #1389 |
something to cheer us all up
Kevin |
29th Apr 2020, 11:10 pm | #1390 |
And this too http://audiosystemsgroup.com/AES-RFI-SF08.pdf . AES presentation on RFI and audio (both balanced and unbalanced)
29th Apr 2020, 11:15 pm | #1391 |
I guess all this is the audio equivalent of astrology.
Steve.
29th Apr 2020, 11:20 pm | #1392 | |
The 88% velocity factor comes out of the air-to-plastic ratio and the dielectric constant of the plastic. The fun comes in contemplating why they bothered and what difference they thought it would make to the behaviour of the system using their cable. The only real effect is on the marketing guff. David
29th Apr 2020, 11:22 pm | #1393 |
But, still touching the floor in a roundabout way.
Though what would be cool is to be able to buy a set of mini replica pylons for anging cables in between, no technical reason for doing so but would be interesting none the less. Something else, not really audiophoolery admittedly, was on another forum when toy got to talking about CD's and the interesting fact that one of their flaws is that the error correction was designed to counter there being tiny holes in the reflective layer, the reason being that early CD's weren't perfect and such tiny holes were happening during manufacturing and as such the error correction system was designed to allow for this9supposedly you can drill a small hole in a CD and it will still work!) . Now in reality early problems with CD manufacture/duplication were quickly ironed out and as such the main problems were with dirt/scratches on the disc, this meant that the CD player would read some good data then some seemly good but mangled data then some more good data when the error correction mechanism is designed for a period of good data, no data then good data again, this is what causes the CD to skip and get stuck in a loop as it gets confused and cannot fix the error.. |
29th Apr 2020, 11:25 pm | #1394 |
But those cables aren't new! they're made out of really old stuff.
The copper was made in the heart of a star which went nova, and you can tell by their temperature that it was at least a good while ago. They've had a real burn-in and had billions of years to settle. David
30th Apr 2020, 12:14 am | #1395 |
That British Rail patent was accepted under the pre-1977 act ( serial numbers below 2,000,000) where the applicant was in practice always given the benefit of doubt (this was explicitly stated in the act). The view was that, if it didn't work, then the public wouldn't be inconvenienced.
Pedric died at around the time I joined the Patent Office. I did once meet the examiner who had dealt with his applications, and was shown a 4 drawer filing cabinet containing numerous annotated books and documents he had submitted. Pedrick evidently suffered from post-traumatic stress syndrome, and only used the patent system as a way of disseminating his ideas for the public good via a publishing medium that was disseminated around the world and would never go out of print. He never paid the sealing fee for any of his patents, so anyone could use them for free. Nowadays he could have used the internet. They weren't all daft: one that proposed reducing friction in ships by blowing small bubbles of air under the hull, seems to be used by some modern cruise liners. |
30th Apr 2020, 9:42 am | #1396 |
What will happen when high temperature superconductivity really gets to room temperature? Sounds like a plan to make money!
Let's ignore for the moment that these materials are ceramics, and have the ductility of a rich tea biscuit.... |
30th Apr 2020, 10:21 am | #1397 |
If that happens, hokey claims about audible effects in hifi cables will be the least of our concerns. There will be some rather dangerous magnets around, and mankind will naturally create whole new types of weapons around them.
30th Apr 2020, 10:30 am | #1398 |
The magnetic rail gun. Too true. Even with resistive magnets the latest ones can fire projectiles 100 miles.
30th Apr 2020, 10:33 am | #1399 |
Frankly I'm disappointed in you with this post.
Why on earth would you compromise the operation of your £16,500 mains cable by putting it on a cheap cable lifter like the one you've linked to? You're just being ridiculous and, if I may boldly suggest, not taking the whole subject seriously. You need at least two of these at a very minimum: https://www.futureshop.co.uk/furutec...yABEgIy6fD_BwE |
30th Apr 2020, 11:28 am | #1400 | |
For £310 a pop. They are clearly having a laugh. For excellent damping I run my speaker cables over the carpet. Job done. Craig |
