Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
23rd May 2020, 2:21 pm | #81 |
Re: Parts in NZ
Looks like the Jaycar range of stuff, same pricing too.
13th Jun 2020, 10:48 am | #82 |
Re: Recommended Component Suppliers.
I've just ordered some pots from Blore Edwards
https://www.blore-ed.com/potentiometers Proper vintage style and they do imperial sizes and custom jobs too. Fast and friendly service from Brett and Amy. The prices are very reasonable. Postage seems to be a standard six quid so for one pot it's a bit expensive but I have several projects waiting so it made sense to order them together. Highly recommended.
Howard |
13th Jun 2020, 2:50 pm | #83 |
I have found this ebay supplier to be a useful source of vintage electronic parts.
https://www.ebay.co.uk/sch/vannadiy/...53.m2749.l2654 They sell a range, but with a strong bias towards glass components. Nixie tubes, many types. VFD displays. Magic eye indicators, several types. Neon lamps, numerous types, including b22 nightlight types. Some specialist gas discharge lamps, including 28volt mercury lamps. A few types of valves but not primarily a valve dealer. |
3rd Jul 2020, 12:29 pm | #84 |
I recently needed 'hard to find' spares for a Grundig Satellit 650 radio and found them at radio-antik a German based supplier. It seems Helmut breaks down radios and sells off the parts. His list is amazing. It's largely 'modern' German and other European radios. He does not understand English too well so best to use Google translate to email him in German. You can also translate the whole site by using Google translate, just plonk the web site address into the translater and it provides the address of a translated version. Also, he does not have an online ordering system as such, you choose the parts you want from his excellently presented lists and then email him and he gives you his bank details to make a bank transfer. My parts just arrived, took just over a week, well packed and as described. From my experience, well recommended.
www.radio-antik.de helmut.schott@radio-antik.de
1st Aug 2020, 9:48 pm | #85 |
Re my earlier post, #101, the supplier sells B22 mains voltage neon lamps that are hard to find elsewhere. An odd size, smaller than a GLS lamp but larger than a golf ball type and much larger than a pigmy lamp.
They also sell a rare type of 8 segment display in which each segment consists of an incandescent filament. Much brighter than first generation LED displays. Obsolete now of course. And several types of miniature CRT. |
7th Dec 2020, 12:19 am | #86 |
I've only looked at resistor prices( .25w), which seem keen. But also , they have a selection of 1/8w resistors and again the prices are keen= from what I've orders it's 20p for ten of the values they stock. Postage is normal at £2 .
WWW.Hobbytronics.co.uk |
16th Oct 2021, 9:59 am | #87 |
Hi.
I've been using this company since I became a radio amateur: https://www.amateurradiosales.co.uk/ They are called Lindars Radio and deal in new Yaesu and a huge amount of used amateur gear at very good prices. I've purchased a 2 meter Yaesu Rig, Linear Amp, Diplexer and some bits and pieces. They even do some vintage components. Located in Yeovil.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member |
21st Oct 2021, 1:50 pm | #88 |
Some portable electronic equipment - amateur radio gear for example - uses sealed lead acid batteries. The local woodturning Club of which I'm Secretary uses a portable PA amplifier with integral speaker, powered from a sealed lead acid battery, with an integral battery charger.
Due to lockdown, the last time the PA system was used until Tuesday evening this week - the relaunch of the Club after 20 months of closure - was February 2020. Though the battery had been recharged, it didn't hold its charge, (unsurprisingly perhaps, given that it was 13 years old), so the PA system failed to work. The dimensions of the 12V 2.9 AH battery are such that I could only find two UK suppliers, one of whom was 'Battery Trader', who supply SLA and other types of rechargeable batteries for everything from cordless power tools to mobility scooters, cameras, motorbikes and intruder alarms. I ordered the SLA battery we needed at 11.30am yesterday. Within minutes I received an email saying it had been despatched via DPD, then an update from DPD saying it would be delivered today between 11.30am and 12.30pm as indeed it was, securely packed, within 24 hours. I thought they deserved a mention, given that they supply such a wide range of rechargeable batteries and based on my experience, give as fast a turn around of orders as we could wish for. The PA system is now back in use. No connection with them, other than as a satisfied customer. https://www.batterytrader.com/
18th Nov 2021, 12:51 am | #89 |
Vendors
Following on from my post in this thread I have attached the spreadshheet that I used to create the list of transformer suppliers.
https://www.vintage-radio.net/forum/...d.php?t=185974 There are links to suppliers of both vintage and modern components that are useful to restorers of old electronic equipment. Al Updated spreadsheet in post 106
I won't tell you how I discovered that. |
18th Nov 2021, 1:21 pm | #90 |
Thanks for that Alistair - very useful.
Regards Mike
Leave me alone - I know what I'm doing. BVWS member, EUG, G-QRP Radio Bygones/Radiophile |
20th Nov 2021, 4:17 pm | #91 |
Bitsbox have been mentioned in other parts of the forum (not sure about this one as could not get search to work properly).
I have used them a number of times for misc electronic bits as they charge a fixed £1.90 postage. I ordered online at 4pm yesterday and the jiffy bag arrived at noon today. http://www.bitsbox.co.uk All bits neatly packaged and labelled.
George |
20th Nov 2021, 6:15 pm | #92 |
Axial capacitors recently supplied by Mr and Mrs Goodman of Towcester, going by the id of 'lyn3009' (on ebay)
Dave |
26th Nov 2021, 6:43 pm | #93 |
Bought a set of NOS valves [CV numbered] for my R209 from PM Components:
Am satisfied - havent worked out the actual manufacturers from the Military letter-codes yet, but the valves work just fine. See http://pmcomponentsnos.co.uk/NOS-valves-2 - they have quite a range and the pricing is sane.
14th Dec 2021, 10:28 pm | #94 |
Looking for potentiometers, I was pointed to Antique Electronic Supply in the USA. Their website is: https://www.tubesandmore.com. It is very comprehensive and clearly laid out. I wonder if others have used them from the UK?
Going through this thread, I notice that couple of of recommended suppliers no longer have active websites, suggesting that they have closed. Mods, is it worth deleting the earlier Bardwells entry? Last edited by qualityten; 14th Dec 2021 at 10:33 pm. |
14th Dec 2021, 11:03 pm | #95 | |
Agree about the website - well laid out, easy to find. Also got good delivery and no hassle. |
18th Jan 2022, 2:18 pm | #96 |
Component Supplies
Perhaps those who are not sure as to where to get a good range of components including electrolytic and other stuff, I would certainly recommend JellyFish Audio.
http://www.jellyfishaudio.com/ The upgraded web site that he has is everything that the radio and electronics person could wish for. Best wishes Ken Last edited by Station X; 2nd Jun 2022 at 8:55 am. Reason: Link added. |
4th Feb 2022, 2:26 pm | #97 |
Vintage Parts site
4th Feb 2022, 3:31 pm | #98 |
Re: Vintage Parts site
I also used them a few weeks ago and also had good service.
Martin BVWS member GQRP Club |
8th May 2022, 5:26 pm | #99 |
I can't find a reference to this website on the forum, so I'll put it here. I've just come across it and it appears to be another useful source for valvish parts.
https://modulusamplification.com |
1st Jun 2022, 4:33 pm | #100 |
Are there any members who'd be prepared to go through the posts in this thread and report dead links and duplicates by clicking the red triangle?
