16th Jan 2021, 12:15 am | #1 |
Philips GM7633/ Cartomatic III valve tester
Having this valve tester sitting around for over 30 years, I have neither liked it -nor trusted it -. The few components that can go wrong have been replaced and the tester works "ok".
My AVO Mk2 & 4, I-177 with its MX949 (& soon to be completed with a Funke W19S) are my preferences when a valve is to be tested, not the Cartomatic. To this tester I have a set of conversion sockets and a large lot of test-cards, valves from the late 50's, even with the card-punching unit in a separate suitcase/box. Some cards seems to have been produced/punched by the local technicians to their needs after updates no longer was available.. No written information whatsoever followed the tester, however. I have downloaded all sorts of information off the interweb, different manuals and diagrams, from different sources, even a online valve to test-card conversion ! Fantastic ! I still just do not understand how to produce a new test card, if wanted As mentioned, i have about hundred -if not more testcards for the most valves from pre-war types to types of the 50 - 60's in the box. Being a emission tester, all elements tied as a diode, does anyone have any experience in how "accurate" this tester is compared to "any other" emmision valve tester" ? This is my major question ;-) There must be a reason why a giant in electronics - Philips perhaps the largest Valve manufacturer in Europe (with Mullard), so soon gave in with a presumable good valve tester, to Max Funke, Mullard, AVO, Metrix et al in Europe. The obvious answer to how it compares to other testers would be: - You having so many testers - do the comparison yourselves! Yes, but from my point of view: So many instruments to mend, so little time, so why re-invent the gunpowder again -and again ? Sooner or later, time permits, I will find out myself - non conclusive Hopefully my version of the "Sussex" will be brought to life this year, according to my components at hand - time being the limiting factor to this project - as well - and as always... Erik/ |
16th Jan 2021, 11:33 am | #2 |
Re: Philips GM7633/ Cartomatic III valve tester
For those who want to know more about this beast there is a good deal of information here:
https://frank.pocnet.net/instruments...30/GM7630.html I have The Mullard test board in its slumbers which was probably also a Philips design. https://mullard.org/blogs/news/aa-1 Cheers Mike T
16th Jan 2021, 12:54 pm | #3 |
Its always good to read about other valve tester enthusiasts, Erik. If your AVO VCM MK4 is working OK, you should be able to use it to reasonably AC standardise a decent triode or pentode valve, & therefore see how accurate your GM7633 is for Ia and Gm.
Alternatively, you could undertake a bit of cross-Scandinavian Border valve testing, by asking Martin Forsberg(aka Dekatron) in Linkoping, Sweden, if he would kindly test a couple of your decent NOS valves on his magic Roe-Test. The AVO Manual for the MK4 also shows you how to DC standardise a wee CV455 or 491(ECC81 or ECC82). If you've got two or three valves in the 10mA to 50mA range of Ia, which have reliable Ia & Gm characteristics, then you're set for regularly calibrating all your valve testers. Regards, David |
