17th Jan 2021, 7:25 pm | #1 |
2SK23A equivalent?
This is a FET in a Sony (ALPS) FM front end I'm trying to subdue. Anybody know of a readily available equivalent? The usual sources aren't that forthcoming.
17th Jan 2021, 7:39 pm | #2 |
Re: 2SK23A equivalent?
Towers lists BFW61 or 2N5459 - the latter is stocked by Cricklewood Electronics.
BF256 L versions have the same pinout d,g,s |
17th Jan 2021, 7:41 pm | #3 |
NTE312. Replacement: 2SK23A. - JFET N Channel.
https://www.datasheetarchive.com/2SK23A-datasheet.html It looks like Newark have some stock; https://www.newark.com/nte-electroni...-92/dp/29C5294 Hope that helps. |
17th Jan 2021, 10:42 pm | #4 |
attached are datasheets for a 2SK19, and my recollection is that the 19 was used in some FM tuners and is not too far away from the 23. I can pop a 19 in the post for you if you'd like to try it. I bought a few for a project some time ago.
B
18th Jan 2021, 12:39 am | #5 |
Thank you all - PM sent, Baz.
