Old 17th Jan 2021, 1:14 am   #1
avocollector
Default Kyoritsu VTVM Model PV - 202 - 115 or 230vac??
Have just acquired this and it arrived with no plug on it. Can any of you wise persons out there save me a bit of time and tell me off hand if it's 115 ac or 230 ac. Also if any manuals for it are around I could not find them. Thanks.
avocollector is offline
Old 17th Jan 2021, 11:55 am   #2
factory
Default Re: Kyoritsu VTVM Model PV - 202 - 115 or 230vac??
Unfortunately most test equipment usually has a dual voltage transformer, if there isn't a voltage selector, then you should find a tag strip either on the transformer or near it, that can be changed with links to set either 115V or 230V.
Edit: Looking at different Kyoritsu VTVM you may find the voltage printed on the transformer.
factory is offline
Old 18th Jan 2021, 5:13 pm   #3
avocollector
Thanks David and you were right about the voltage but NOT on the transformer. Instead it was printed '230vac' on a small metal strip inside the case and neatly obscured by the inside 'knot' in the power cord.
To my shock, horror and utter surprise, it worked perfectly once it had a new mains plug!! 'What is the world coming too??' I ask myself if goods on an internet auction site don't have at least one defunct valve, dodgy electrolytic cap or leaky battery/extensive rusting therefrom inside - incredible. Mind you it was filthy on a level I've rarely seen before BUT cleaned up wonderfully.
Old 19th Jan 2021, 11:59 am   #4
Any mucky pics to share?
Before and after would be good.
Herald1360 is online now
Old 19th Jan 2021, 4:33 pm   #5
avocollector
This is the auction site pic
