Old 14th Jan 2021, 7:05 pm   #1
Skywave
Default EL34 & O/P xfmr. design notes
Intro.
In the Wanted to Buy section (q.v.) I have listed a post about my need for an O/P transformer for an EL34 valve to build a simple test rig to test a number of these valves. Since the plan is to build an item of test gear rather that an A.F. amp. as such, this thread is placed here in this particular Forum section.*
Here is a useful note (found on the www) that deals with the basics of selecting such an O/P xfmr. - and more. I found it to be informative & useful; it might be similarly useful to other members.
http://www.valvewizard.co.uk/se.html
*In my post in that WTB section there are a few posts that would be of benefit if they were moved to this thread: that will obviously be a moderator decision. This idea was inspired by a post by David (Radio Wrangler) in the appropriate thread in the WTB section, q.v.
Al.
Skywave is offline
Old 14th Jan 2021, 8:49 pm   #2
GrimJosef
Default Re: EL34 & O/P xfmr. design notes
For the purposes of testing you could separate the load into its quasi-DC part, which you'd like to be very largely inductive so you don't need a very high voltage HT supply, and its AC part, which you'd like to be largely resistive.
The arrangement involves replacing the output transformer primary with a high-value choke capable of passing the DC. Apart from satisfying these two requirements it can be pretty crude. You also need to add a high-voltage capacitor from the anode, via a high power resistor, to ground. The resistance should be whatever value would have been reflected by an output transformer rom the speaker secondary into the primary. The AC part of the signal voltage will appear across this resistor.
This arrangement is sometimes used with an output transformer in place of the resistor. It makes the design of the output transformer easier since it doesn't have to handle the DC current flowing through the valve, nor does its primary have to sit at the high voltage present on the anode.
GJ
http://www.ampregen.com
GrimJosef is offline
Old 14th Jan 2021, 11:06 pm   #3
Skywave
Thumbs up Re: EL34 & O/P xfmr. design notes
Thanks GJ. All of that is new to me and is worthy of further thought.
Al.
Skywave is offline
