2nd Nov 2022, 11:22 am | #121 |
Re: Mini-Mod 2021!
A bit of expectation management - in case it has been lost in the thread...
My modifications for the MkII are explained in posts #94 and #95 above. (Note that D3 in #94 is the wrong way round!). The mods do not increase the power or range, but address the slight FMing this simple design has, which I suspect may also have something to do with layout. Goodness knows how many MiniMods have been built and presumably this hasn't been generally noticed, although one made with Veroboard did suffer more than most - possibly due to some extraneous long tracks not being cut. Thank you Peter (Electronpusher0) for adding the voltage regulator for extra flexibility, developing your new PCB layout and getting the quality boards made. However, a note of caution; if you use a SMPS some are quite noisy and may leave residual buzz on the MiniMod signal. If you experience this please use a linear PSU or battery. Note that the inductor and transistor/IC part-kit sold by Tony Nailer at Spectrum Communications (on his eBay store) is for the original two-transistor version. You'll need an extra BF256 for the MkII. Tony also supplies the BC548B equivalent to the old BC109 - be aware of the CBE pin-outs. Thank you for all the positive things that have been said about the MiniMod since I published the original version in the Winter BVWS Bulletin way back in 2011! Regards, Ian Last edited by Ian - G4JQT; 2nd Nov 2022 at 11:40 am. |
15th Nov 2022, 11:31 am | #122 |
Re: Mini-Mod 2021!
The boards have arrived!
I have assembled and tested one board in all three variations 1. For battery use with no regulator fitted and a link in the D101 position. 2. For use with a 78L09 regulator - all components starting at number 100 EXCEPT R101 and R102 fitted. 3. For use with an LM317 – all components starting at number 100 fitted. All three options work. However there are two minor errors in the layout but they do not affect its operation. The errors are: The silk screen shows the tab of the LM317 facing the top of the board, it must be mounted with the tab facing the bottom. See pictures The second error is quite embarrassing. The 3.5mm stereo jack socket footprint is upside down, this means that the socket must be mounted on the copper side of the board! Fortunately the socket is low profile so should not be too much of a problem. The error occurred because this is a footprint I created myself and KiCad requires footprints to be constructed as viewed from the top of the board. I found the dimensions of the socket on line but of course they were viewed from underneath and I forgot to transpose them. I will now offer the remaining boards on the appropriate section of the forum. The boards themselves cost £1 each including the shipment from China. Ian, whose design it is, has requested a £1 per board donation to Charity. Postage will be £1.45 first class but I will increase that to £2 to allow for packing. I will limit the offer to 2 boards per person initially just in case there is a rush!. I have 28 available. Peter |
15th Nov 2022, 11:33 am | #123 |
Re: Mini-Mod 2021!
Photos of the LM317 and scope images during testing.
Peter |
18th Nov 2022, 7:40 pm | #124 |
Re: Mini-Mod 2021!
Now I've bought a circuit board I'm now thinking of gathering up the components to build up the pcb.
I know spectrum sell a pack containing the coils & transistors. Is there a parts list available ? Robin |
18th Nov 2022, 11:22 pm | #125 | |
Re: Mini-Mod 2021!
Please note there are some modifications, all of which are included in Electonpusher's latest PCB. The MK II uses an equivalent to the BC109 (although a BC109 is fine if you have one) and there is an extra FET as the buffer, with a few extra parts around it. If I remember tomorrow I'll post links from relevant threads in this forum from relevant posts, if they are not already here in this thread. But really all you need to know is the two inductors are 90uH coils sold by Spectrum Communications: http://www.spectrumcomms.co.uk/Components.htm And the relevant Spectrum Communications ebay page is: https://www.ebay.co.uk/itm/284204729...Bk9SR5CHk7aRYQ Original MK I article from 2011: The_Bulletin_2011_MiniMod2.pdf |
19th Nov 2022, 10:06 am | #126 |
Re: Mini-Mod 2021!
Thank you Ian , the link to the bvws 2011 bulletin was an interesting read.
Robin |
19th Nov 2022, 10:25 am | #127 |
Re: Mini-Mod 2021!
Post 122 has Electonpusher's board circuit diagram showing all the components and thier values. The only parts that aren't clearly narked with values are the two inductors which are available from Spectrum Communications in my links in post 125 above.
19th Nov 2022, 10:30 am | #128 |
Location: Near Worcestershire/Gloucestershire border (in WR), UK.
Re: Mini-Mod 2021!
Thank you Ian - and many thanks for the design and generous sharing of it, appreciated.
19th Nov 2022, 1:14 pm | #129 |
Re: Mini-Mod 2021!
Just prepared a parts list for the MK2 Minimod.
I have checked it several times for any mistakes..... Compiled using libre office as i do not have WORD on my pc. Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd |
19th Nov 2022, 4:31 pm | #130 | |
Re: Mini-Mod 2021!
For anyone having trouble finding 680n for C12, 470n will be good enough. Maybe a very slight reduction in bass. I'm sure someone can do the modelling to come with the theoretical figures, and I can see it on a scope, but not really heard a difference in most of the radios I use. Repeat note: The MKII addresses the slight FMing of the MKI which I describe in the article and also in this thread post 121. The MKII does not have more range which is still only a few feet. |
19th Nov 2022, 10:56 pm | #131 |
Re: Mini-Mod 2021!
My post 129, the BOM document. Steve_Bell notified me of an error. Thanks. C6 should be 4n7 and not 47n as listed.
I have revised the document with the change. Thanks, Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd Last edited by CambridgeWorks; 19th Nov 2022 at 11:04 pm. Reason: added doc |
17th Jan 2023, 5:47 am | #132 |
Location: Sometimes Suffolk and other times Limburg, NL
Re: Mini-Mod 2021!
17th Jan 2023, 11:01 am | #133 | |
Re: Mini-Mod 2021!
And one for the MK2...? |
1st Feb 2023, 7:29 pm | #134 | |
Re: Mini-Mod 2021!
Can the mini-mod be modded with some extra components and power for a longer transmission range, like about 10 metres or so without piling on extra outside interference and staying within the legal rules and regulations? Just a thought. Cheers. |
2nd Feb 2023, 12:13 pm | #135 |
Re: Mini-Mod 2021!
Might be pushing the rules a bit, perhaps a longer aerial? But do check the range.
2nd Feb 2023, 2:51 pm | #136 | ||
Re: Mini-Mod 2021!
The MiniMod (MkI and MkII) is designed to have limited range. Unfortunately a completely different design is required for more range, as described in the original article posted in one or two of these threads. There aren't any regulations for an unlicensed MW transmitter of any power - they are all illegal! But to be honest, I doubt a more powerful illegal MW transmitter with a range of a tens of yards is going to attract the wrath of the authorities, unless you're causing interference to legitimate stations. Ofcom have better things to do, but of course that's not their official policy and I'm not suggesting anyone try their luck! Ian |
3rd Feb 2023, 5:34 pm | #137 |
Re: Mini-Mod 2021!
Ok, Thanks Ian andHamish for giving me the heads up with that info. I was also chatting to Radio Wrangler and he was saying much the same along those lines, to keep it sweet and not try and go overboard with the transmission distance.
8 - 10 meters range is about what I would desire so I could keep the mini-mod beside my upstairs hi-fi and my vintage radio down stairs in the kitchen about 8 or so meters away. Thanks for that info fellas. Greg. |
