22nd Dec 2023, 5:56 pm | #1 |
What nut thread is this?
I'm referring to the nuts used on panel-mounting toggle switches, fuse holders, etc.
It appears to be 0.5 inch diameter but I would like to know what thread form it is. |
22nd Dec 2023, 6:04 pm | #2 |
Re: What nut thread is this?
I have always assumed it was 15/32 UNEF.
Bulgin simply state 15/32 X 32 tpi. Last edited by barrymagrec; 22nd Dec 2023 at 6:15 pm. Reason: extra info |
22nd Dec 2023, 8:50 pm | #3 |
Hi Steve, I think there were one or two different sizes as the OD varies between makers.
I have a good selection of nuts if you need any Cheers. Ed |
22nd Dec 2023, 9:28 pm | #4 |
Some rotary switches of continental manufacture (such as Elma) use a M10 x 0.75 thread, but I have never encountered any toggle switches with this thread type. This thread size was also used on the pot and tuning shafts of the car radios made for Ford by Plessey in the late 1960's.
The technical section of the 1936 Bulgin catalogue simply said that all bushes were 15/32" × 32 tpi: the UNEF standard hadn't been established at that date. I would think that manufacturing tolerances would mean that either the 55° Whitworth form or the 60° Unified form would mate in either direction, rather like the 1/4" Whitworth/UNC thread used for attaching cameras to tripods. Last edited by emeritus; 22nd Dec 2023 at 9:53 pm. Reason: typos |
23rd Dec 2023, 5:32 pm | #5 |
Steve,
Might this be the necessary stimulus to invest in a set of screw thread gauges? Your 'hexode' status suggests that you have, and probably will meet this problem more than once. With a set of screw thread gauges and a digital calliper, you'll never need to wonder again - the thread tables are easily downloaded. PMM |
24th Dec 2023, 9:22 pm | #6 |
Thanks for all replies. I'll investigate screw thread gauges.
